MUM Europe 2020
ma3xDFS
OVNP Connection reset, restarting [0] - Client stays on Connecting
Sat Nov 02, 2019 6:16 pm
Hello everyone,
Strange policy for new comers you have here. Straight to the topic, as this is the 2nd time I am posting the same information.
I am trying to configure the VPN of RB962UiGS-5HacT2HnT w/ RouterOS v6.45.7.
Below is the CLIENT.OVPN file:
client
dev tun
proto tcp-client
remote WAN_IP 1194
resolv-retry infinite
nobind
persist-key
persist-tun
;mute-replay-warnings
ca ca.crt
cert client.crt
key client.key
tls-client
remote-cert-tls server
cipher AES-256-CBC
;comp-lzo
verb 5
;mute 20
auth SHA1
--auth-user-pass secret.txt
auth-nocache
;redirect-gateway autolocal
;route 10.0.0.0 255.255.255.0
;route 192.168.88.0 255.255.255.0
Upon trying to establish connection between the Client and the Server, everything works as it is supposed except for the TCP/UDP reset connection in the very end :
OpenVPN 2.4.7 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 25 2019
Windows version 6.2 (Windows 8 or greater) 64bit
library versions: OpenSSL 1.1.0j  20 Nov 2018, LZO 2.10
Enter Management Password:
MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Need hold release from management interface, waiting...
MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
MANAGEMENT: CMD 'state on'
MANAGEMENT: CMD 'log all on'
MANAGEMENT: CMD 'echo all on'
MANAGEMENT: CMD 'bytecount 5'
MANAGEMENT: CMD 'hold off'
MANAGEMENT: CMD 'hold release'
MANAGEMENT: CMD 'password [...]'
Control Channel MTU parms [ L:1623 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Data Channel MTU parms [ L:1623 D:1450 EF:123 EB:406 ET:0 EL:3 ]
Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_CLIENT,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1559,tun-mtu 1500,proto TCPv4_SERVER,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
TCP/UDP: Preserving recently used remote address: [AF_INET]{WAN_IP}:1194
Socket Buffers: R=[65536->65536] S=[65536->65536]
Attempting to establish TCP connection with [AF_INET]{WAN_IP}:1194 [nonblock]
MANAGEMENT: >STATE:1572709927,TCP_CONNECT,,,,,,
TCP connection established with [AF_INET]{WAN_IP}:1194
TCP_CLIENT link local: (not bound)
TCP_CLIENT link remote: [AF_INET]{WAN_IP}:1194
MANAGEMENT: >STATE:1572709928,WAIT,,,,,,
MANAGEMENT: >STATE:1572709928,AUTH,,,,,,
TLS: Initial packet from [AF_INET]{WAN_IP}:1194, sid=1eaf9cba 73416e2e
VERIFY OK: depth=1, C=US, ST=New York, L=New York, O=Ltd., OU=SecDef, CN=CA
VERIFY KU OK
Validating certificate extended key usage
++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
VERIFY EKU OK
VERIFY OK: depth=0, C=US, ST=New York, L=New York, O=Ltd., OU=SecDef, CN=VPN
TCP/UDP: Closing socket
SIGUSR1[soft,connection-reset] received, process restarting
MANAGEMENT: >STATE:1572709929,RECONNECTING,connection-reset,,,,,
Restart pause, 5 second(s)
Re-using SSL/TLS context
MANAGEMENT: >STATE:1572709934,TCP_CONNECT,,,,,,
MANAGEMENT: >STATE:1572709935,WAIT,,,,,,
MANAGEMENT: >STATE:1572709935,AUTH,,,,,,
TLS: Initial packet from [AF_INET]{WAN_IP}:1194, sid=0c5bded4 ec5a841b
VERIFY KU OK
VERIFY EKU OK
MANAGEMENT: >STATE:1572709937,RECONNECTING,connection-reset,,,,,
SIGTERM[hard,init_instance] received, process exiting
MANAGEMENT: >STATE:1572709941,EXITING,init_instance,,,,,
WRWRWRRWRWRWRWRRWRWRWRWRRWRWRWRWRRWR
The configuration files comes from OpenVPN running previously on a Windows Server. I am not sure where the restrictions come from that's why I am submitting this. I have followed an YouTube video in order to properly configure the Mikrotik device (won't share the URL now as I suppose this was the reason I had my 1st post not confirmed by the Moderators team).
BR,
T.
wfalcon
Re: OVNP Connection reset, restarting [0] - Client stays on Connecting
Mon Nov 04, 2019 11:57 am
this should definitely help
ma3xDFS
Mon Nov 04, 2019 6:15 pm
Well, checked the URL you have left me. Thank you. Did not see anything different in the configuration files I have and what the others were discussing.
This is the Terminal output when I logged in:
ovpn,debug,error,,,,,,,,,l2tp,info,,debug,,,critical,,,,,,,,,,,,,warning duplicate packet, dropping
What was offered when I have tried searching for in here is inapplicable - tried it already as the first time I have tried running the OVPN on the Mikrotik I have had all certificates and configuration files imported. The above was the client's console error I received back then and now. Then started over and ended up here discussing the misconfiguration, as it is obviously misconfigured.
BR,
T.
Users browsing this forum: ajem22, pme and 61 guests
