WeWiNet
Long time Member
Long time Member
Enable control of "Audience" color LED via ROS
Wed Mar 04, 2020 6:19 pm
How can you control the front facing color LED of the Audience product?
Could this be enabled in future ROS release? Would be really handy for the consumer kind of product
to allow status indications to users!
normis
Re: Enable control of "Audience" color LED via ROS
Thu Mar 05, 2020 8:35 am
You can already do that, example:
/system leds
add leds=user-led:red type=on
add leds=user-led:blue type=off
This makes the LED pure red color.
WeWiNet
Long time Member
Long time Member
Thu Mar 05, 2020 12:04 pm
Normis,
when I do that command it says:
input does not match any value of led
normis
Thu Mar 05, 2020 12:30 pm
Type:
/system leds add leds=
and hit [? ] on the keyboard.
or hit [TAB] twice. It will offer choices. Also make sure you have upgraded RouterOS to the latest.
rextended
Wed Jul 28, 2021 3:32 pm
/system leds
Please, can provide more detail about "user-led:red" ?
I have test on Audience RBD25G-5HPacQD2HPnD first revision (not /r2 or /r3 if any)
I try Audience with original factory 6.45.4, 6.47.10, 6.48.3, 6.49beta54 and with 7.1beta6
and no one version have user-led exposed for be configured on any way, CLI or WinBox, no differencies.
Very thanks!
rextended
Tue Aug 03, 2021 11:59 am
Normis, please, can you reply to my previous post?
Thanks.
normis
Tue Aug 03, 2021 12:08 pm
Still working for me. What is your error?
normis
Tue Aug 03, 2021 12:13 pm
If you don't see any LEDs in the droplist, post your Audience serial number and I will investigate more
rextended
Tue Aug 03, 2021 12:18 pm
Two devices:
# aug/03/2021 11:15:49 by RouterOS 6.47.9
# software id = T4TG-88JY
# model = RBD25G-5HPacQD2HPnD
# serial number = BBQRXN59A5D4
i cant'read the /xxx on the box because is on remote location
second device 6.48.3 with same "problem":
serial number = BBQRXNC7D2E0/937
device on same order of previous
Very thanks!
Edit: ;)
normis
Re: Enable control of "Audience" color LED via ROS  [SOLVED]
Tue Aug 03, 2021 12:38 pm
Looks like in newer revisions the LED is no longer software controlable, as it's made differently now, with hardware assigned functions. Sorry, no longer adjustable.
Front status LED behavior
Solid blue – the device is powered on.
Blinking green – the device is in Access Point mode and waits for another Audience device to be connected.
Blinking amber (Red + Green) – the device searches and tries to connect to another Audience device.
Solid green – the device has established a connection in an Audience network.
Blinking Red – the device runs radar detection for Dynamic Frequency Selection (DFS).
https://help.mikrotik.com/docs/display/UM/Audience
rextended
Tue Aug 03, 2021 12:49 pm
Not worry, just a cosmethic thing.
Very thanks.
Now I'm sure of what I see ;) :lol:
MircoADM
Fri Mar 24, 2023 9:57 am
where can i find a manual that is correct for the audience?
When using it with 3 working APs (1 x 2,4g and 2 x 5g wifi band) the LEDs are on in different colours.
Sometimes the LED is blue, sometime the LED has a amber colour etc.
Only 1 point in the manual are correct:
1. Booting > blue
Is there an manual about the LEDs in operational mode of the device?
Hint(no wifiwave 2 driver and no CAPSMan used):
the colour changes to "amber" when the wifi-clients on 2 APs connected while 1 AP is unused.
When clients connected on all 3 APs the LED goes to blue.
Is there a manual about the "operational modes" ?
Greets
Users browsing this forum: No registered users and 163 guests
