drracing07
R11e-LTE6 2CA not staying connected
Sat Jan 11, 2020 5:05 pm
Hi everyone,
I just picked up a R11e-LTE6 to test in place of my Sierra Wireless MC7455 connecting to AT&T in the states. With the MC7455 on router OS v7.0beta4 on a hap ac2, modem in a USB enclosure with 2 yagi antennas, I'm able to get about 40mb/s down and 5-7mb/s up. What I would like is some more insight on the LTE interface page with the MC7455, but that will come in time with support, I hope. In the mean time, I tried the R11e-LTE6 since it/s CAT6 and should support CA like the MC7455. What I'm seeing is that it will connect to either band 12, 17 or 2 primarily, and only sometimes if the primary is band 2, it will show 2CA with band 5 but then drop right back up. Speeds on any of the bands don't compare to how the MC7455 performs and it might be a combination of the low band distance and the high band 2 performance. The MC7455 also has bands 29 and 30, also used by AT&T but I'm not sure of those are coming into play. With the MC7455 connected to the routerboard, I can't get access to the AT commands to check anything, and if I plug it in my laptop, I can get AT commands but for some reason won't connect with data so I'm unable to check speeds. I know the MC7455 connects with CA, even if the screenshot i was able to grab shows inactive.
Some other posts show some issues with CA dropping. Is anyone able to get CA working? Thinking of trying a Telit LM940 too.
I should add that I'm experiencing the same thing with stable and testing releases of router OS
SiB
Re: R11e-LTE6 2CA not staying connected
Sat Jan 11, 2020 9:53 pm
drracing07
You not use a vendor documentation or search in this forum - this was write many times.
R11e-LTE6 not use B29 or B30. Maybe you should wait for lr11e-LTE6-US|4G version with better Band selection for you.
https://i.mt.lv/cdn/rb_files/R11e-LTE6-1575025885.pdf
Band's what you say and answer why B2 as primary can have other ca-band.
Please use a CellLock into your B2 or B5 and then check ca-band.
I use a realease candidate v22 of modem firmware but in official v20 I had the same issue that ca-band can never connect if I use "few disable/enable lte1" or "few at*cell= command" but always after at+reset or usb power-reset or reboot the ca-band work wary well if I have a good signal (in my case).
ca-band works, can work stable with good signal.
I have B3+B8 works 24/7
If you have this possibility plese:
  • give a model of your usb wwan adapter
  • do in table the comparison of Band/Speed/rsrp on both modem with this 2xYAGI antenas.
  • The same but without external antenas give us a amplification per band of your YAGI.
MTCNA + MTCRE + MTCINE | ~800 users at ~150 RouterBoards in EMEA
Knowledge Base about LTE by SiB | Buy me a caffe | Telegram: http://t.me/SiB_PL
tommy91
Sat Jan 11, 2020 10:52 pm
Thanks a lot for answering. I was also facing the same problem now I get solution.
Acryli
Sun Jan 12, 2020 7:48 am
That's actually the normal behavior of any LTE modem.
The carrier aggregation channels are only used on heavy load, after that the CA bands are released.
Check the status with AT-commands while you download a huge file.
mkx
Sun Jan 12, 2020 11:57 am
I've described briefly how CA works in another thread.
BR,
Metod
SiB
Sun Jan 12, 2020 2:02 pm
I can add even info from one of answers MikroTik Support Team about 2xCA
Artis M.03/01/20 16:21:46
Modem should follow handshake/commands from eNB (base station), so we can't write firmware that permanently enables CA. For instance in Latvia, major cellular providers have a different view for CA, one activates CA at connection, and keeps it active for some time, even without significant traffic, other enables CA only when it is needed. By the way second even offers as service TV reception using Andriod/iOS app using its cellular network (same content as DVB-T).
Best regards,
and my ISP in Poland (Cyfrowy Polsat) give me a ca-band to non-stop even if I don't any traffic at lte1.
Other ISP (Play) must have at least 10MB/10minuts from my testing to not disconnect me ca-band.
All this is dependence of YOUR ISP, not your modem feature.
About R11e-LTE6 I give you a hint in AT commands.
Do a loop every 1s with: "at+eemginfo\?" and in separately terminal thise one command /log print follow-only where message~"EEMLTEINTER:|EEMLTEINTRA:" to see that send you a your eNB with what parameters because answers are in syntax "x,phy-cellid,earfcn,~rsrp,~rsrq".
drracing07
Mon Jan 13, 2020 10:40 pm
Thanks for all the replies.
I am aware that B29 and 30 aren't on this modem. Unsure if the MC7455 was locking to them or not.
I wasn't aware that CA wouldn't always stay up, so that's good to know. With the LTE6 modem, even if I ran a speedtest or large download, it wouldn't connect CA.
Is a US version of the R11e-LTE6 coming out? Wasn't aware of that or I would have waited for that. Is there a way to get r22 firmware for this one? I'd like to try it out.
SiB
Tue Jan 14, 2020 1:02 am
drracing07
Try "at+reset" / usb power-reset / reboot.
Be sure that set band="" means auto-selection is set to LTE6 who can connect to one of any of them and try assign the ca-band.
You can reach 2+5 or 2+12 or 2+17 means the CellLock on 2 or 12 or 17 is good way to check
In separe post the MikroTik team say they plan create new version but I think we must wait for MUM Prague to anonce the new info about new hardware. But for sure someting will be in future.
Check the firmware because my version is release candidate and I share with support all my feedback and wait for news as you. You can send e-mail to support@mikrotik.com about this. For me the RC version of firmware should be shared with beta version of ROS.
Ferrograph
Tue Oct 06, 2020 1:33 pm
Im facing a similar issue, and I think that the one of the receivers in the r11e-LTE6 gets in a state where it stops functioning and you end up with no CA/single band operation until you at+reset.
Heres what I observe happening (I sent all this to MT support along with logs and they (Emils T) fobbed me off saying it was parameters from the cell):
# After boot or AT+RESET it connects CA with B3+B20 and cell monitors shows B3+B20 cells. Speeds are great.
# After a time (varies from few mins to hours) it drops the connection and reconnects on B20 only (the slow cell) and speeds are poor. Weirdly at this point cell monitor only shows B20 cells.
# I issue AT+RESET and CA is instantly back and cell monitor shows both bands again.
Why would cell-monitor be affected by the connection parameters and only see cells what the connected cell wants it to see - or even if what MT support are saying makes sense. This has been a really frustrating experience and its spoiling an otherwise good product. I'm at my whit's end with it.
Cell monitor with CA (these are good signals right?)
[admin@MikroTik-LTE] > interface lte cell-monitor
number: 0
PHY-CELLID BAND  PSC EAR..          RSRP          RSRQ          RSSI         SINR          RSCP
       171 B3         1392         -91dBm       -19.5dB
       387 B20       6175         -78dBm        -9.5dB
-- [Q quit|D dump|C-z pause]
Cell monitor after drop:
number: 0
         14 B20       6175         -95dBm       -15.5dB
       387 B20       6175         -79dBm       -11.5dB
Help.
SiB
Tue Oct 06, 2020 1:52 pm
I special for that problems buy LDFR with LTE6 to not drive again and again to BTS to receive good signals.
I just report the same problems with other user who can do CellLock to the same eNB at Bands 3/1/7/20 and should receive aggregations like 3+7 / 3+20 / 1+20 / 7+20 in ISP:Orange.
ROSv6 give him stable few days connections but ROSv7 give him breake in every 4|5h .
I have Orange sim card too and will start that testing to check what's in game bcs many ppl ask me about not working 2CA in R11e-LTE6 and I have confirmation is some not right here.
PS. You can do a
* enable only band=3,20
* do CellLock at B3 by: /interface lte at-chat lte1 input="at*cell=2,3,,1392,171"
About cellmonitor, it's greate tool but he report that what module see, means:
* he not show current connection details bcs he show neighbour as his nature
* he show neighbour only from that band or ca who are current connected (even if you active other bands who are not connected then you not show theyr details until you not connect to that band)
* good that he show us other towers from the band he connect and/or connected CA - this is greate.
Please report the eNB bcs not every tower have all bands :( and to receive great speed we nead good SINR(CQI)
Ferrograph
Tue Oct 06, 2020 10:45 pm
I've tried enabling just band 3 as this is the primary band when CA works but the modem still drops CA but remains connected to just B3 instead of dropping to B20.
I also tried enabling just B3 & B20 but same result. Drops CA and drops to B20.
I wish MT would take this issue seriously.
Ferrograph
Wed Oct 07, 2020 12:15 am
I applied the cell-lock as suggested. Ive not tried this yet so thanks for putting the exact string needed. I will report back results.
Thanks SiB
SiB
Re: R11e-LTE6 2CA not staying connected  [SOLVED]
Wed Oct 07, 2020 12:47 am
Then I have please to help me with proper diagnostic and report that to MikroTik as "additional case" - you will be 3rd with "proof".
  • Diagnostic:
Enable logging of LTE, regular logs.
/system logging action add name=support target=memory memory-lines=16384
/system logging remove [find where topics~"lte"]
/system logging add action=support topics=lte
Upload a lteLogger2.rsc to your ros and do /import lteLogger2.rsc;
You see new scheduler&script items what are software watchdog for script lteLogger2 - it keeps that script is still running.
  • RouterOS v6
    ros6-lteLogger2.rsc
  • RouterOS v7
    ros7-lteLogger2.rsc
Installation of that file is by copy that file to RB and in terminal:
/import filename.rsc
Watch your logs, detect problems like swape/hop/switch/replace eNB/phy-cellid/primary or ca band... to other one... maybe flapping ca in time... maybe every 4 or 5h... logs like this example:
That give you better perspective to see if something is change or not with LTE general.
Now we will discuss about your case. But this checking must be with time.
I will tested other firmware 024, 025, 026 with r11e-lte6 on LDFR in this near week time and good if you check your side, that what you can.
  • What we do a testing
Main example is one. If you can connect to the same Tower, eNB with few bands, and that bands "should" aggregate then we have 50% of confirmation on our site.
When other (not R11e-LTE6) module can aggregate that bands then we have like 100% of sure that it should at lte6 be 2CA too.
You should set band 3, connect and report connected EARFCN and PHY-CELLID.
Do a CellMonitor and report others earfcn&pci. ROS in testing and development branch have a new parameter "max-age=2m" for cell-monitor.
I have that 43 possibility at sxtr and 5 are connected, yes, I do the 44 Cell Locks. I record in excel the eNB with 3x speedtest.net/run .
Now I know the best eNB and in future I repeat that all test to found other bands from that eNB.
Correct the position of SXTR to one of the best results thanks to Cell Lock at this earfcn&pci and a MikroTik App, now I have better SINR what give me +20Mb...
When I do that for other Bands like B1/7/20 then magic of Excel show me all Bands earfcn&pci of that eNB.
When I can do Cell Lock to all of them - this is proof you could connect to them.
At his level we not have more diagnostic like watch a SIB messages in LTE between eNB and our module and we not know what they negotiate.. and our role end-s here.
  • Report
When we have confirmation etc. then please use https://help.mikrotik.com/servicedesk to create case with MikroTik Support Team and share case with me as info@sibex.it. Thanks.
SiB
Wed Oct 07, 2020 1:11 am
Ferrograph
I applied the cell-lock as suggested by placing it in modem-init. Ive not tried this yet so thanks for putting the exact string needed. I will report back results.
At https://wiki.mikrotik.com/wiki/Manual:Interface/LTE we have that info about Cell Lock @ r11e-lte6:
For R11e-LTE6 modem cell lock information will not be lost after reboot or modem reset. To remove cell lock use at-chat command:
/interface lte at-chat lte1 input="AT*Cell=0"
Please not use that in modem-info feature!.
modem-init better is not to be used, bcs we have reported problems after reboot when first initialisation of lte was done... .
modem-init should be with only part like "at*cell=1,3,,1392" means only directly at command without that ros CLI part /interface lte ...
Here is a Frequency Lock to your Band 3 at example.
You can create a separate scripts for lock/activate proper Band instead of using the band=3 bcs FreqLock is done in ~10sek and set cmd in ~1m :) Litle trick to select band in fast way.
This not block 2CA who can still be connected and should be of course if your Tower have INTRA or INTER earfcn.
Ferrograph
Wed Oct 07, 2020 1:40 am
Thanks SiB - I realised not long after that modem-init was bad place to use cell-lock so I removed with at*cell=0, did a reset and then issue cell-lock with terminal once.
It is connected now with CA so I will monitor to see if it stays. I should know by the morning.
SiB
Wed Oct 07, 2020 2:12 am
Ferrograph
Use lteLogger2 - this is perfect to track parameters who you see at Cellular tab of lte1.
Best Regards, Good connection :).
Ferrograph
Wed Oct 07, 2020 1:00 pm
Sadly it didnt stay up long on the B3 band and dropped after a few minutes. But with the cell-lock in place it didn't reconnect to even the B20 band, I had to get the customer to issue AT*Cell=0.
This adds weight to my theory about the 2nd receiver crashing, and it would seem to be that in r11e-LTE6 bands are divided up between two receivers, hence the limited list of CA workable band combinations. This would explain a lot of the behaviour that is being reported about r11e-LTE6.
  • Dropping CA
  • Cell-Monitor only shows bands of the working receiver
  • Not all cell-tower-possible CA band combinations workable with r11e-LTE6
I have now installed the lteLogger2 script (SiB's) so will check back in few hours to see what is reported.
Its a shame theres no way to get to internal logs of the r11e-LTE6 to see why 2nd receiver stops functioning.
Thanks SiB!
SiB
Wed Oct 07, 2020 1:17 pm
I do one mistake.
Script what I share have a main cmd works at ros7 :(, for ros6 one word must be change.
I upload a two scripts in original post, you can download and import proper one - he remove and add new scheduler & script.
Change is here:
RouterOS v6
:do {:set lteInfo [/interface lte info lte1 once as-value]} on-error={}
RouterOS v7
:do {:set lteInfo [/interface lte monitor lte1 once as-value]} on-error={}
even you replace that one word, or import new rsc then still you must do:
/system script job remove [find script=lteLogger2]
and a scheduler in 1m time run the new one script.
Ferrograph
Wed Oct 07, 2020 7:29 pm
Thanks SiB for the update. I updated the script and killed it from the jobs tab. Then reran the script.
There is data now in the lte log. Should I clear the log and collect data with the fixed script?
Ferrograph
Thu Oct 08, 2020 1:54 am
The CA was dropped and the following entries were logged...
Unless I'm misreading the B3 connection was lost (the reason isnt not clear) and it connected to the B20.
SiB
Thu Oct 08, 2020 1:55 am
no, you can just create a Point-Of-Time log to see from where you have fixed it. Example:
/log warning "************************************************ NO LOGS, NO FUN *********************************************************************"
:) Be happy :)
SiB
Thu Oct 08, 2020 2:10 am
We not have internal logs... and reason of that behavior... you have a separate "lte" logs and probably here can be some clue.
About that change:
* good, the eNB is still the same = the same eNB give you B3 & B20 with the most strong signal.
* You could do a CellLock to that B3 by
/interface lte at-chat lte1 input="2,3,,1392,92"
to lock earfcn=1392 & pci=92 what give you no option to hop to other one cells.
Minus:
* without a proper rescue scripts you can reach some offline per x minutes and a auto rescue cmd should be used, I like that my way:
Advance watchdog: viewtopic.php?f=9&t=151492&hilit=watchdog#p768392
* r11e-LTE6 have a unconfirmed error with stuck offline when the CellLock is setup, I have that at my unit and thats why I buy ldfr+lte6 to confirm that in all Poland ISP... check is the RSRP not go frezz = -140... and ca is leave
Plus: CellLock give you a constance connection with the same cell... when I have good signal then it's work by days as session-uptime.
Ferrograph
Thu Oct 08, 2020 2:15 am
Here is the lte log:
Ferrograph
Thu Oct 08, 2020 2:17 am
Regarding cell-lock I did try this and it ended up offline as described above and I had to talk customer through removing it. So yes I have experienced the cell-lock issue resulting in system being offline.
SiB
Thu Oct 08, 2020 3:00 am
This is strange.
LAC - your region should be the same, or maybe you have some roaming.... or change SIM slot... ?
0e13 hex -> 3 603 dec
1c4c hex -> 7 244 dec
This is very strange, this should be the same LAC/TAC - your region.
Probably every Band have other LAC... bcs other cmd have ending "05c"hex=92dec phy-cell-id and next one for B20...
next params are CurrentCellID
001ee402 hex -> 2 024 450 dec CurrentCellID who /256 give 7 908 eNB/Tower
001ee408 hex -> 2 024 456 dec CurrentCellID who /256 give 7 908 eNB/Tower - the same Tower from the same ISP
additionally
001ee4 hex -> 7 908 dec - without last two digit you have a eNB in hex
last two digits 02 and 08 are a SectorID.
Summary - this not give us any hint.
Ferrograph
Thu Oct 08, 2020 3:47 am
The device is LHG-LTE6 and way out of reach so SIM cant be changed. Operator is Three UK, roaming is not enabled.
What more can be done? Its al very weird, what do you think of my theory that one of the modems receivers is becoming non functional?
SiB
Fri Mar 26, 2021 2:57 pm
@Ferrograph - so sorry, I not see your answer and I not Give additional help.
What is your current status with latest 027 firmware, problem is still exist ?
You use one of a watchdog to monitor&fix that problem by scripting ?
Similar cases are: Chateau LTE12 - dropping LTE interface/connection - MikroTik and LTE operator problem? - I think all are about the same case with 027.
Ferrograph
Fri Mar 26, 2021 3:17 pm
@SiB I did get Mikrotik support looking at this and made remote access available, but unfortunately they weren't able to debug it because when the connection dropped they lost their debug connection. I was going to setup an additional connection so they could debug but then covid lockdown meant I couldn't return. Maybe I can soon.
The site reports that things have settled somewhat with fewer drops but the problem does still exist. Additionally I saw the drops to single band when workable bands were available on another site with SXT-LTE6. Same situation cell monitor shows only one band when I know there are two suitable for 2CA.
I did install the script but the owner of the gear was already on instruction how to reset the card and so I wanted to know how often it was happening, which at the time was every few hours. Now its every few days so maybe the operator made a change that prevents the circumstances that cause the crash happening.
LukasBre
Fri Apr 09, 2021 11:29 am
@SiB and all.
Hi, I recently joined the forum. But the problems with LHGG I have equally serious. This device I have connected to Hap ac3, configured by IT guy. Unfortunately, the transmission parameters (PLAY) are hopeless. Previously I had a Huawei B818, which max gave in aggregation of three bands of 150 Mbs, but encouraged to switch to reliable professional equipment MIkroTik I was convinced to take turns. When LHGG works (after logging into the network – from getting a public IP to an Internet connection can pass to no availy even an hour ...) the max speed is 70 (which is not bad).
After a while – it can be a day or 30 minutes after lhgg synchronization disconnects (ca band falls out) or loses bandwidth up to 0.5 Mbs.
After the LTE reboot, the modem is sequenced:
- connects to CAT2 - B20 as main B3 as CA, immediately (after 2 disconnects, only B20 is left and waits for CA
-How well it goes ca joins and the Internet appears -) takes with 10 min.
Today, after 1h after the LTE reboot, there was no connection to the network.
Sometimes reboot helps, and sometimes turning off the 3G band
Is this a problem with this model?
What to do about it?
Ferrograph
Sun Jun 20, 2021 1:16 pm
What you describe is my experience too. There's definitely some issues with the product - either the internal cell card or main firmware.
It's a shame because when it works, it works very very well.
I'm still having issues even on v27 cell card firmware exactly like you describe and mikrotik support were going to debug it on my site but I need to somehow get a second connection up there which has not been easy but your comment reminds me to do this!
russelld
Sun Jun 20, 2021 6:41 pm
I had significant issues after upgrading to V27 of the LTE6 modem firmware - making my device pretty much unusable.
(That was even with a single channel, it became even more unreliable after negotiating a 2CA connection)
After contacting support, I was provided with V28 firmware which restored the reliability and speed I enjoyed before V27 was made available....
Not sure if it was a pre-release of V28, but V27 was unusable in the UK on the networks it had previously been fine with...
R
Ferrograph
Mon Jun 21, 2021 12:32 am
russelld Are you able to make v28 available to me?
vanille
Fri Jun 25, 2021 1:56 am
I am very very disappointed with such LTE 6 modem.
I can not understand why any crappy Huawey or ZTE provided almost for free by local TelCo performs far better than these MikroTIk
I can forget for a moment perfomances and look at stability: it is a nightmare
useruser1212
Tue Aug 10, 2021 11:07 am
Have you gotten the v28 ? I would need it as well. It seems this problem is pretty common and its absolutely unacceptable that it not has been fixed. I am starting to get disappointed at mikrotik. I have wrote to support 7 days ago and still no answer.
useruser1212
Tue Aug 10, 2021 11:22 am
I bough mikrotik rather then any ISP provided modem that i would have gotten it cheaply specifically because i believed it would perform better then them or at least in the same level. But its not as it seems, especially with performance and stability. Perhaps it will be fixed and will perform well. As i don't see a reason in terms of hardware on how it could under perform.
stevewales
Sun Aug 15, 2021 10:46 am
Hi all
I have similar problems. This post indicates as SOLVED?
What is the solution?
thanks
Ferrograph
Fri Oct 22, 2021 7:02 pm
October now and still this issue isnt resolved.
Mikrotik have been doing some diagnostics remotely on one site that was getting CA but now does not get CA at all and this has been the case for months now. Ive also got a dish setup at the office to do some tests pointing at a tower with bands 1,3,20. Same - no CA. At one point we had v29 firmware in the card.
I see odd behaviour in cell-monitor. If I specify one of bands 1,3 or 20 individually with the checkboxes, in cell monitor I will only see that band, although sometimes I see nothing. When I have all bands enabled I only ever see the band currently connected.
I also spoke to cell provider at length because MT support suggested it was the tower. Provider said there are no issues with the tower.
Ive also seen passthru stops working and traffic grind to a halt. lte interface shows solid connection (RSSI -47db) but no traffic.
Ready to give up on Mikrotik LTE solutions, but I don't see anyone else that has anything similar to the LHG.
Ferrograph
Fri Oct 22, 2021 7:35 pm
I just decided to try a couple of test at the office setup to confirm suspicions that R11e-LTE6 is the problem so I checked which cell tower it was connecting to and it was the expected tower locally with bands 1,3 & 20. A speed test shows 5Mbps download.
I put the sim card in my phone and checked with cell mapper that my phone was connecting to the same tower (eNB 13364) and I noticed straight away that phone says 4G+, did a speed test and got 70+MBps.
This isnt a new story. Ive read here and in other forums of similar experiences. What more proof do we need that this product isnt fit for purpose? Its very frustrating that MT are blaming towers when clearly something is wrong with the card.
etm7469
Fri Oct 22, 2021 8:57 pm
I confirm what you say. For me, R11-LTE6 "pulls out" 30-40 MB, and the old HUAWEI B525 connected to the same antennas 60-90 MB. It is a pity the money spent on the R11-gadget.
Users browsing this forum: No registered users and 6 guests
