in4ni
Can MikroTik RouterOS V2.8 do this
Thu Dec 09, 2004 4:36 am
Here is my scenario:
1100 users with pre assigned username and password arrive at convention center with ther notebook, sit down and plug in to the LAN
open their browsers and get re-directed to a login page before internet access is granted sessions will need time out limits etc. Also i need to limit bandwidth to 64k. Also some users will need a pre-assigned public ip address. Smtp re-direction would be nice.
What would be the minunum hardware requirements for 1100 users and a 45MB T-3
Thank you.
mag
Re: Can MikroTik RouterOS V2.8 do this
Thu Dec 09, 2004 9:42 am
...open their browsers and get re-directed to a login page before internet access is granted sessions will need time out limits etc. Also i need to limit bandwidth to 64k. Also some users will need a pre-assigned public ip address. Smtp re-direction would be nice.
sounds like the usual hotspot features.
http://www.mikrotik.com/docs/ros/2.8/ip/hotspot.content
depends from area and building. i've heard of up to 50 users per accesspoint (it's possible to have many accesspoints connected to the hotspot server). in a building made of reinforced concrete its e.g. difficult to get floor to floor connections.
regards.
  matthias
the_time
Fri Dec 10, 2004 9:48 am
The hotspot is teh best solution for this we alredy doing this and you can limit in the profile .
Thanks , the_time
in4ni
Mon Dec 13, 2004 2:01 am
I want hardware reccomendations for the mikrotik box itsself. My internet connection is a T-3 with about 1100 connected users.
wildbill442
Mon Dec 13, 2004 5:30 am
a decent processor speed ~1000mhz should handle it fine with about 1MB RAM per user depending on firewall rules and such..
so 1GHz 1GB RAM should handle all the connections fine, and like one user said before me the limiting factor is your AP's you're going to need a few of them to handle the user load, 802.11b is limited to 5.5mbps so you have some math to do. :)
