I don't understand XS, XC, and XQ.
Gone? Stupid me - should've got some screens...According to the links @Paternot found (but are gone now), XS would be '40 Gigabit' and XQ '40 Gigabit combo'. With '40 Gigabit' being (I assume) 40GBASE-T (because of the 'combo' bit, and we already have 'Q+' for QSFP+ 40G).
I don't think they are the real prices. Many sites do this: put an impossible price, when the item is out of stock.Ah! Didn't think of google cache. Interesting prices too; 10K NT$ is only US $334,=. Somehow I don't think they'll be *that* cheap![]()
Intresting. The ccr2016 variant, AL73400 possibly?
My point was:I don't understand XS, XC, and XQ.
To my great surprise 40GBASE-T actually exists as a standard (it's defined in IEEE 802.3bq), but who in his right mind would ever use it? It needs a CAT8 cabling plant, which nobody has, and makes no sense to install even on a greenfield because just going to OM4 is cheaper. And even if you had one it then only reaches 30 meters! And if 10GBASE-T is any indication, you can probably use the tranceivers to boil your tea...
Nope, not seeing it.
My point was:
- G means GBASE-T so X would just mean 10
- XQ should actually be QC if XC replaces C+
- There's nothing that says 40 in XS
Terragraph?what 60ayD could mean?
So this was in a wiki modification from July 2018 that lacks a comment.Some clues here? https://wiki.mikrotik.com/wiki/Manual:P ... ng_details
What else? Dual chain.
The port configuration is actually quite minimal for SOHO.Yes make sense Wifi 802.11ay 60 GHz Dual chain but what really doesn't make sense is to put a wifi interface in a Core router that has 2xGiga port + 10G SFP+ ports and 2x 25G SFP+
Some people would actually look for Q+.
It is not lunacy when a 40G card costs about 300 euro.The port configuration is actually quite minimal for SOHO.
We've been here before: I want what you are smoking. Really. We're getting to the point that 10G is useful and affordable for prosumers and enthousiasts. Calling a router with 25G ports 'quite minimal for SOHO' is lunacy.
Professionals also work at home.
40G is the new 10G.It is not lunacy when a 40G card costs about 300 euro.
Vortex, there is a difference between 'there is a market for 40G for home' and 'a router with 25G ports is quite minimal for SOHO'. I agree with the first, small as I think that market to be. The second does not follow from the first. If you don't see that, this discussion is pointless.
That all is plausible, what I don't get it is why to put a Wifi interface on CCR device? in POV it totally wastes of resources40G is the new 10G.It is not lunacy when a 40G card costs about 300 euro.
When I was asking for home routers capable of 10G switching some years ago, it was professional level. Now not only is 10G cheap, some people even have 10G WAN at home.
Why would you buy a couple of 25G cards when they are not much cheaper than 40G? Workstations and NAS that can take them are not cheaper.
I did not buy a 10G NAS because it was slower than TB2. I will similarly avoid buying a 25G NAS because it is slower than TB3. If I really needed a serious NAS, I would want 40G (with NVMe slots of course).
Even if it can route much faster than 10000/10000, it can make sense for SOHO for IDS or VPN.That all is plausible, what I don't get it is why to put a Wifi interface on CCR device? in POV it totally wastes of resources
Look at it from a WISP perspective. You'd use the CCR2004-2G-2S+-2XS-60ayD a your wireless "POP". Put it right on a signal tower / post. Connect your 10/25G fibre uplinks to it, and spread those to various locations via 60GHz, and from then on.That all is plausible, what I don't get it is why to put a Wifi interface on CCR device? in POV it totally wastes of resources
I think CN98XX.Some clues here? https://wiki.mikrotik.com/wiki/Manual:P ... ng_details
OK, now that makes a lot more sense. a CCR2004-1G-12S+2XS has 12 SFP+ ports and 2 25G SFP+ ports, and the CCR2016-1G-12XS-2XQ has...<blink>...12x25G & 2x100G?![]()
I want to see prices for that CCR2016... And I want to know what's pushing those boxes. I don't think the Alpine SOCs will cut it for speeds like that, not even the AL73400/Graviton.
so you are putting the ccr as an very over blaster overkill AccessPoint? also in top of the Tower/post?Look at it from a WISP perspective. You'd use the CCR2004-2G-2S+-2XS-60ayD a your wireless "POP". Put it right on a signal tower / post. Connect your 10/25G fibre uplinks to it, and spread those to various locations via 60GHz, and from then on.That all is plausible, what I don't get it is why to put a Wifi interface on CCR device? in POV it totally wastes of resources
Example: 2 25G Uplinks to the CCR. The CCR connects to 2x4=8 distribution wireless systems. Imagine those as "LHG 5XP-60ay" or "LHG 5P+-60ay" (comparable to LHG 60G) with 5 Multigigabit PoE ports, each connecting to a pair of "wAP 60Gx3 AP" or different 60GHz APs with a smaller degree field of view.
That would net you up to 128 100Mbit Clients with "Cube Lite60" as customer client systems slaved to a single CCR2004.
Or quite a bit more if a .ay variant was used to connect the customer client devices.
Just my 2 cents![]()
ccr2004-1g-12s+2xs 4 Core, 1x 1G, 12x 10G SFP+, 2x 25G SFP28
ccr2016-1g-12xs-2xq 4 Core, 1x 1G, 12x 25G SFP+, 2x 100G QSFP28
ccr2004-2g-2xc-2s+ 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+
ccr2004-2g-2xc-2s+/r2 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+, 2.4Ghz WiFi
ccr2004-2g-2xc-2s+/r2-60 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+, 2.4Ghz WiFi, 802.11ay 60Ghz
CCR2004-2G-2S+2XS-60ayD Shorter Production model name for ccr2004-2g-2xc-2s+/r2-60
Marvell does not show only 16 cores in this subfamily.I think CN98XX.
Possibly Mikrotik have combined Annapurna Labs ARM core's with Marvell Prestera Switch ASIC's, where the AL chip does the initial packet pass (slow path) then the fast-path is handled by the Marvell ASIC. This would allow them to scale port counts independently of the ARM core and would also allow them to scale the platform from low-cost designs (CCR2004) with just an Annapurna Labs ARM processor, to higher-cost designs (CCR2016) with a Annapurna Labs core and a Marvell Prestera switch ASIC.
I just used the Marvell Prestera's as an example, because I know the ASIC's are capable of it, and that Mikrotik are familiar with them due to their use in CRS3xx series. They could use almost any of the modern L3+ switch ASIC's.
The Marvell Octeon TX2 and possibly NXP ARM based SOC's are really the only ARM SOC's capable of the port counts the above Mikrotik CCR20xx model codes indicate natively, the Annapurna Labs stuff that is public does not have support for that number of interfaces so if they are using the Annapurna Labs SOC's it is either some unknown version of it, or running external switch ASIC's for the fast-path as I suggested above.
Marvell have already made custom Prestera DX ASIC's for Mikrotik...I only saw the Prestera port extenders matching these speeds.
That's an interesting though. Does it mean that V7 final is closer than we thought? We already saw one site with the hardware, even if still "unavailable" and pulled out later.If we really are talking about multiple 25G and QSFP28 - then the forwarding must be done in hardware on a switch ASIC. No ARM or Intel CPU can shuffle that amounts of data.
It will probably then be a V7-only device with this specific forwarding delegation is implemented.
Do you know for which devices?Marvell have already made custom Prestera DX ASIC's for Mikrotik...
The 98DX8208 in the CRS309Do you know for which devices?Marvell have already made custom Prestera DX ASIC's for Mikrotik...
I certainly hope that is the case, but all the evidence above points to CCR2000 series being an Annapurna Labs based architecture.
If fibre is easy to break, some home users would prefer copper.To my great surprise 40GBASE-T actually exists as a standard (it's defined in IEEE 802.3bq), but who in his right mind would ever use it? It needs a CAT8 cabling plant, which nobody has, and makes no sense to install even on a greenfield because just going to OM4 is cheaper. And even if you had one it then only reaches 30 meters!
imagine a device - the ccr2004-2g-xxx - which is compact. as compact as a powerbox, maybe thicker. has decent fiberoptic options for high speed fixed backhaul.I extrapolated these codes out:
It all seems possible, but not completely logical.Code: Select allccr2004-1g-12s+2xs 4 Core, 1x 1G, 12x 10G SFP+, 2x 25G SFP28 ccr2016-1g-12xs-2xq 4 Core, 1x 1G, 12x 25G SFP+, 2x 100G QSFP28 ccr2004-2g-2xc-2s+ 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+ ccr2004-2g-2xc-2s+/r2 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+, 2.4Ghz WiFi ccr2004-2g-2xc-2s+/r2-60 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+, 2.4Ghz WiFi, 802.11ay 60Ghz
well, they are also to be found in 6.47b35 (checked the arm build)ccr2004-1g-12s+2xs
ccr2016-1g-12xs-2xq
ccr2004-2g-2xc-2s+
All referenced in a kernel object file in v7.0b5...
2.4GHz wifi for easier management if it is mounted to a tower / pole.
and has 2 independent .11ay radios, each with 180 degree FOV - using 3 RF stages each, similarly to the current APx3.
because this is what this looks like.
and i would buy them on first sight.
i built a fairly big network out of rev.5 terragraph nodes. their next gén stuff is in early prototype phase.I think you are on the right track here, and this could be a device in a square plastic enclosure that has connectors and a mounting bracket on the bottom to act as a Terragraph node.
I have no real idea, but it makes sense and the speculation is fun![]()
Very cool! I'm looking forward to the 16 core version for replacing some CCR1072 BGP routers, but those numbers for the 4 core one are pretty promising.Well one of these is now semi-announced:
https://mt.lv/CCR2004_1G_12S_2XS
It supports the -48volt DC PSU for the r2 CCR's as well!
The only head scratcher is the RAM... "RouterOS v6 1792MB ECC / RouterOS v7 4GB ECC", so for some reason we can't get the full 4GB of RouterOS 6? That's a bit of a weird limitation and until RouterOS 7 starts coming out with stable releases, having it in the core network makes me pretty uneasy.
One I can think of: full BGP tables. With the improvements made on RoS, and the higher single core speed, these new CCRs should work really well with this kind of load.which scenarios require vast amounts of RAM beyond 1.7GB ??? They are many? Jumping from 2GB to 4GB is enough for that scenarios??
no 40G port support?
In the text i read about it but in technical overiew i only see 25G ?
ccr2016-1g-12xs-2xq 16 Core, 1x 1G, 12x 25G SFP+, 2x 100G QSFP28
sort of. 40G was _the_ datacenter thing for quite a while, but almost entirely for switching / spine+leaf. there was for example no 'real' cisco router with 40G interfaces - they had 10GE or 100GE. the thing with 40G is that the form factor is really not efficient today. the same space can accommodate a qsfp28 with 100G and it can be breaked out to 4x25G, in the same way as 40GE can be split into 4x10G. the fact of the matter is, that forwarding ASICs/NPs have a huge amount of bandwidth available, but we struggle to find enough faceplate real-estate to accommodate the connectors. so there are already a truckload of various 32x or 64x 100GE pizza boxes on the market. honestly, they might even sacrifice the space for the lights out interface and require an app to display link states if they could put an extra port on the device.10G/40G: SOHO/SMB
25G/100G: datacenter
Buy a pcMikrotik cannot make the ideal device! Why it wasn’t easy to make support for USB, memory cards and several miniPCI-E slots and of course the ability to connect or immediately complete an SSD.
In my opinion better to make one universal device that will be easier to maintain.
Marketing, damn it ...
Want to buy Mikrotik's "PC". Buying PC I can use more powerful OS.Buy a pcMikrotik cannot make the ideal device! Why it wasn’t easy to make support for USB, memory cards and several miniPCI-E slots and of course the ability to connect or immediately complete an SSD.
You have to understand that MikroTik routers are built around "System-on-a-Chip" devices (SoC) which contain a certain mix of CPU (of course) and I/O ports.Mikrotik cannot make the ideal device! Why it wasn’t easy to make support for USB, memory cards and several miniPCI-E slots and of course the ability to connect or immediately complete an SSD.
The texts and descriptions feels a bit unpolished. Impressive power consumption and very nice with ECC memory. Looking forward to a block diagram as well.
ftp, dude, etc.Why the need for SSD storage in a router?
What do you mean, man?I understand Mikrotik routers uses not from a good life, for the same reason I want several uses for one device.
Of course it will kill the NAND flash after a while, it's only designed to run the OS and store configuration.
ftp, dude, etc.
Using internal 128 mbytes will kill it flash in a little time and divice goes into thrash.
PC is also worth the money and takes up space in the rack. It’s better to pay for Mikrotik some money for the SSD option or buy an SD card. You will not deny that the presence of an SD card in the CCR1000 is a necessary option.Of course it will kill the NAND flash after a while, it's only designed to run the OS and store configuration.
ftp, dude, etc.
I don't use dude myself but it does run far better in a CHR on a cheap PC/server. That goes for FTP as well.
You mean SO or also HO?For SOHO, a 100G switch with 24x 10G and 2x 100G would be very interesting.
I primarily mean SO, but the industry prefers the term SOHO...You mean SO or also HO?For SOHO, a 100G switch with 24x 10G and 2x 100G would be very interesting.
I agree with you there must be a huge market for devices like that. Everyone in the SOHO business would want or need some.
InHouse Distributed High Performance Computing (HPC) using Accelarator Cards for GPGPU computing via OpenCL/CUDA on true workstations (and servers), Games Dev, SciFi-Movie Dev, PCIe3/4 usage for realtime system backups to NAS system with NVMe SSDs, also crypto research (for example code cracking), ...I can't imagine any SOHO needing 10G, much less 100G.
That's fine. None of that is typically done in the home or small offices.InHouse Distributed High Performance Computing (HPC) using Accelarator Cards for GPGPU computing via OpenCL/CUDA on true workstations (and servers), Games Dev, SciFi-Movie Dev, PCIe3/4 usage for realtime system backups to NAS system with NVMe SSDs, also crypto research (for example code cracking)...I can't imagine any SOHO needing 10G, much less 100G.
The said 2x 100G interfaces on the switch are intended to attach 2 HPC servers to the switch, so that the switch can serve the 20 clients with 10G each over its 10G ports...
There is and will always be demand for HPC. Of course these are special applications, simply HPC applications, not the usual Average Joe applications![]()
But it is done in small closed research groups of up to that size. These are the core users, the horsepower of an org, excluding the foot folks like secretaries etc (1G suffices for these)That's fine. None of that is typically done in the home or small offices.
If people have 40G TB3, it is normal to want 40G Ethernet.I can't imagine any SOHO needing 10G, much less 100G.
It was not me who called a 4k-11k router SOHO.What @vortex seems to be implying is that such devices should come with SOHO price tag - and I fully agree at this point. Absolute number (and currency symbol) varies from market to market, for me acceptable price is 2 to 3 digit number expressed in Euro ... however @vortex so far quoted numbers which are one order of magnitude higher ... which rule them out of SOHO segment at least where I live ... most certainly from H, but from S as well.
Research groups can't be considered typical SOHO groups. Hence they don't use SOHO gear ... even if it's the same devices, when they use them they are instrumentsBut it is done in small closed research groups of up to that size.That's fine. None of that is typically done in the home or small offices.
I never said 40G is a minimum for SOHO, just that it is normal if professional users want that at home.It was not me who called a 4k-11k router SOHO.
No, you didn't do it directly. However, you're very vocal at claiming 40Gbps is a minimum for contemporary SOHO[*] ... I'm just extrapolating that over current gear prices.
[*] I'm not talking about special uses such as set forward by @mutluit ... and even in HPC world most of the time super high bandwidth is not necessary, the uses he described demand low latency (which slightly correlates with high thtoughput, but not linearly) and for those uses there are specialized solutions (such as infiniband for communication between compute nodes or fibrechannel for attaching SAN). Those solutions come with price tags in the same order of magnitude as 40/100 Gbps ethernet.
Rather I'm talking about typical office ... which can as well be some engineers developing new products ... and in such offices, 40Gbps or 100Gbps is not a norm yet, 1Gbps mostly does it, perhaps small fraction of devices need 10Gbps.
It absolutely is not.I did not say 40G is a typical SOHO requirement, just a normal one.
40G is not HPC level. It is Mac level.
Macs have had 40G TB3 for years.It absolutely is not.
https://media1.tenor.com/images/196b84e ... d=14058849Macs have had 40G TB3 for years.It absolutely is not.
No lesser NAS will be accepted here.
A bog-standard PC is far cheaper than a CCR. We have several CCR, no SD cards at all.PC is also worth the money and takes up space in the rack. It’s better to pay for Mikrotik some money for the SSD option or buy an SD card. You will not deny that the presence of an SD card in the CCR1000 is a necessary option.
Vortex ... please do stop treating us as kids. All the time you write ... MORE, MORE, MORE ... SOHO needs more ... I need MORE ... it's obvious what you write about and ask for no matter what words you don't use.40G is the new 10G.
I _really_ wish it was Marvell Octeon TX2, but this platform looks like Annapurna Labs ARM SoC's.
Following this bus speed logic I could say hurr durr 200G is basic b*tch gaming PC level because I can buy this totally consumer network card: https://store.mellanox.com/products/mel ... hs-r6.html and put in my totally consumer 4th gen Ryzen gaming PC.It was 10GbE time, I could have added it via TB1.
Now I use a PC, I could add 40GbE via TB3 (some cards also work with Macs).
Basically, i'd treat it as a router with a 25G Uplink (LAG) to the core switches and 12x 1G conntections, that can scale up to 10G.It is a bit unclear to me how useful it is to have 170Gbps worth of ports connected via 2x25Gbps bottleneck, and without mutual switching capability.
With switching I could see that (the device could be used as a combined router/switch) and maybe it could even do "hardware routing" similar to an L3 switch.
But with overall performance limited to ~35Gbps I don't see the point of all those 10G and 25G ports...
If you need more throughput, you'll have to wait for the CCR2016 version. Assuming the throughput scales linearly, you'd have 140Gbit routing capacity @ 1518 Bytes - close enough to wirespeed.
Personally, I see it as an upgrade for my current CCR1016-12S-1S+
Maybe it is the answer.CCR2004-1G-12S+2XS is our router with the most powerful single-core performance so far. It provides incredible results in single tunnel (up to 3.4 Gbps) and BGP feed processing.
That is what I meant. Fortunately, I have no need for such a device. In my networks, a device like the CCR1009 is plenty powerful enough.Basically, i'd treat it as a router with a 25G Uplink (LAG) to the core switches and 12x 1G conntections, that can scale up to 10G.It is a bit unclear to me how useful it is to have 170Gbps worth of ports connected via 2x25Gbps bottleneck, and without mutual switching capability.
One question for the experts though, will this router also interface @2.5 and 5 gigabit?
Due to the architecture of this thing, you better get your separate switch (like CRS326) when you want that high-performance LAN.I do have a use case personally. With WiFi6 (802.11ax), useful speeds will exceed 1 gigabit/sec. And if you have > gigabit fiber internet (dreaming is allowed) that's 2 ports in use.
Then a new NAS would likely also interface at > gigabit speeds. And hey, no separate switch needed which is a bonus if space is limited.
Are these chips from 'Annapurna labs' going to have a Long Term Support? or Another 'TILE' Incident with No New Features / Development in Future.
Oh but that happens without architecture-change! The CCR1009 line originally had 8 ethernet ports and 2 SFP slots. The first 4 ethernet ports were on a switch chip.If your network rely on a device like that has a certain number of interfaces, performance and memory, and that model suddenly vanish because of an architecture-change, then you have a problem.
Amazon has a great team for In-House Development, which Mikrotik is not very good at. We can also see this with TILE series. Facebook developed and used it for many great things, but Mikrotik never got to that point, just generic usage as a router for a long time. Slow Development and No New Features.They are an Amazon company, and Amazon uses their stuff (de Graviton & Graviton2) in AWS. I think we're pretty safe. Not to mention everybody and their dog uses the lower-end chips in things like NAS boxes and the like. They are a far cry from Tilera (for which MikroTik was pretty much the only outside customer I know of).
That is true. Sometimes I suspect that Mikrotik finds a good SoC on the market, then creates the product of it, regardless of the usage or market research.So instead of making this an architecture- or chip based problem, it is more like a product specification problem. Probably Cisco have a more rigid (and therefore sometimes more restrictive) featureset of products. But they do serve a different market too.
I agree with that! This is apparently how it works.Sometimes I suspect that Mikrotik finds a good SoC on the market, then creates the product of it, regardless of the usage or market research.
Two points:Are these chips from 'Annapurna labs' going to have a Long Term Support? or Another 'TILE' Incident with No New Features / Development in Future.
Please share Roadmaps and Support Plans so the investment can be secure.
Cheers![]()
Of course keep in mind that in most cases you will have to add about the same money for SFP modules...2. It's $600 RRP - Keep that in perspective, it is exceptional value!
Eh, depends. $24 for 10G, $59 for 25GOf course keep in mind that in most cases you will have to add about the same money for SFP modules...2. It's $600 RRP - Keep that in perspective, it is exceptional value!
I think more people would want a couple 40G ports at home than 12x 10G.That is what I meant. Fortunately, I have no need for such a device. In my networks, a device like the CCR1009 is plenty powerful enough.
(internet connections to homes and small/medium offices here rarely exceed 1Gbps and I use a separate switch behind the router)
vortex ... please do not treat us as fools and please do not lie ... once more i see such a comment and you will be bannedI think more people would want a couple 40G ports at home than 12x 10G.
this now has a way prettier name in 7.1b1: CCR2004-2G-2S+2XS-60ayDimagine a device - the ccr2004-2g-xxx - which is compact. as compact as a powerbox, maybe thicker. has decent fiberoptic options for high speed fixed backhaul.I extrapolated these codes out:
It all seems possible, but not completely logical.Code: Select allccr2004-2g-2xc-2s+/r2-60 4 Core, 2x 1G, 2x 10G/25G SFP28, 2x 10G SFP+, 2.4Ghz WiFi, 802.11ay 60Ghz
Found it.. Nice(also a reference to a lovely addition to the crs3 series is in the image, but i don't want to spoil all the fun)
npk-tools, and some traditional unix utils: find, strings, sort, grep.How do you find it, wanna see by my eyes.
I extracted find all the info that show on first page but not luck to find any reference crs3npk-tools, and some traditional unix utils: find, strings, sort, grep.How do you find it, wanna see by my eyes.
Maybe some! ->No new findings in the new beta 3?
Sent from my Moto Z3 Play using Tapatalk
Guess this are the same discovered previouslyMaybe some! ->No new findings in the new beta 3?
ccr2004-2g-2xc-2s+
ccr2004-16g-2s+
ccr2004-1g-12s+2xs
ccr2016-1g-12xs-2xq
ccr2116-12g-4s+
some new ->Guess this are the same discovered previouslyMaybe some! ->No new findings in the new beta 3?
ccr2004-2g-2xc-2s+
ccr2004-16g-2s+
ccr2004-1g-12s+2xs
ccr2016-1g-12xs-2xq
ccr2116-12g-4s+
I think the last one was a typo correct?
