+1 but MLAG / LACP must be >20pcs , the best without limitationMikroTik Cloud Router Switch CRS354-48G-4S+2Q+RM
If the MLAG is active-passive (like in IOS-XR), then Layer-3 is very easy, because only one of both routers has an active/running interface. The distribution needs to be done by a routing protocol, of course.I would much rather see stacking.
MLAG is fine for Layer 2, but it's a nightmare for Layer 3. Stacking works well for both. Considering a lot of the CRS3XX chipsets have L3 HW offload that has yet to be taken advantage of, it would be nice to be able to form an LACP chanel across two or more switches and use it at L2 or L3.
802.1BR is NOT MC-LAG and has a different use case. It is for bridge extension, port expanders and the like. You could possibly use it for stacking...The IEEE 802.1BR support added to 6.48beta12 will eventually give us that, and more:
*) crs3xx - added initial Bridge Port Extender support (CLI only);
*) crs3xx - added initial Controlling Bridge support for CRS317, CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices (CLI only);
A full IEEE 802.1BR implementation will give you a single control plane for all your switches, like a Cisco 3x00 switch stack or 6800 & Nexus with fabric extenders.
Bring it on, MikroTik!
It only eliminates the need to use STP and VRRP. Dual control plane issues like lack of synced connection tracking will remain.MC-LAG is still needed, it removes the "single control plane" point of failure.
Or to have 2 or 4Ge redundant connection from server for free.I'd be happy with the ability to just be able to run an MLAG. There is currently no way for one to create a redundant LAG across 2 switches for redundancy.
Anyone have a workaround to be able to bond 2 connections from say a router to 2 switches?
I got this working, but there is NO hardware switching support, so its all CPU based, which as you know means its unusable.Anyone tried this yet?
https://help.mikrotik.com/docs/display/ ... t+Extender
And managed to get a bonded interface across 2 switches?
I'd take any stack or MC-LAG solution as long as the control plane can take over from one to another stack/mc-member, though I guess to get it to work like in cisco-stacks this would take a serious rewrite on RouterOS, therefore mc-lag might be the easier solution (or virtual bonding between multiple CRS-boxes).802.1BR is NOT MC-LAG and has a different use case. It is for bridge extension, port expanders and the like. You could possibly use it for stacking...
They're available now:7.1beta6 changelog:7.1beta6 changelog:
!) added MLAG support for CRS3xx devices (CLI only);
No instruction yet
