MUM Europe 2020
warenbe
Wrong ethernet speed negotiation
Sat Oct 12, 2019 7:22 pm
Hi all
i have 2 LHG G-5acD-XL connected through nstreme.
each LHG is connected to a 1Gbps switch using cat 6 cable.
Cable are tested and OK
But on both sides, the ethernet is running at 100Mbs full duplex rate :(
system are up to date. (6.45.6 package version & firmware)
on site A, i see that the LHG advertise 1Gbps but "link partner" is advertising 100Mbps
On site B i see that the LHG advertise only 100Mbs, and does not advertise 1Gbps
changing Switch does not work
setting auto neg to off and forcing 1Gpbs does not work (thanks "safe mode")
do you have an idea ?
pe1chl
Re: Wrong ethernet speed negotiation
Sat Oct 12, 2019 7:42 pm
I have seen such things happen in radio transmission towers where there are strong transmitter signals at FM and DAB frequencies.
warenbe
Sat Oct 12, 2019 7:45 pm
You mean interferences going to the cable ?
in my case both site are domestic area, without strong interferences
on site B, the LHG don't advertise 1Gbps, that's strange.
Cable on both site are not from the same manufacturer, so i excluded a problem on both cable at the same time
Cable on site A is 30 meter long
cable on site B is 40 meter long
xvo
Long time Member
Long time Member
Sat Oct 12, 2019 7:56 pm
Stupid question: is interface on Site B configured to advertise 1000M at all (have needed options ticked)?
pe1chl
Sat Oct 12, 2019 8:00 pm
Remember only the AC type LHG can do 1G, the N type is 100 Mbit.
You also have to use the power inserters that come with it, not some leftover type from another device.
warenbe
Sat Oct 12, 2019 8:36 pm
Yes it is ;)
it is the AC version
I use the POE injector shipped with it.
warenbe
Sat Oct 12, 2019 11:16 pm
On site B, if i uncheck then re-check the 1Gbs checkbox, i see in the status that the LHG advertise 1Gpbs. 5 secondes later, it's gone, and i only see 10/100 half/full :(
Edit: resetting device does not help
warenbe
Sun Oct 13, 2019 10:29 am
Tried to downgrad without success.. last this to do is to check both cables...
1 is cat 5e, the other is cat6
if it's the cable, it's really bad luck having 2 new faultly cable :(
Zacharias
Re: Wrong ethernet speed negotiation  [SOLVED]
Sun Oct 13, 2019 1:03 pm
You use gigabit POE injectors? Its the white ones with the green led...
warenbe
Sun Oct 13, 2019 1:30 pm
That's an excellent question...
Just checked... the poe injector has only 4 wires !!
no green led.
this one was shipped with the antennas... does it mean that mikrotik sell gigabit capable antennas with 100Mbps injector ? that's stupid ! i
thank you for finding this...
i'll buy 2 gigabit poe injector.
warenbe
Sun Oct 13, 2019 2:07 pm
ok found why i had 100mbps injector
we bought LHG 2Ghz before, and we replaced it with 5Ghz AC antennas, without replacing the injector...
i found the good gigabit poe injector and installed it on site 1 : now it's giga ;)
i must install it to site B
thanks for finding it Zacharias
Zacharias
Sun Oct 13, 2019 3:41 pm
You are welcome...
pe1chl
Sun Oct 13, 2019 8:34 pm
Wait, I told you that before, in posting #5. But then you said "I use the POE injector shipped with it."...
warenbe
Tue Oct 15, 2019 1:28 am
Yes you're right.
thank you also
as i said i thought the injector were the one provided with the antennas
but you were right.
Users browsing this forum: arnoldmikro and 99 guests
