DotTest37
How to Wireless Repeater (signal booster)?
Thu Dec 26, 2019 7:21 pm
My cable TV provider have hotpots all around the city, I always connect to them with my laptop authenticating via web using an account I have with them.
Sometimes I work in a place where that WiFi signal is very weak, and I wonder if I could use a Mikrotik to amplify it so I can connect to the Internet using my laptop.
I dont need the Mikrotik to be authenticated on the target WIFi, I just need to amplify the signal so I can log in on the same SSID using my laptop, as I normally do when Im close to their Hotspot.
Does anybody has a suggestion on how that can be achieved?
Thanks guys.
UpRunTech
Re: How to Wireless Repeater (signal booster)?
Thu Dec 26, 2019 8:46 pm
What do you mean register? Do you mean with a WPA2 password login or a hotspot style login on an open access point?
DotTest37
Thu Dec 26, 2019 9:03 pm
Hotspot style login, just like a Hospital.
I dont want the Mikrotik to register on the Hotspot, because what I want is to use one or more laptops, and log in from them.
Does that makes sense?
UpRunTech
Thu Dec 26, 2019 9:43 pm
OK well first try this:
* Create a bridge - "Bridge1".
* Set wlan1 in "station pseudobridge" mode and set it to join the desired SSID without a password (security profile mode is 'none').
* Make a slave wlan2 in AP mode with the same SSID and no password.
* Make sure wlan1 and wlan2 are member ports on Bridge1.
I don't know if you will be able to get more than one laptop at a time logged in.
DotTest37
Thu Dec 26, 2019 10:51 pm
I tried that, but the laptop never gets DHCP.
I see the bootpc/bootps traffic on the slave Wifi, and I see it on the Bridge, but I never see it on the master Wireless.
I though the issue was on the bridge, but if I set it for DHCP client it gets an IP from the ISP.
UpRunTech
Thu Dec 26, 2019 11:16 pm
OK scratch and start again trying this:
https://wiki.mikrotik.com/wiki/Manual:I ... s#Repeater
I have never used it - I am wondering if it quietly enables (local)-proxy-arp into the mix.
DotTest37
Fri Dec 27, 2019 2:13 am
[quote=
[/quote]
:-( , those instructions called for a passphrase on the main interface so it connects to the originating AP, or WPS.
I have neither one, authentication is via Web, and I dont have physical access to the originating AP, so no WPS button for me.
Users browsing this forum: bpwl, Google Adsense [Bot], hfree and 41 guests
