lukix
RBLHGG-60ad kit - "wrong username or password" after "system reset-configuration"
Tue Jan 14, 2020 10:11 pm
Hi Guys!
I have bought kit RBLHGG-60ad (master and slave device). I have sucessfully paired them and been using short time. (devices already mounted, approx 300m between) After it I have upgraded FW to 6.46.1 (stable). I was doing some config on master side, my config was not OK, so I decied to reset it to start form the scratch.
Everything went good, I have performed reset via mac telnet (I was having some troubles to connect via IP ddress, but was able to sucessfull connect via mac telnet). On "master device" I have perfomed command system reset-configuration. It went OK, but accourding to my suprprise my Mikrotik received 192.168.88.3 instead of 192.168.88.2 that is on the sticker.
(I think 192.168.88.3 = slave and 192.168.88.2 = master). And Iam not able to login to my device anymore. Iam using admin as username and password from the sticker. It is not working. Iam all the time receiving message "wrong username or password"
Tried:
- several version of WinBox (including latest 3.20 64bit)
- user admin, blank password, user admin my previous password
- turn off and on the device form the power source
- login via Winbox, SSH, telnet and web
Any sugestion what can be wrong and why?
Thanks in advance.
oskarsk
Re: RBLHGG-60ad kit - "wrong username or password" after "system reset-configuration"
Wed Jan 15, 2020 12:58 pm
If provided passwords does not work please contact mt support.
garrygarry23
Tue Feb 04, 2020 7:37 pm
Hi Guys!
Tried:
Thanks in advance.
Did you solve the problem? I have same problem too... :-(
Thanks Martin
judec
Fri Feb 07, 2020 7:11 pm
15" dish mikrotik RBLHGG-60ad and installed 2.6.20, these are rated at 1500M. Physical distance between sites is 1157 meters.
We could see both tower locations and the radios with the naked eye and with spotting scopes with no physical obstruction. I had tested these radios on our test bench in the morning and programmed IP addresses (only change from factory config besides password to login to the radios) that would work with our tower connection site A: master 60g 10.x.0.42/29 gateway CCR1036 10.x.0.41/29 and Site B: station 10.x.0.43/29 gateway ccr1009 10.x.0.44/29. Last ditch effort I attempted to do a firmware update 6.46.3 and after the firmware update it sends an error saying wrong user or passcode, I tried both the new password I had programmed and the original factory password with no luck, so now I can’t log into either radio. Please advise. I also downloaded the newest version of winbox to see if that would solve it with no success. I have contacted MK support, and received the auto reply stating that they would contact me within 3 days. Has anyone successfully solved this issue?
qwertyghost
Tue Feb 18, 2020 1:39 pm
I have the same problem, with the "6.46.1" version, no one has managed to solve?
