anas94c
Fasttrack Enabled But Nothing
Sat Dec 14, 2019 7:00 am
Hi i have a problem that i have enabed fast track but nothing do just a traffic pass throw the rule but mangel and every thing work
anas94c
Re: Fasttrack Enabled But Nothing
Sat Dec 14, 2019 7:34 am
Fixed the problem after i downgrad to 6.44 my router is ccr 1036
anas94c
Sun Dec 15, 2019 7:47 pm
the problem return again nothing i have changed the problem return again the fastrack roule not working
mkx
Sun Dec 15, 2019 8:07 pm
Post configuration here ... so that we can see what you've got.
anas94c
Mon Dec 16, 2019 6:49 am
there is no configration just a public ip and nat with private ip to customer the problem is the fasttrack work after i restart just for about 5 min and after that it's stopped i must restart to work again
anas94c
Mon Dec 16, 2019 7:40 am
after testing and testing the fasttrack will stop if there is a change in route ?? so if i changed the route it's will stop
