keithstarrate
Speed limit on queue not working
Wed Feb 12, 2020 1:31 pm
Hi there,
I'm having an issue with a speed limit I'm trying to apply on 2 separate interfaces on an RB951 (6.43.4) that I was hoping someone might be able to assist with.
I have 2 separate physical LANs plugged in to the Mik on independent interfaces using the same WAN interface (20mbps) and want to apply bandwidth limits of approximately 15 and 5 mbps, respectively.
LAN1 (192.168.100.0) uses a Linux firewall (192.168.100.85(LAN), 10.0.0.2(WAN) as it's LAN gateway which in turn uses the Mikrotik (10.0.0.254 - eth2) as it's gateway.
LAN2 (192.168.0.0) is just a switch plugging in to eth3 (192.168.0.254) on the Mik, also using it as it's gateway.
Routing is all working fine and the LANs can't see each other but when running speed tests using the queue speed limits I've applied I'm not getting the intended limitations, or any limitation for that matter. I've tried dropping them as low as a few hundred kbps but still seem to get full throughput when doing speed tests and downloads.
I've attached screenshots of the queues.
Your assistance is greatly appreciated.
davidsheffield
Re: Speed limit on queue not working
Wed Feb 12, 2020 7:36 pm
goto your bridge general tab and uncheck fast forward then click apply, this should work
keithstarrate
Tue Feb 18, 2020 11:43 am
Thanks, David. Unfortunately, this did not help.
skylark
Tue Feb 18, 2020 11:53 am
Disable action=fasttrack-connection under firewall filter rules or enable use-ip-firewall under bridge settings if you have one configured. If it still does not work, please show us devices /export hide-sensitive !
keithstarrate
Tue Feb 18, 2020 12:15 pm
I found the solution here
https://www.youtube.com/watch?v=6LaqhDm6PHI
The fast track rule needs to be removed from the firewall
viewtopic.php?t=120772
skylark
Tue Feb 18, 2020 3:57 pm
You can keep the rule for the traffic which should not be shaped with queues and it will increase overall throughput, and reduce a CPU load.
Users browsing this forum: Bing [Bot], rjscomms and 146 guests
