laitounejjar
Help on my project 2WAN-2LAN
Thu Dec 19, 2019 6:19 pm
Hello everyone,
Please i need your help to achieve my project. I want to experiment this idea (see attachment) :
In my LANs, i have two kind of users : lets say STANDARD & PREMIUM who can connect (via hotspot) from LAN1 or LAN2. I want the PREMIUM users go to, WAN2 and the STANDARD user go to WAN1 (ever user user cant use LAN1 or LAN2 to connect).
how can i do it with my RouterOS 5.x (with hotspot and radius on the same machine 127.0.0.1) ?
Thanks.
Zacharias
Re: Help on my project 2WAN-2LAN
Thu Dec 19, 2019 6:42 pm
Generally speaking either by using the mangles facility or Policy routing Rules....
5.x what ? :shock:
laitounejjar
Thu Dec 19, 2019 6:49 pm
Thanks for your reply
I have RouterOS 5.26 (that mean 5.x, i suppose).
Can you give me more details ? please.
Zacharias
Thu Dec 19, 2019 7:00 pm
Why such an old version...
You can google about policy based routing + Mikrotik and you will find some examples...
laitounejjar
Thu Dec 19, 2019 7:26 pm
all examples i found are about loadbalancing or failover
pe1chl
Thu Dec 19, 2019 7:28 pm
Your first task is to update RouterOS to at least 6.44.6 (long-term version)
Then you reset the router to defaults and apply one of the loadbalancing examples found.
Once that works you can start adapting it to your wishes.
ingdaka
Thu Dec 19, 2019 10:23 pm
I think he has 5.26 because is the only one that can be found on internet with "Crack"! He doesn't have a RouterBoard
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
pe1chl
Thu Dec 19, 2019 10:31 pm
Well good luck then!
(sometimes I find it amusing that people try to use a hAP mini as their enterprise core router, but it seems like it can be even worse...)
Users browsing this forum: No registered users and 6 guests
