emils
Winbox v3.20 released!
Tue Oct 15, 2019 2:12 pm
What's new in v3.20:
*) allow to filter by IPv6 addresses and prefixes;
*) build 64-bit Winbox as well (https://mt.lv/FeuQe);
*) do not leave files locked on computer when uploading files to router;
*) fixed problem where some fields were not shown for read only users;
*) fixed Winbox crash when copying multiple files between routers;
*) make Ctrl+A work in script fields and other multiline fields;
*) make DLL hijacking attack not work: Winbox will not look at the directory it resides in, when looking for system DLLs;
*) on update, Winbox will check that code is signed by MikroTik and not somebody else;
*) removed Drag and Drop support on 64-bit Winbox in Wine;
*) show system note at login;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
Instructions on running Winbox 64-bit on MacOS Catalina are available here: viewtopic.php?f=2&t=152795&p=754980#p754824
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
R1CH
Forum Veteran
Forum Veteran
Re: Winbox v3.20 released!
Wed Oct 16, 2019 12:27 am
Unfortunately this check still seems insecure.
jonmansey
Wed Oct 16, 2019 1:57 am
Why?
akin2silver
Wed Oct 16, 2019 3:57 am
Why?
Yeah seems kinda weird. I guess it was breaking some thing?
vecernik87
Forum Veteran
Forum Veteran
Wed Oct 16, 2019 7:19 am
I remember your report ages ago and I always wondered how long till they fix that. I find this unbelievable that update process is vulnerable like that. Well, good to know that it is not yet fixed.
Thanks for report.
Sob
Wed Oct 16, 2019 4:06 pm
Changing the updater to use https instead of current plaintext http would be good and simple first step. It's nice bonus if it also checks new exe's signature, but in first place, it should not allow anyone on the way to intercept requests so easily.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Nevon
Wed Oct 16, 2019 4:12 pm
Will their ever be a workin winbox in cata? Dont feel that Im a fan of this terminal thing..
PEMA Kommunikationer AB
Vårgårda - Sweden
AS207448
normis
Wed Oct 16, 2019 4:15 pm
What is "cata"?
zandhaas
Wed Oct 16, 2019 4:50 pm
Perhaps "MacOS Catalina"
DummyPLUG
Wed Oct 16, 2019 6:04 pm
Interface Link up/down date and time still incorrect, one of the reason I am still using 3.16.
Nevon
Wed Oct 16, 2019 9:51 pm
What is "cata"?
Yes Macos Catalina..
Vårgårda - Sweden
AS207448
Anthemous
Thu Oct 17, 2019 12:16 am
After do Upgade in 3.20 they show the next message and only if I put [ok] allows me to continue, Why ?
Sob
Thu Oct 17, 2019 1:19 am
Make sure you don't have anything in "/system note", because that's what the window is. From screenshot it doesn't look like you have anything there, but even single space would be enough.
florid
Thu Oct 17, 2019 1:15 pm
On macos catalina using wine64 and automation start winbox64.
Seems all normal. hex poe (v6.45.6). cpu is around 1~5%.
But if i go to IP-FIREWALL-Address lists tab, CPU goes up to 54% immediately, then hopping between 25%-57% constantly. Only when i click other tabs, CPU returns normal.
Anyone observes the same?
normis
Thu Oct 17, 2019 3:51 pm
What is "cata"?
Winbox is already working in macOS catalina.
Nevon
Thu Oct 17, 2019 5:02 pm
What is "cata"?
Are you planing to release a real macos app?.. or is this what we have to live with?.. the old winbottler was ok.. maybe I have done somthing wrong.. but its disturbing with the terminal in the background.
Vårgårda - Sweden
AS207448
CoMMyz
Fri Oct 18, 2019 12:48 pm
Making the window full screen in wine64 with winbox64 on macos Catalina breaks winbox - Just drag the edges to full screen if you want this to work.
Also attempting to export/import addresses crashes wine64 with noexec filesystem error and hangs winbox.
Other than the above it seems to be working to an extend - we can live with it until full support is released!
Nevon
Fri Oct 18, 2019 1:14 pm
Drag and drop doesnt work for my.. when I try to upload firmware.. upload button in files doesnt do anything more then hang winbox.
How far aways are we from a real winbox app for macOS? Parallels isnt an option.. to slow to start.. and resourses.
Is their anyway to get rid of terminal when winbox is started from terminal?
Vårgårda - Sweden
AS207448
himvas
Fri Oct 18, 2019 1:48 pm
When start new winbox (either 32bit or 64bit) I get message: "ERROR: Colud not save conffiguration".
If I start with administrative privileges - no such error.
Also without administrative privileges I can't connect to router. And with administrative privileges - without problem
OS - Windows 7 Prof SP1 x64
Panbambaryla
Fri Oct 18, 2019 2:47 pm
Dear Mikrotik,
could you please consider changing application bar/other WinBOX window component colour while in SafeMode? Regardless of information when exiting the app it would help to identify the current mode.
Thanks in advance.
Best regards,
Bam
Best, Bam
Cha0s
Fri Oct 18, 2019 2:52 pm
+1
ErfanDL
Fri Oct 18, 2019 6:43 pm
Why not added dark mode ?
Sent from my SM-A705FN using Tapatalk
sterod
Fri Oct 18, 2019 11:14 pm
Can you give us the ability to resize the columns in the Log window please? Mainly to be able to see full date/time. I've requested this feature many times and it still hasn't happened.
conrad
Sat Oct 19, 2019 12:37 am
I've been asking for this for a year.
Not do.
Although promised year 3 ago do in version of 3.0
In the beta version did, then removed, promised and forgotten.
Sarel0092
Sun Oct 20, 2019 12:33 pm
Keep getting the following error when trying to connect to any router:
"ERROR: no roteros.jg found"
Was working fine on version 3.19.
Routers are on version 6.45.6.
Any ideas of what it could be?
osc86
Sat Oct 26, 2019 11:36 am
when will this finally be fixed?
victorkemp
Trainer
Trainer
Tue Oct 29, 2019 9:23 am
I am getting the same since latest Win 10 update.
I had a student in class last week who was not getting neighbour discovery but we got around this by statically configuring an IP on his Windows machine.
My machine was updated yesterday and since the update I have the same problem you do. My workaround is to use winbox 3.18 (don't have 3.19)
macsrwe
Forum Veteran
Forum Veteran
Thu Oct 31, 2019 1:20 pm
Why?
It rarely worked as it was, I wish it would have been fixed rather than removed. Everything else in the Mac Winbox port worked pretty well except file transfer in and out via drag and drop.
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Thu Oct 31, 2019 2:30 pm
Not a major issue, more of an annoyance, double click does not work under "Neighbors" tab
MTCNA, MTCTCE, MTCRE & MTCINE
normis
Tue Nov 05, 2019 8:45 am
Why?
Upgrading to latest Wine Staging 4.19 will fix these issues, new Winbox 3.21 will have drag/drop and file transfers again.
Anastasia
Tue Nov 05, 2019 5:14 pm
1) Does the program Winbox use encryption to connect to hardware device?
2) Сan I use Winbox without fear in adverse networks?
3) Is there any protection in the connection from the Man in the middle (MITM) attack?
macsrwe
Forum Veteran
Forum Veteran
Tue Nov 05, 2019 8:50 pm
Why?
Great news. I'm unfamiliar with the term "Wine Staging." Are you talking about the pre-cooked Mac Winbox that is (or was once) available from the MikroTik website Software page, or am I going to have to learn how to roll my own (which I've tried before and never got to work)?
karlisi
Wed Nov 06, 2019 8:11 am
From Winbox v3.14, the following security features are used:
Winbox.exe is signed with an Extended Validation certificate, issued by SIA Mikrotīkls (MikroTik).
WinBox uses ECSRP for key exchange and authentication (requires new winbox version).
Both sides verify that other side knows password (no man in the middle attack is possible).
Winbox in RoMON mode requires that agent is the latest version to be able to connect to latest version routers.
Winbox uses AES128-CBC-SHA as encryption algorithm (requires winbox version 3.14 or above).
https://wiki.mikrotik.com/wiki/Manual:Winbox#Summary
Karlis
normis
Thu Nov 14, 2019 8:38 am
I am referring to the official Wine download page, "Staging" is the latest and most updated release, as opposed to Stable: https://dl.winehq.org/wine-builds/macosx/download.html
Yes, but since this is an administration tool, under no circumstances should you be leaving the management port open to the world. Always initiate an IPsec session before administering your devices.
mariogrip
Fri Nov 22, 2019 4:43 pm
Still no native Linux client :(
SiB
Wed Dec 04, 2019 9:57 pm
Please fix fonts, my ASCII Art not work :(
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back :) Hello again.
normis
Thu Dec 05, 2019 1:02 pm
Note is orginally made for notes, not for art :)
SiB
Thu Dec 05, 2019 2:52 pm
Beep is originally made for Beeps, not for play a "Star Wars -- The Imperial March" or "A_Bit_of_Sounds"
Future Suggestion: Please fix font or give us option in WinBox to not display this "Note PopUp/SplashScreen" and we will be happy with Ascii Art at terminal :). Thanks!.
rushlife
Sat Dec 07, 2019 5:08 pm
+ 1
macsrwe
Forum Veteran
Forum Veteran
Sun Dec 08, 2019 1:48 am
I suspect this was in response to a perceived legal issue, to ensure that any login note is immediately presented to and acknowledged by any breacher using Winbox.
Chaosphere64
Sat Jan 11, 2020 9:39 am
LMAO :lol:
Made my day, thanks a lot!
sterod
Tue Jan 21, 2020 3:46 pm
I tried this new version (3.20 x64) and it crashes on any host I try to connect to in the "downloading descriptors" phase. I tried clearing the cache, moving the sessions folder, nothing has helped. 3.19 does not do this. Any idea as to why this is happening?
emils
Thu Feb 06, 2020 3:23 pm
Winbox v3.21 has been released:
viewtopic.php?f=21&t=157150
Users browsing this forum: No registered users and 9 guests
