MUM Europe 2020
davorin
CRS309-1G-8S+IN RouterOS functionality
Sat Oct 12, 2019 10:28 pm
Good evening
As I am thinking of installing 10GB SFP+ cards into one of my hosts at home I looked at the CRS309-1G-8S+IN as it is a fanless design...
From the description it tells me that it can run either RouterOS level 5 or SwitchOS...apparently being choosable on restart...
Could this switch replace my small hEX RB750GR3 router to do the internet IPv4/IPv6 internet connectivity and IPsec tunnels as well?
thanks in advance
richard
sid5632
Re: CRS309-1G-8S+IN RouterOS functionality
Sat Oct 12, 2019 10:52 pm
No. A switch is not a router. Performance would be very poor.
mkx
Sat Oct 12, 2019 10:53 pm
It could ... as well as race horse can replace an ox.
Seriously: you wrote ... CRS is a switch and RB750Gr3 is a router. Don't let be mislead by the fact that CRS can run ROS. Test results on the product pages show that RB750Gr3 is slightly better at routing ... plus it supports HW-accelerated encryption (for IPsec)
BR,
Metod
davorin
Sat Oct 12, 2019 11:00 pm
Ah okay.....
So the best way would be to replace my current hEX RB750GR3, although it is doing a fantastic job up to wire speed,
with the RB4011iGS+RM router and connect it to the switch running SwitchOS for best performance?
Well I can keep than the two RB750GR3 routers as spare and for testing new configurations...
Hmm..can I just copy over the RB750GR3 configuration to the RB4011iGS+RM?
thanks in advance
richard
mkx
Sun Oct 13, 2019 11:41 am
In this case the best would be to keep using RB750Gr3 as router and use CRS309 as switch (personally I'd run ROS on it, in theory OS selection doesn't change functionality nor performance of these units). I'd wait with investment into new router until needs arise.
BR,
Metod
Users browsing this forum: mbovenka and 23 guests
