tberg
CRS Ethernet TX Drops
Sun Feb 16, 2020 10:44 pm
We recently installed a few CRS317 and 328P switches. I am noticing TX Drops incrementing on some Ethernet interfaces. What are TX drops? Are they buffer overflows or filtered traffic with incorrect/unallowed VLAN tags?
tberg
Re: CRS Ethernet TX Drops
Mon Feb 17, 2020 3:57 pm
Looking closer, they must be buffer overruns. They are only happening on 1G ports on switches that have 10G ingress and multiple 1G egress. I assume you cannot change interface queue type without breaking hardware offload.
IPANetEngineer
Trainer
Trainer
Mon Feb 17, 2020 4:26 pm
If you are going to be moving a lot of traffic between ports at different speeds , you may be exceeding the buffer (which is required for moving traffic between ports of different speeds.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
tberg
Mon Feb 17, 2020 6:14 pm
Thanks! Yes I'm sure that is it. On the worst port, it is about .1%. We're moving to switch centric architecture and upgrading routers. Once routers are all 10G, part of the problem should go away. However, it's got me thinking about uplink to access switches with 1G backhaul and APs. It might be better to aggregate a few 1G uplinks vs. 10G uplink. Either that or get different switches with bigger buffers?
Maggiore81
Thu Apr 02, 2020 6:30 pm
Hello
we replaced an UBNT Edgeswitch (all with 1G) ports with a CRS326-24G-2S+ with RouterOS
we just use for VLANS, as a L2 switch.
we replaced the UBNT to take advantage of the S+ ports 10G.
We have now a 10G SFP+ port with DAC to the router (CCR 1009).
We have multiple PTP Wireless licensed uplink coming at 1G speed into the switch, and going aggregated in a VLAN TRUNK port on the CCR through 10G port.
we noticed immediately tx drops.
Is normal or should we change something?
Dott. Elia Spadoni
Network Administrator,
MTCNA, MTCRE, MTCTCE, MTCINE, MTCWE, MTCSE
Spadhausen Internet Provider
Ravenna, ITALY
http://www.spadhausen.com
Users browsing this forum: Alexa [Bot], Zipter47 and 55 guests
