toxie
APC Smart-UPS 620
Mon Apr 23, 2007 10:33 pm
Hi, i`m having a problem with this ups.Every time when I simulate the power failure, the router stops responding, when i plug back the ups to power network the router restarts itself.Settings are :
Port: serial0
Off Line Time : never
Min Run Time : 00:03:00
Alarm Setting : Immediate
Is it possible because on the status tab the Replace Battery is lit?
I`ve used a cable for that UPS, and i`ve made a cable like in Mikrotik manual.It has the same simptoms.
firebat
Tue Apr 24, 2007 1:05 am
Is the battery dead and thus when you unplug it, there is no battery to power the router?
toxie
Tue Apr 24, 2007 12:34 pm
The battery is holding the power on 3 pc`s for 4-5 minutes.I can`t figure out why the router restarts itself when i replug the ups.
firebat
Tue Apr 24, 2007 7:49 pm
It not plugged into one of the outlets that is surge protected only and not battery backed up? There are both on the unit. If you plug something else in like a small light, does it blink when you pull power?
toxie
Tue Apr 24, 2007 10:58 pm
It came to misunderstood.The pc connected with cable to ups restarts, the other ones which are connected to ups are working properly.That restart thing is becomming very annoying to me.When i remove the serial cable everything is ok, even if i pull out the UPS from AC.
firebat
Tue Apr 24, 2007 11:27 pm
Oh OK. So if you disconnect the serial cable between the UPS and the the PC running Router OS, it doesnt reboot.
Hopefully Mikrotik will pop in to provide some light.
I have always used mangement cards in the smartUPSs and manageme them via IP.
toxie
Thu Apr 26, 2007 1:02 am
Exactly.
tgrand
Long time Member
Long time Member
Thu Apr 26, 2007 1:29 pm
You need a proper APC cable.
You can build an adapter yourself.
I have come across pin diagrams in the past off the internet.
Try a search on google or yahoo etc.
Users browsing this forum: No registered users and 135 guests
