alsinaleandro
Wireless Wire Dish alignment
Wed Nov 20, 2019 6:25 pm
Hi. I have several of Wireless Wire Dish PTP links in my town. I like these devices very much.
One of the links has its signal strength and MCS (on both sides) chaging dynamically with time. Signal strength sometime is 80, then drops to 50, then 60, and so on.., MCS sometimes drop from 8 to 5.
What could be the cause of this¿
The link HAS visual contact, but the Fresnel zone area is not totally clear, the enviroment is a dense urban, and the height / altitude of the antennas is not very generous at all.
Is it absolutely neccessary the dishes to be rock rigid still¿, could a little moving because of wind to disturb the link¿
I aligned these antennas with no proper instrumentation, just checking the signal strength with the quickset in the RouterOs
What is the proper and correct procedure to get the best alignment of these equipments¿
thank you very much in advance.
Zacharias
Re: Wireless Wire Dish alignment
Wed Nov 20, 2019 6:57 pm
Yes and yes.
The signal drop from -80dbm to -50dbm is a huge difference.
So it seems your antenna goes wherever the wind goes... :lol:
Since beamforming is used in the 60GHz models i dont think that this is a real problem.
Also the radiation pattern is :
< 1 degree single pattern and full span 3 degrees over horizontal and 3 degrees vertical plane
The radiation pattern is so narrow...
https://wiki.mikrotik.com/wiki/Manual:Interface/W60G
As the wiki suggests :
LHG60 devices require very precise alignment in order to get best performance in higher distances.
So imagine what can happen if they move because of wind...
alsinaleandro
Fri Nov 22, 2019 2:56 pm
all right, thanks for your useful reply!.
but I still have the question. what is the proper and correct alignment procedure for these dishes? ,
how do i enter the alignment mode?
thanks!
blingblouw
Fri Nov 22, 2019 3:05 pm
interface w60g align numbers=0
alsinaleandro
Fri Nov 22, 2019 3:27 pm
my dishes performance changes with time
alsinaleandro
Fri Nov 22, 2019 3:32 pm
thanks!, what is to be done next? is this described in a manual?
alsinaleandro
Fri Nov 22, 2019 4:53 pm
The manual mentions an "aim tool"
what is this "aim tool"?? how do I enter it? is it in RouterOS?, is it an standalone app?
thanks fellas
Zacharias
Fri Nov 22, 2019 4:59 pm
No its just a tool... :D
alsinaleandro
Fri Nov 22, 2019 5:01 pm
how do I use it?
blingblouw
Fri Nov 22, 2019 5:18 pm
Use your eye. There is a tiny hole
alsinaleandro
Fri Nov 22, 2019 6:48 pm
you guys could have a little more verbiage, or be more talkative. anyways your help was enough for me to figure it all out.
thank you
rabienz
Tue Dec 01, 2020 10:38 am
I am also facing this problem in aligning such dishes because in w60 there is no alignment tool like in 5G and 2.4G
Users browsing this forum: No registered users and 44 guests
