Belyivulk
Dude Beta 6 showing diskusage to 8 decimal places
Tue Apr 24, 2007 11:27 pm
Has anyone else seen / fixed this before?
Thanks in advance
firebat
Tue Apr 24, 2007 11:30 pm
Just modify the hdd_usage function. Take the result, multiply by 100, round (will remove to nearest integer) and then divide by 100. This will give you two decimal points. You can multiply/divide by whatever you want to get the resolution desired.
Belyivulk
Tue Apr 24, 2007 11:34 pm
Thanks, Can you please give a working example of that?
firebat
Wed Apr 25, 2007 5:49 am
edit the hdd_usage function. Using the example below, subsitute current_function with the existing code in hdd_usage and save.
(round((current_function)*100))/100
Belyivulk
Wed Apr 25, 2007 6:14 am
This is under probes - hdd?
Belyivulk
Wed Apr 25, 2007 6:36 am
Ok, when i do as you say around this segment of code
(oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.",
array_element(
oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageIndex", 600),
array_find(
oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageType", 600),
"iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTypes.hrStorageFixedDisk"
* 100 /
oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageSize.",
array_element(
array_find(
like so
(round(oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.",
array_element(
array_find(
* 100 /
array_element(
array_find(
)))))*100))/100
it doesnt work, the dude just displays [device_function]
firebat
Wed Apr 25, 2007 8:01 am
IF this is hdd_usage:
array_element(
array_find(
Then replace it with:
(round(((oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.",
array_element(
array_find(
)))) *100))/100
After saving, ensure that the error column is blank and not reporting any issues with the function.
Belyivulk
Wed Apr 25, 2007 8:03 am
i have, see what ive posted above
firebat
Wed Apr 25, 2007 8:12 am
I don't have access to dude at the moment. Is hdd_usage this entire piece:
array_element(
array_find(
* 100 /
array_element(
array_find(
then it would look like: (you are missing parens in yours above)
(round(( (oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.",
array_element(
array_find(
* 100 /
array_element(
array_find(
)))) )*100))/100
Belyivulk
Wed Apr 25, 2007 8:28 am
that doesnt work. it just comes ip with device_performance
firebat
Wed Apr 25, 2007 8:54 am
Does it show an error in the error column for the function?
firebat
Thu Apr 26, 2007 9:55 am
This code works for me:
(round((
array_element(
array_find(
* 100 /
array_element(
array_find(
)*100)/100)
Belyivulk
Thu Apr 26, 2007 10:27 am
That worked a treat, thanks alot! :)
Users browsing this forum: No registered users and 15 guests
