icko81
GREENBOW and IKEV2 MIKROTIK RSA and PSK setup WIN10
Tue Dec 17, 2019 4:22 pm
HI
since I have been struggling to make ikev2 native certificate import and connection WINDOWS 10 .
I installed this software and is very good alternative
Mi question is does some user have this experience and tried make connection
https://www.thegreenbow.com/vpn_client.html
I got TFS padding not supported when trying to connect
Regards
Icko81
Znevna
Re: GREENBOW and IKEV2 MIKROTIK RSA and PSK setup WIN10
Tue Dec 17, 2019 4:44 pm
1. Why do you open multiple topics for the same issue?
2. Is it RSA or PSK ?!
3. Did you fix your config as I've said at the end of this post here? viewtopic.php?f=2&t=154789#p765247
icko81
Re: GREENBOW and IKEV2 MIKROTIK RSA and PSK setup WIN10 FIXED
Wed Dec 18, 2019 3:29 pm
Hi Znevna
i corect everything but its not the certificate it something in the protocol Invalid Sintax same issue when using Native Client its some bug.
with the GreenBow i get valid certificate but its not compatible witk mikrotik client pass certificate and gets TFs Padding not supported,
Maybe last try use Lets Encrypt i dont know?
Bug for sure :)
regard
FIXED THE ISSUE
viewtopic.php?t=152914
Users browsing this forum: alexsali, erlinden, Google [Bot], ilkogd and 71 guests
