archerious
Is Native VLAN0 or VLAN1? Confused.
Tue Dec 17, 2019 7:26 am
I read posts from 2016 talking about how VLAN0 is native VLAN on say CRS112, and even Mikrotik's wiki says VLAN0 is native vlan/untagged default vlan https://wiki.mikrotik.com/wiki/Manual:C ... s_ports.29 Specifically from wiki on CRS1xx:
Specify the VLAN ID that the switch must set on untagged (VLAN0) traffic for each access port:
This confuses me as default untagged VLAN on my CRS309 is VLAN1. Image
Did Mikrotik change the default VLAN in CRS3xx series? Or did the newer RouterOS? I need to get a concrete answer as I am looking to buy a CRS112 but I need to make sure I don't set untagged vlan as the wrong number (0 or 1).
Thank you!
UDM-Pro Former: RB4011, CCR2004, hEX, ER4
Aruba 2930F, CSS326, CRS309, CRS112-PoE Former: Ubiquiti XG-16 & ES-10X
Wireless Wire
AT&T Fiber 1000/1000
http://tlopez.cc/images/hex_is_a_beast.PNG
http://tlopez.cc/images/ccr2004_speedtest.png
Anumrak
Re: Is Native VLAN0 or VLAN1? Confused.
Tue Dec 17, 2019 2:22 pm
There is no such vlan id in 802.1Q Ethernet standart. So it's just Switch OS interpretation of untagged vlan traffic.
https://en.wikipedia.org/wiki/IEEE_802.1Q
P.S.: "A 12-bit field specifying the VLAN to which the frame belongs. The hexadecimal values of 0x000 and 0xFFF are reserved. All other values may be used as VLAN identifiers, allowing up to 4,094 VLANs. The reserved value 0x000 indicates that the frame does not carry a VLAN ID".
So basicly, vlan 0 should be a frame without 802.1Q header.
mkx
Tue Dec 17, 2019 8:55 pm
Not exactly. Frame with 802.1Q header which is there explicitly because of using other fields - QoS/priority, but without intent of using VLANs, will have field VID set to 0. Which essentially makes it VLAN-untagged frame. Or in ROS language: untaged-or-priority-taged
BR,
Metod
archerious
Wed Dec 18, 2019 7:56 am
In that case why is VLAN1 the default on my RB4011 and CRS309?
Wireless Wire
Anumrak
Wed Dec 18, 2019 12:44 pm
Well yeah, I meant it will be untagged with 802.1Q header. Correction.
Anumrak
Wed Dec 18, 2019 12:47 pm
Because vlan 1 is a default vlan in any switch in a world. There are some layer 2 protocols tha are using vlan 1 to work, even if you'll use some tagged traffic with different vlans. You can use vlan 1 as tagged, untagged or native vlan traffic.
mbovenka
Wed Dec 18, 2019 12:58 pm
There is no zero id in standart.
Not an actual VLAN 0, no. But a dot1q frame header with 0 as the VLAN ID is perfectly valid; it just means a priority-tagged frame without a VLAN ID.
Anumrak
Wed Dec 18, 2019 1:00 pm
It is just will be without vlan id at all with all other fields.
Users browsing this forum: Bing [Bot], YaCy [Bot] and 43 guests
