penguinpages
DHCP Service - Logs and Debug
Thu Oct 31, 2019 2:01 pm
Trying to convert DHCP services from wifi router to my new MikroTik router.
I have defined two zones, with zone options. One on each VLAN
Test VLAN is 101. And I swear it worked for a while, now it stopped responding. Trying to figure out where I can get logs from on router side to find what is going on. I know the VM is on the VLAN L2 as I can ping when set to static IP and arp table shows on local broadcast domain. DHCP client times out due to lack of response from "server".
Questions:
1) Where is logs from switch that I can check service started and response to client request
2) I assume with each VLAN being bound with IP (for routing) I assume no relay definition needed as the router interfaces is on that native VLAN.
3 If / when I can purchase second switch, Is there any comments on zone split option to create this kind of service HA
Zacharias
Re: DHCP Service - Logs and Debug
Thu Oct 31, 2019 4:23 pm
Go to system logging and select debug, DHCP...
Then you will get debug information in your log for the DHCP...
msb1
Fri Sep 16, 2022 5:39 pm
defconf offering lease 192.168.0.100 for F0:03:8C:AF:6F:DF without success
This is the entry pertaining to the printer. I had the printer set to dhcp.
I guess it's offering a lease and the printer isn't taking it for some reason.
Users browsing this forum: Kanzler, tangent and 58 guests
