MUM Europe 2020
MMorris
Wireless With low bandwith
Sun May 06, 2007 7:49 pm
I have a 10 mile link and can only get 4.2 mbps Rx and 4.2 mbps Tx. i have tryed 5 GHZ turbo and nothing has changed.
dose anyone have any sugestions?
janisk
Mon May 07, 2007 10:01 am
there are many threads in this forum that would be helpful for you,
to list some: low signal level, high noise, bad cabling, bad antenna, broken wireless card etc.
arions
Re: Wireless With low bandwith
Sat Jun 02, 2007 3:51 pm
what kind of hardware do you use ?
MMorris
Wed Jun 27, 2007 11:29 pm
I am using routerboard 500 with cm9 cards.
normis
Thu Jun 28, 2007 9:22 am
check cables and connectors
make sure cable is not longer than 2-3 meters
check antenna polarization and align it properly
make sure there is clear line of sight (visibility)
change frequencies / check for interference
check pigtails, are they are attached to correct connectors
check if height of the endpoints is enough
also how did you test it?
MMorris
Sat Aug 25, 2007 4:28 am
I am able to get 20 mbps with OSPF routing full duplex wireless! now my issue is the processor is at 100% so i think that is my limitation at this point.
uldis
Mon Aug 27, 2007 9:21 am
how fast are you routers, are they Routerboards? You can also make the support output file and send it to support@mikotik.com to check if that 100% is due to the limitation of the CPU or maybe there ia some other problem (maybe a bug).
MMorris
Tue Aug 28, 2007 12:24 am
I am using Routerboard 532 and i have never done a support output before. how do i do that and is it free to send it to mikrotik?
uldis
Tue Aug 28, 2007 9:33 am
Here are the instructions:
http://www.mikrotik.com/testdocs/ros/2. ... upport.php
MMorris
Tue Aug 28, 2007 10:42 pm
Thanks I will have to try that!
Users browsing this forum: anonem, bpwl, eworm, keithy and 48 guests
