LinusN
wAP LTE and LHG LTE - Very bad LTE performance
Mon Jan 27, 2020 10:27 pm
I must start with saying that I am a big fan of Mikrotik products. I have experience with hAP, wAP, LHG, RB, CRS among other products. I have set up 20 km wireless links with the LHG5, which works flawlessly.
I do however have one issue with some products, and the common problem is the Mikrotik R11... miniPCI cards installed in the LHG LTE and the wAP LTE. I have never managed to gain any kind of performance (stability and speed) with these. If I manage to get any kind of LTE connection, it is slow, unstable and has terrible ping times.
The last time I tried a wAP LTE I failed miserably. I ordered a LHG LTE, but is still worked terribly. Yes, the cellular conditions at that site are not good at all, but a ZTE MF910 mini LTE router put inside the building (the wAP and LHG were installed outside) outperformed the Mikrotik products by far.
I then replaced the 4G/LTE miniPCI card in the LHG with a Huawei ME909s-120, and immediately got better performance (stable ping times, stable connection, high speed).
On another site (my home), I installed a wAP LTE with two external antennas (Iskra P-58 L700). Performance was terrible until I installed a Huawei miniPCI card.
I know I'm not the only one experience terrible performance with these products, which is bad. I really like Mikrotik products, and this cannot be good for Mikrotik's reputation. I think the wAP LTE and LHG LTE should be available with an empty miniPCE slot to enable the buyer to select a miniPCI module on his/her own. In fact, I believe that they should never be sold equipped with the Mikrotik 4G/LTE modules.
jspool
Re: wAP LTE and LHG LTE - Very bad LTE performance
Mon Jan 27, 2020 10:44 pm
It's unlikely a single modem from Mikrotik will suit the needs of everyone in every country. Personally I order the SXTR and LHGR (The ones without an included modem) I then put in the desired modem based on the location or needs and they work flawlessly.
LSan83
Tue Jan 28, 2020 12:26 pm
Hi, here in Italy both WAP LTE and LHG LTE with standard Mikrotik modem work very well.
I reached stable 95-100 Mbits data transfer without problem (on 20Mhz B3).
Perhaps is a problem of your country's mobile operator.
LinusN
Tue Jan 28, 2020 3:44 pm
What is the 4G coverage where these have been installed? The ones I had problems with were installed in difficult areas. The Huawei 4G boards show RSSI around -80 and SINR around 1-4.
LinusN
Tue Jan 28, 2020 3:50 pm
Maybe so. The operator in use (Telenor) use frequency bands 20, 8, 3, 38 for LTE. The LHG LTE Kit supports all of these.
The Huawei ME909s-120 supports 20, 8 and 3 (not 38). It still works better. Is there something else to look for?
Filament
Tue Jan 28, 2020 5:19 pm
Which firmware are you running in your R11e-LTE card? I've installed several wAP LTE routers and had very poor performance until I upgraded to firmware v13, that version fixed the issues for me (my telco provider is Vodafone in Spain)
LinusN
Wed Jan 29, 2020 11:07 am
Honestly, I have no idea. I did not even know I could upgrade the firmware. How do I do that? Is there a guide somewhere?
This would of course be great news if it worked! :)
eworm
Wed Jan 29, 2020 11:16 am
To check if an update is available:
[admin@MikroTik] > /interface lte firmware-upgrade lte1
  installed: MikroTik_CP_2.160.000_v011
     latest: MikroTik_CP_2.160.000_v013
I would advise to use my script unattended-lte-firmware-upgrade.
Just copy and paste into a terminal, then be patient and wait until the firmware is updated.
SiB
Wed Jan 29, 2020 12:11 pm
Official documentation:
https://wiki.mikrotik.com/wiki/Manual:I ... re_upgrade
eworm
Wed Jan 29, 2020 3:26 pm
But keep in mind that you can not do the upgrade via LTE this way. A stable management connection is required.
JardinEspanol
Thu Jan 30, 2020 2:18 am
@eworm, thank you for making the modem firmware upgrade script. It seems to work, but looks like my modem has some kind of issue. I executed your script twice. Hopefully, this info can shed some light into why R11e-LTE-US modem is not upgrading.
# Time Buffer Topics Message
155 Jan/29/2020 11:36:34 memory system, info new script added by admin
172 Jan/29/2020 11:36:47 memory script, info Scheduling LTE firmware upgrade for interface lte1.
173 Jan/29/2020 11:36:47 memory system, info new script added by admin
174 Jan/29/2020 11:36:47 memory system, info new script scheduled by admin
255 Jan/29/2020 11:37:47 memory system, info script removed from scheduler by admin
256 Jan/29/2020 11:37:47 memory system, info script removed by admin
257 Jan/29/2020 11:37:47 memory lte, account lte1 session: 163040s 32402090424/6915060917 bytes 31470168/23322992 packets
258 Jan/29/2020 11:37:47 memory lte, async lte1: sent at$ecmcall=0
259 Jan/29/2020 11:37:47 memory interface, info lte1 link down
260 Jan/29/2020 11:37:47 memory lte, async, event $ECMCALL: 0
261 Jan/29/2020 11:37:47 memory lte, async lte1: rcvd OK
262 Jan/29/2020 11:37:47 memory lte, async, event @SOCKDIAL:1
263 Jan/29/2020 11:37:49 memory lte, async, event @FOTACHECK:"1839-1839-XXXX-XXXX-XXXX","some numbers"
264 Jan/29/2020 11:37:49 memory lte, async, event @FOTAIND:1,1
267 Jan/29/2020 11:47:53 memory lte, async, event @FOTAIND:3,1
268 Jan/29/2020 11:47:53 memory script, info LTE firmware upgrade finished, waiting for installation before reset.
269 Jan/29/2020 11:47:54 memory lte, async lte1: sent AT+CFUN=1,1
270 Jan/29/2020 11:47:54 memory lte, async lte1: rcvd OK
271 Jan/29/2020 11:47:57 memory lte, async, event @SOCKDIAL:0
272 Jan/29/2020 11:47:57 memory lte, async, raw =+CREG: 0
273 Jan/29/2020 11:47:57 memory lte, async, raw =+CGREG: 0
274 Jan/29/2020 11:47:57 memory lte, async, raw =+CEREG: 0
275 Jan/29/2020 11:47:57 memory lte, async, event =+CGEV: ME DETACH
276 Jan/29/2020 11:47:59 memory lte, async lte1: modem hung up
277 Jan/29/2020 11:48:14 memory lte, async lte1: sent AT E0 V1
278 Jan/29/2020 11:48:23 memory lte, async lte1: rcvd OK
279 Jan/29/2020 11:48:23 memory lte, async lte1: sent AT+CFUN?
280 Jan/29/2020 11:48:23 memory lte, async lte1: rcvd +CFUN: 1
281 Jan/29/2020 11:48:23 memory lte, async lte1: sent AT+CFUN=4
282 Jan/29/2020 11:48:24 memory lte, async lte1: rcvd OK
283 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CFUN?
284 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd +CFUN: 4
285 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CMEE=2
286 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
287 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CREG=2
288 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
289 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CGREG=2
290 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
291 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CEREG=2
292 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
293 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CGEREP=2,0
294 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
295 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CMGF=0
296 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
297 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CNMI=1,1,0,1,0
298 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
299 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CFUN=1
300 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd OK
301 Jan/29/2020 11:48:27 memory lte, async lte1: sent AT+CPIN?
302 Jan/29/2020 11:48:27 memory lte, async lte1: rcvd +CPIN: READY
303 Jan/29/2020 11:48:27 memory lte, async, raw =+CREG: 2
304 Jan/29/2020 11:48:27 memory lte, async, raw =+CGREG: 2
305 Jan/29/2020 11:48:27 memory lte, async, raw =+CEREG: 2
306 Jan/29/2020 11:48:28 memory lte, async, raw =+CREG: 1,"FFFE","A438001", 7
307 Jan/29/2020 11:48:28 memory lte, async, raw =+CGREG: 1,"FFFE","A438001",7
308 Jan/29/2020 11:48:28 memory lte, async, raw =+CEREG: 1,"8D03","1C","A438001",7
309 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+CPMS="SM","SM","SM"
310 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd +CPMS: 0,30,0,30,0,30
311 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+CFUN?
312 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd +CFUN: 1
313 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+ICCID
314 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd ICCID: 89014 some other numbers
315 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+CNUM
316 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd
317 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+CIMI
318 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd 310 some other numbers
319 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+CPIN?
320 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd +CPIN: READY
321 Jan/29/2020 11:48:31 memory lte, async lte1: sent AT+COPS=2
322 Jan/29/2020 11:48:31 memory lte, async, raw =+CREG: 0
323 Jan/29/2020 11:48:31 memory lte, async, raw =+CGREG: 0
324 Jan/29/2020 11:48:31 memory lte, async, raw =+CEREG: 0
325 Jan/29/2020 11:48:31 memory lte, async lte1: rcvd OK
326 Jan/29/2020 11:48:31 memory lte, async, event =+CGEV: NW DETACH
327 Jan/29/2020 11:48:33 memory lte, async lte1: sent AT+COPS=0,0,,7
328 Jan/29/2020 11:48:33 memory lte, async lte1: rcvd OK
329 Jan/29/2020 11:48:33 memory lte, async lte1: sent AT+CGDCONT=1,"IP","broadband"
330 Jan/29/2020 11:48:33 memory lte, async lte1: rcvd OK
331 Jan/29/2020 11:48:33 memory lte, async lte1: sent AT$QCPDPP=1,0
332 Jan/29/2020 11:48:33 memory lte, async lte1: rcvd OK
333 Jan/29/2020 11:48:33 memory lte, async, raw =+CREG: 2
334 Jan/29/2020 11:48:33 memory lte, async, raw =+CGREG: 2
335 Jan/29/2020 11:48:33 memory lte, async, raw =+CEREG: 2
336 Jan/29/2020 11:48:34 memory lte, async, raw =+CREG: 1,"FFFE","A438001", 7
337 Jan/29/2020 11:48:34 memory lte, async, raw =+CGREG: 1,"FFFE","A438001",7
338 Jan/29/2020 11:48:34 memory lte, async, raw =+CEREG: 1,"8D03","1C","A438001",7
339 Jan/29/2020 11:48:34 memory lte, async lte1: sent AT+CEREG=2
340 Jan/29/2020 11:48:34 memory lte, async lte1: rcvd OK
341 Jan/29/2020 11:48:34 memory lte, debug lte1: config ok
342 Jan/29/2020 11:48:34 memory lte, debug lte1: network access technology: Evolved 3G (LTE)
343 Jan/29/2020 11:48:34 memory lte, info lte1: registered home
344 Jan/29/2020 11:48:34 memory lte, async, raw lte1: sent AT+CFUN?
345 Jan/29/2020 11:48:34 memory lte, async, raw lte1: rcvd +CFUN: 1
346 Jan/29/2020 11:48:34 memory lte, async, raw lte1: sent AT+COPS?
347 Jan/29/2020 11:48:34 memory lte, async, raw lte1: rcvd +COPS: 0,0,"AT&T",7
348 Jan/29/2020 11:48:34 memory lte, async, raw lte1: sent QAT$QCRSRP?
356 Jan/29/2020 11:48:39 memory lte, async lte1: sent at$ecmcall=1
357 Jan/29/2020 11:48:39 memory lte, async, event $ECMCALL: 1
358 Jan/29/2020 11:48:39 memory lte, async lte1: rcvd OK
359 Jan/29/2020 11:48:39 memory lte, async lte1: sent at$ecmcall?
360 Jan/29/2020 11:48:39 memory lte, async lte1: rcvd $ECMCALL: 1
361 Jan/29/2020 11:48:39 memory lte, async lte1: sent AT+CGCONTRDP=1
362 Jan/29/2020 11:48:39 memory lte, async lte1: rcvd +CGCONTRDP: 1,5,broadband, ip address was here,,another ip address was here,
363 Jan/29/2020 11:48:39 memory interface, info lte1 link up
364 Jan/29/2020 11:48:39 memory interface, info lte1 link down
365 Jan/29/2020 11:48:39 memory interface, info lte1 link up
366 Jan/29/2020 11:48:40 memory lte, async, raw lte1: sent QAT$QCRSRP?
402 Jan/29/2020 11:49:05 memory lte, async, raw =+CREG: 1,"FFFE","A438016", 7
403 Jan/29/2020 11:49:05 memory lte, async, raw =+CGREG: 1,"FFFE","A438016",7
404 Jan/29/2020 11:49:05 memory lte, async, raw =+CEREG: 1,"8D03","1C","A438016",7
405 Jan/29/2020 11:49:07 memory lte, async, raw lte1: sent AT+CFUN?
406 Jan/29/2020 11:49:07 memory lte, async, raw lte1: rcvd +CFUN: 1
407 Jan/29/2020 11:49:07 memory lte, async, raw lte1: sent AT+COPS?
408 Jan/29/2020 11:49:07 memory lte, async, raw lte1: rcvd +COPS: 0,0,"AT&T",7
513 Jan/29/2020 11:50:23 memory lte, async lte1: sent AT+RESET
514 Jan/29/2020 11:50:23 memory lte, async lte1: rcvd ERROR
643 Jan/29/2020 11:52:01 memory system, info changed script settings by admin
661 Jan/29/2020 11:52:14 memory script, info Scheduling LTE firmware upgrade for interface lte1.
664 Jan/29/2020 11:52:14 memory system, info new script added by admin
666 Jan/29/2020 11:52:14 memory system, info new script scheduled by admin
743 Jan/29/2020 11:53:14 memory system, info script removed from scheduler by admin
744 Jan/29/2020 11:53:14 memory system, info script removed by admin
745 Jan/29/2020 11:53:14 memory lte, account lte1 session: 275s 10070111/2886592 bytes 16331/15938 packets
746 Jan/29/2020 11:53:14 memory lte, async lte1: sent at$ecmcall=0
747 Jan/29/2020 11:53:14 memory interface, info lte1 link down
748 Jan/29/2020 11:53:14 memory lte, async, event $ECMCALL: 0
749 Jan/29/2020 11:53:14 memory lte, async lte1: rcvd OK
750 Jan/29/2020 11:53:14 memory lte, async, event @SOCKDIAL:1
751 Jan/29/2020 11:53:16 memory lte, async, event @FOTACHECK:"1839-1839-XXXX-XXXX-XXXX","some numbers"
752 Jan/29/2020 11:53:16 memory lte, async, event @FOTAIND:1,1
755 Jan/29/2020 12:03:19 memory lte, async, event @FOTAIND:3,1
756 Jan/29/2020 12:03:20 memory script, info LTE firmware upgrade finished, waiting for installation before reset.
757 Jan/29/2020 12:03:20 memory lte, async lte1: sent AT+CFUN=1,1
758 Jan/29/2020 12:03:20 memory lte, async lte1: rcvd OK
759 Jan/29/2020 12:03:24 memory lte, async, event @SOCKDIAL:0
760 Jan/29/2020 12:03:24 memory lte, async, raw =+CREG: 0
761 Jan/29/2020 12:03:24 memory lte, async, raw =+CGREG: 0
762 Jan/29/2020 12:03:24 memory lte, async, raw =+CEREG: 0
763 Jan/29/2020 12:03:24 memory lte, async, event =+CGEV: ME DETACH
764 Jan/29/2020 12:03:25 memory lte, async lte1: modem hung up
765 Jan/29/2020 12:03:40 memory lte, async lte1: sent AT E0 V1
766 Jan/29/2020 12:03:50 memory lte, async lte1: rcvd OK
767 Jan/29/2020 12:03:50 memory lte, async lte1: sent AT+CFUN?
768 Jan/29/2020 12:03:50 memory lte, async lte1: rcvd +CFUN: 1
769 Jan/29/2020 12:03:50 memory lte, async lte1: sent AT+CFUN=4
770 Jan/29/2020 12:03:50 memory lte, async lte1: rcvd OK
771 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CFUN?
772 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd +CFUN: 4
773 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CMEE=2
774 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
775 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CREG=2
776 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
777 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CGREG=2
778 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
779 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CEREG=2
780 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
781 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CGEREP=2,0
782 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
783 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CMGF=0
784 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
785 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CNMI=1,1,0,1,0
786 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
787 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CFUN=1
788 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd OK
789 Jan/29/2020 12:03:53 memory lte, async lte1: sent AT+CPIN?
790 Jan/29/2020 12:03:53 memory lte, async lte1: rcvd +CPIN: READY
791 Jan/29/2020 12:03:54 memory lte, async, raw =+CREG: 2
792 Jan/29/2020 12:03:54 memory lte, async, raw =+CGREG: 2
793 Jan/29/2020 12:03:54 memory lte, async, raw =+CEREG: 2
794 Jan/29/2020 12:03:54 memory lte, async, raw =+CREG: 1,"FFFE","A438001", 7
795 Jan/29/2020 12:03:54 memory lte, async, raw =+CGREG: 1,"FFFE","A438001",7
796 Jan/29/2020 12:03:54 memory lte, async, raw =+CEREG: 1,"8D03","1C","A438001",7
797 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+CPMS="SM","SM","SM"
798 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd +CPMS: 0,30,0,30,0,30
799 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+CFUN?
800 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd +CFUN: 1
801 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+ICCID
802 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd ICCID: 89014 some more numbers
803 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+CNUM
804 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd
805 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+CIMI
806 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd 310 some more numbers
807 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+CPIN?
808 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd +CPIN: READY
809 Jan/29/2020 12:03:57 memory lte, async lte1: sent AT+COPS=2
810 Jan/29/2020 12:03:57 memory lte, async, raw =+CREG: 0
811 Jan/29/2020 12:03:57 memory lte, async, raw =+CGREG: 0
812 Jan/29/2020 12:03:57 memory lte, async, raw =+CEREG: 0
813 Jan/29/2020 12:03:57 memory lte, async lte1: rcvd OK
814 Jan/29/2020 12:03:57 memory lte, async, event =+CGEV: NW DETACH
815 Jan/29/2020 12:03:59 memory lte, async lte1: sent AT+COPS=0,0,,7
816 Jan/29/2020 12:03:59 memory lte, async lte1: rcvd OK
817 Jan/29/2020 12:03:59 memory lte, async lte1: sent AT+CGDCONT=1,"IP","broadband"
818 Jan/29/2020 12:03:59 memory lte, async lte1: rcvd OK
819 Jan/29/2020 12:03:59 memory lte, async lte1: sent AT$QCPDPP=1,0
820 Jan/29/2020 12:03:59 memory lte, async lte1: rcvd OK
821 Jan/29/2020 12:04:00 memory lte, async, raw =+CREG: 2
822 Jan/29/2020 12:04:00 memory lte, async, raw =+CGREG: 2
823 Jan/29/2020 12:04:00 memory lte, async, raw =+CEREG: 2
824 Jan/29/2020 12:04:00 memory lte, async lte1: sent AT+CEREG=2
825 Jan/29/2020 12:04:00 memory lte, async lte1: rcvd OK
826 Jan/29/2020 12:04:00 memory lte, debug lte1: config ok
827 Jan/29/2020 12:04:00 memory lte, async, raw lte1: sent AT+CFUN?
828 Jan/29/2020 12:04:00 memory lte, async, raw lte1: rcvd +CFUN: 1
829 Jan/29/2020 12:04:00 memory lte, async, raw lte1: sent AT+CSQ
830 Jan/29/2020 12:04:00 memory lte, async, raw lte1: rcvd +CSQ: 24,99
831 Jan/29/2020 12:04:01 memory lte, async, raw =+CREG: 1,"FFFE","A438016", 7
832 Jan/29/2020 12:04:01 memory lte, debug lte1: network access technology: Evolved 3G (LTE)
833 Jan/29/2020 12:04:01 memory lte, info lte1: registered home
834 Jan/29/2020 12:04:01 memory lte, async, raw =+CGREG: 1,"FFFE","A438016",7
835 Jan/29/2020 12:04:01 memory lte, async, raw =+CEREG: 1,"8D03","1C","A438016",7
836 Jan/29/2020 12:04:03 memory lte, async, raw lte1: sent AT+CFUN?
837 Jan/29/2020 12:04:04 memory lte, async, raw lte1: rcvd +CFUN: 1
838 Jan/29/2020 12:04:04 memory lte, async, raw lte1: sent AT+COPS?
839 Jan/29/2020 12:04:04 memory lte, async, raw lte1: rcvd +COPS: 0,0,"AT&T",7
840 Jan/29/2020 12:04:04 memory lte, async, raw lte1: sent QAT$QCRSRP?
844 Jan/29/2020 12:04:06 memory lte, async lte1: sent at$ecmcall=1
845 Jan/29/2020 12:04:06 memory lte, async, event $ECMCALL: 1
846 Jan/29/2020 12:04:06 memory lte, async lte1: rcvd OK
847 Jan/29/2020 12:04:06 memory lte, async lte1: sent at$ecmcall?
848 Jan/29/2020 12:04:06 memory lte, async lte1: rcvd $ECMCALL: 1
849 Jan/29/2020 12:04:06 memory lte, async lte1: sent AT+CGCONTRDP=1
850 Jan/29/2020 12:04:06 memory lte, async lte1: rcvd +CGCONTRDP: 1,5,broadband,ip address was here,,another ip address was here,
851 Jan/29/2020 12:04:06 memory interface, info lte1 link up
852 Jan/29/2020 12:04:06 memory interface, info lte1 link down
853 Jan/29/2020 12:04:06 memory interface, info lte1 link up
994 Jan/29/2020 12:05:50 memory lte, async lte1: sent AT+RESET
995 Jan/29/2020 12:05:50 memory lte, async lte1: rcvd ERROR
996 Jan/29/2020 12:05:52 memory lte, async, raw lte1: sent QAT$QCRSRP?
krafg
Thu Jan 30, 2020 2:54 am
Sometimes the basestation that your device connects have bad thoughput for many clients connected or simply the trunk of the basestation have low thoughput (if the connection is though VDSL or MMOO normally this happens). Check if with your cellphone you have the same results that using MikroTik. Make sure that the signal levels are good (-100 dbm or plus in RSRP).
Regards.
LinusN
Thu Jan 30, 2020 11:21 am
Thank you. It would be very interesting to make a comparison before and after upgrading. I have a wAP LTE which is not in use.
For the sake of making a good comparison. What should I measure in terms of performance before and after the upgrade?
WeWiNet
Long time Member
Long time Member
Thu Jan 30, 2020 12:29 pm
It does upgrade over LTE connection. Never had issues so far.
SiB
Thu Jan 30, 2020 12:49 pm
RSRP, avg. of few speedtest's, sinr <-- all those on different BAND's.
That way you know what speed and signal's you have on what band per different firmware. This should be fine for you.
In my case I have R11e-LTE6_V022_085TB@6.47beta24 with that I do additional test like - how long works ca-band, that ca-band give me additional speed or/and stability. I check that in 3G too. That CellLock works in 3G and/or LTE and cell-monitor works and show correct or not data. I go near to my eNB and do a speedtest per few ISP. All this go into excel table and are feedback to MikroTik support team.
Users browsing this forum: No registered users and 25 guests
