seanet
LTE Network mode check
Thu Jan 30, 2020 1:48 pm
Hi
i want to create script to do some actions after checking lte interface network mode
For example if "gsm,3g,lte" is checked do /beep
but it does't work correctly.but i don't know why ?
:global a
/interface lte print once do={
  :set a $network-mode
:if ($a = "gsm,3g,lte") do={
  :beep frequency=50 length=2
SiB
Re: LTE Network mode check
Fri Jan 31, 2020 1:15 am
first try your command in CLI, just in terminal to discover that print and once are not existing together. Use TAB key in CLI.
Next with working one command build more complex structure. Use simple commands as possible.
put [interface lte get lte1 network-mode ]
lte
if (1=1) do={put OK} else={put NOK}
OK
if ([interface lte get lte1 network-mode ] = "lte") do={put OK} else={put NOK}
OK
if ([interface lte get lte1 network-mode ] = "lte") do={/system script run music}
And bonus:
Beeps are for play a music "Star Wars -- The Imperial March" or "A_Bit_of_Sounds"
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | Buy me a caffe
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
seanet
Sat Feb 01, 2020 8:33 am
thanks Sir
i will try :D
scarletmichelle
Wed Dec 30, 2020 9:15 am
lte
OK
OK
And bonus:
Your music is great, I like it and can I download it ???
World ringtones for your mobile phone.
SiB
Tue Feb 23, 2021 1:54 am
scarletmichelle
If your RouterBoard have got a speaker (beep commands play a music) then you go into this commands lines and can use them as Script and play anytime you want.
But you not download them as .mp3 etc.
Jotne
Tue Feb 23, 2021 11:06 am
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
Users browsing this forum: No registered users and 39 guests
