robertEIT
CAP AC with VLANs on wifi and on ethernet interfaces
Thu Mar 05, 2020 10:11 pm
Hi guys!
I'm trying to set up a CAP AC to use VLANS, one for private staff WiFi and ethernet LAN and another VLAN for guests WiFI only.
I have a HEX configured with 2 VLANS, vlan100 wich has a DHCP 192.168.2.1/24 and vlan200 wich has DHCP 10.11.12.1/24 both on eth2 port, trunk port.
What I'm trying to do is get eth1 of CAP AC as trunk port, Staff WiFi on VLAN100, Guests WiFi on vlan200 AND eth2 port of the CAP AC as access untagged port with vlan100 so I can connect another device like a PC that the staff uses.
I managed to get almost everything working using this guide, did all steps under R2 section - https://wiki.mikrotik.com/wiki/Manual:VLANs_on_Wireless but I can't get eth2 port of the CAP AC to act as access port carying vlan100 only.
I'm attaching a diagram
Here is my config:
interface bridge print
 0 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled
     arp-timeout=auto mac-address=C4:AD:34:8D:2C:4A protocol-mode=rstp
     fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m
     priority=0x8000 max-message-age=20s forward-delay=15s
     transmit-hold-count=6 vlan-filtering=yes ether-type=0x8100 pvid=1
     frame-types=admit-all ingress-filtering=no dhcp-snooping=no
interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE           VLAN-IDS  CURRENT-TAGGED          CURRENT-UNTAGGED
 0 D bridge1          1                                 bridge1
                                                        ether1
                                                        ether2
 1   bridge1          100       ether1                  ether2
 2   bridge1          200       ether1
interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE      BRIDGE         HW  PVID PR  PATH-COST INTERNA...    HORIZON
 0     ether1         bridge1        yes    1 0x         10         10       none
 1 I   wlan1          bridge1               1 0x         10         10       none
 2 I   wlan2          bridge1               1 0x         10         10       none
 3     ether2         bridge1        yes    1 0x         10         10       non
anav
Re: CAP AC with VLANs on wifi and on ethernet interfaces
Fri Mar 06, 2020 3:42 am
I have a similar setup.
MT Router to 24 port Dlink switch to Capac
MT Router to 6 port 260GSP MT switch with port 3(POE) going to capac.
Now my CapaCs each have 3 vlans going into them
upstairs guest 5gh virtual of chain1
houselan 5gh CHAIN1
smartdevices 2ghz CHAIN2
I dont use the second etherport on my CAPACs but it wouldnt be hard simply to add that port to the mix. Since its going to a PC Im assuming an access port.
Let me see if I can dig up a useable config or least one for demo.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
anav
Fri Mar 06, 2020 4:18 am
ROUTER
add admin-mac= auto-mac=no comment=defconf name=HomeBridge \
    vlan-filtering=yes
/interface vlan
add interface=HomeBridge name=Guests_cap1_V100 vlan-id=100  (my guest  vlan for guest 5ghz WLAN)
add interface=HomeBridge name=Home-LAN_V110 vlan-id=110   (my homevlan used for wired and wifi)
add interface=HomeBridge name=SmartDev_cap1_V50 vlan-id=50  (my smart devices vlan for smart devices wifi)
add bridge=HomeBridge ingress-filtering=yes interface=ether2  (trunk port to my switches, in our case the ether port going to the Capac)
/interface bridge vlan
add bridge=HomeBridge tagged=HomeBridge,ether2 vlan-ids=\
    110,100,50
CAPAC
Wifi Interfaces besides the physical ports eth1,eth2
WLAN1- Devices
WLAN2- HomeWIFI
WLANVirtual - VisitorWIFI
add admin-mac= auto-mac=no comment=defconf name=\
    bridgeCap vlan-filtering=yes
/interface vlan
add interface=bridgeCap name=Guests_WIFI vlan-id=100
add interface=bridgeCap name=Wifi_SDevices vlan-id=50
add interface=bridgeCap name=homevlan vlan-id=110
add bridge=bridgeCap comment=defconf frame-types=admit-only-vlan-tagged \   (this is the trunk port coming from the HEX in your case)
    ingress-filtering=yes interface=ether1
add bridge=bridgeCap comment=defconf frame-types=\   (this is for wlan1 and is an access port)
    admit-only-untagged-and-priority-tagged interface=Devices pvid=50
add bridge=bridgeCap comment=defconf frame-types=\   (this is for wlan2 and is an access port)
    admit-only-untagged-and-priority-tagged interface=HomeWIFI pvid=110
add bridge=bridgeCap frame-types=admit-only-untagged-and-priority-tagged \  (this is for my virtual wifi running off wlan2 and is an access port)
    interface=VisitorWIFI pvid=200 trusted=yes
add bridge=bridgeCap comment=defconf admit-only-untagged-and-priority-tagged \   (access port toyour PC).
interface=ether2 pvid=110
add bridge=bridgeHallway tagged=ether1 untagged=Devices vlan-ids=50
add bridge=bridgeHallway tagged=ether1 untagged=VisitorWIFI vlan-ids=200
add bridge=bridgeHallway tagged=ether1,bridgeCAP untagged=eth2,HomeWIFI vlan-ids=110
/interface wireless (for completeness to understand the above config)
set [ find default-name=wlan1 ] band=2ghz-g/n basic-rates-b="" country=canada \
    disabled=no distance=indoors installation=indoor mac-address=\
    mode=ap-bridge name=Devices rate-set=configured \
    scan-list= security-profile=devices_only ssid=SMART \
    supported-rates-b="" wireless-protocol=802.11 wmm-support=enabled \
    wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=2 band=5ghz-a/n/ac \
    channel-width=20/40mhz-Ce country=canada disabled=no mode=ap-bridge name=\
    HomeWIFI rate-set=configured scan-list= \
    security-profile=upstairs_wifi ssid=5GHome_CellPhones wireless-protocol=\
    802.11 wmm-support=enabled wps-mode=disabled
add disabled=no mac-address= master-interface=HomeWIFI \
    name=VisitorWIFI security-profile=HouseGuests ssid=Guest_Wifi \
    wds-cost-range=0 wds-default-cost=0 wmm-support=enabled wps-mode=disabled
robertEIT
Mon Mar 09, 2020 11:06 am
ROUTER
    vlan-filtering=yes
/interface vlan
    110,100,50
CAPAC
WLAN1- Devices
WLAN2- HomeWIFI
/interface vlan
    wps-mode=disabled
I tried your config but as soon as I apply settings to /interface bridge port I loose connection to the CapAC and can't get it back either via WiFi, ether1 or ether2. I'm doing something wrong or the order is wrong.
UPDATE:
I managed to make it work in the sense that I had VLAN100 on my wlan1 and eth2 and VLAN200 on wlan2.
Eth1 served as trunk port, connected to a switch BUT I can no longer manage the CapAC using winbox\webfig from either vlan\port, it doesn't appear in Winbox at all. I'm missing something related to assigning an IP or management interface. I want to be able to config the CapAc from within private LAN wich is vlan100 and assign an IP to it, 192.168.2.3.
anav
Wed Mar 11, 2020 6:50 pm
My CAPACs get their DHCP structure from my private LAN, lets say vlanxx.
Not sure how I set that up come to think of it????????
The best document for config understanding is this one, check out thread #4 which is for Access points.
viewtopic.php?f=13&t=143620
anav
Wed Mar 11, 2020 6:53 pm
Okay reading the reference here is potentially the key point........
# egress behavior
# Purple Trunk. L2 switching only, Bridge not needed as tagged member (except BASE_VLAN)
set bridge=BR1 tagged=ether1 [find vlan-ids=10]
set bridge=BR1 tagged=ether1 [find vlan-ids=20]
set bridge=BR1 tagged=ether1 [find vlan-ids=30]
add bridge=BR1 tagged=BR1,ether1 vlan-ids=99[
Based on that the config has looks okay.
But I may have set my capac IP up manually........
anav
Wed Mar 11, 2020 7:20 pm
Okay make sure you are tagging ether1 as well on the AP bridge!!
add bridge=bridgeCap tagged=bridgeCap,eth1,eth2 untagged=WLAN1 vlanid=100
robertEIT
Fri Mar 13, 2020 10:41 am
I eventually managed to make it work via this config:
add frame-types=admit-only-vlan-tagged name=bridge1 vlan-fil
add bridge=bridge1 ingress-filtering=yes interface=ether1
add bridge=bridge1 frame-types=admit-only-untagged-and-prior
100
200
100
add bridge=bridge1 tagged=ether1,bridge1 untagged=wlan1,ethe
add bridge=bridge1 tagged=ether1 untagged=wlan2 vlan-ids=200
I assigned and IP on VLAN100 interface, added a 0.0.0.0 route to 192.168.2.1 (my router) and also DNS to 192.168.2.1 (my router). I can now see the CapAc in winbox
add address=192.168.2.3/24 interface=vlan100 network=192.168.2.0
set servers=8.8.8.8
add distance=1 gateway=192.168.2.1
/ip service
set winbox address=0.0.0.0/0
I don't know if this is the optimal way, will tweak it more as I learn more
angriukas
Fri Mar 13, 2020 11:19 am
Maybe I am wrong, but I do not see the needs of VLAN if communication between CAP and CAPsMAN are on L2.
It's enough to have two bridges in CAPsMAN, first one for LAN, second one for guests, with own dhcp server for each bridge.
You can control traffic between bridges in CAPsMAN with firewall.
Same can be achieved with VLAN's of course. But more simple config - less head pain :)
robertEIT
Fri Mar 13, 2020 11:37 am
For this application I didn't use CapsMAN. I use 2 VLANs because there are other TP-Link APs in the LAN with VLANs assigned to each SSID + wired devices for guests and staff. I also needed the eth2 port of the CapAC to serve as access port into private LAN (vlan100). Maybe there is a way to do this CapsMAN. I have a spare AC2 + another CapAC, I'll set them up this weekend and play with them, it would be great to achive this with CapsMAN as it will allow easy deployment of more future CapACs.
Do you have a sample config?
angriukas
Fri Mar 13, 2020 12:57 pm
This is sample only, for lan and for guest. You cannot use this file as script because I have replaced sensitive info (include MAC addresses).
robertEIT
Fri Mar 13, 2020 1:51 pm
I'm trying to understand the attached config your provided.
So in here
add admin-mac=44:44:44:44:44:44 auto-mac=no name=bridge1-lan
add name=bridge2-guest
What ports would add to those bridges? Let's consider a RB960 with eth1 as WAN, eth2-5 as LAN. Guests WiFi should have their own DHCP server in a different subnet. I will then use the firewall to restrict access.
angriukas
Fri Mar 13, 2020 2:28 pm
In general - yes.
CAPsMAN by config in 'data path' will add cap interfaces to the appropriate bridges.
eth2-5 -> bridge-lan, also DHCP server on this bridge for lan IP's like: 192.168.0.0/24
Then seconds DHCP on bridge-guest like: 192.168.40.0/24
In firewall:
allow DNS requests for guests:
/ip firewall filter add action=accept chain=input comment="accept DNS for guests" dst-port=53 in-interface=bridge-guest protocol=udp
block access to router from guest
/ip firewall filter add action=drop chain=input comment="Drop guests to router" in-interface=bridge-guest
drop guests to lan:
add action=drop chain=forward out-interface=bridge-lan in-interface=bridge-guest
Note:
this is the way you have to move, because you still have to understand what are you doing: add router IP for both networks, create ip pools, check routes and etc...
Users browsing this forum: No registered users and 47 guests
