ceylan
special rule for comminicate between two different subnets
Tue Jan 21, 2020 12:31 pm
-i am trying to give access over winbox for "192.168.1.3" pc. So i want to connect 192.168.100.2/24 SA5 AP only from 192.168.1.3 PC. But whenever i am writing "IP services set winbox address=192.168.1.3" than i can not connect to 192.168.100.2/24 SA5 AP. I removed "available from:192.168.1.3" than connected to 192.168.100.2/24 SA5 AP for checked the logs and i saw "user admin logged in from my real ip1"(my real ip1 netmap to 192.168.1.0/24). SO I DON'T KNOW WHY I CAN NOT CONNECT?!
-we are trying to connect radius manager to run the pppoe-server at different router our radius server ip is 192.168.100.103/24. the router connected to server's ip is 192.168.100.254/24. the problem is if the router ip address that we are trying to run pppoe-server is in different ip adres block(subnet) ex:192.168.102.3 we can not make the connection to radius manager we also give the nas ip and secret but still not connected,we can ping the radius server ip from the different block could not connect as pppoe-server
for these two reasons, I am thinking to need rule for communicate between two different ip block(subnets)!!!
Users browsing this forum: No registered users and 5 guests
