emils
Forum Veteran
Forum Veteran
Winbox v3.22 released!
Wed Mar 11, 2020 12:21 pm
What's new in v3.22:
*) added 24x24 and 32x32 icon support (RouterOS v6.47 required);
*) added Legacy Mode (disabled by default) to allow using older, less secure connections to RouterOS older than v6.43;
*) added scroll bar support in item property windows;
*) added support for super low DPI - 72, accessible by Zoom Out;
*) fixed Log window drawing on HiDPI displays;
*) fixed Zoom In/Zoom Out setting persistence after window is closed;
*) made table row height 15px by default;
*) use monospace font for big pop-up messages;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
roe1974
Re: Winbox v3.22 released!
Wed Mar 11, 2020 12:50 pm
winbox64 is always opnening in a small window.....see picture :-(
emils
Forum Veteran
Forum Veteran
Wed Mar 11, 2020 12:55 pm
The window size should be stored in session file. Make sure you have autosave on or save the session before closing.
roe1974
Wed Mar 11, 2020 12:59 pm
auto-save is enabled ..... also tried save it manually .... no change :(
PS: Also winbox itself starts every time on the left corner of the desktop ......
System: Windows 10(1909) 64Bit
strods
Wed Mar 11, 2020 1:16 pm
Is the only problem the size? Are, for example, opened windows re-opened? Are you sure that you have launched WinBox loader with administrator privilegies, session is selected on WinBox loader before you access router (is not set to "<none>")?
Chupaka
Wed Mar 11, 2020 1:19 pm
I'm in love with new Log window :)
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Wed Mar 11, 2020 1:23 pm
I am not experiencing the same, Windows 10 version 1803
CZFan
Wed Mar 11, 2020 1:24 pm
Ditto :-)
roe1974
Wed Mar 11, 2020 1:28 pm
yes, only problem is the size
when i have rezized the session and put it on the taskbar an re-open the session ... size is OK ... closing the session and reopen with winbox loader ... size is small
no change if starting with or without admin privileges
i start winbox loader an double click the saved connection ....
richard
Sob
Wed Mar 11, 2020 2:09 pm
There's a bug with read-only fields and copying to clipboard. I discovered it when I tried to copy log messages (after double clicking line in log window), but it's actually not new, same happens also in older WinBox with other fields:
- If I double-click the field to select whole text (A) and try to copy it to clipboard using keyboard shortcut (Ctrl+Ins / Ctrl+C), it works correctly.
- When I select only part of text (B) and try to copy it, keyboard shortcuts don't do anything. Copying from context menu (right click on selected text, Copy command) works.
Then there's tiny little detail about font in system note popup, it's much wider than in Terminal. IMHO it would look better it used the same one, i.e. what is now in Terminal should be also in popup (definitely not the other way around). Just for the record, it's no biggie.
Other than this, everything is perfect. :)
anav
Wed Mar 11, 2020 2:16 pm
Only MT nerds would be in love with 0s and 1s displayed on the log palette ......... ;-P
As for me, same same, garbage looking as per the previous version :-((
gemesif
Wed Mar 11, 2020 2:23 pm
Thanks for MikroTik, the professional works. :D
roe1974
Wed Mar 11, 2020 2:34 pm
i deleted all files in C:\Users\xxxx\AppData\Roaming\Mikrotik\Winbox\sessions and C:\Users\xxxx\AppData\Roaming\Mikrotik\Winbox and started winbox from stretch.
issue persists .....
OS: Windows 10 Version 1909 (Build 18363.719)
Richard
normis
Wed Mar 11, 2020 2:45 pm
did winbox re-create those deleted files? meaning, did winbox actually save something new in session file?
complex1
Wed Mar 11, 2020 2:52 pm
No issues here, running fine on Win10 1909 b18363.719
roe1974
Wed Mar 11, 2020 2:53 pm
yes ... new files are here
back to 3.20 .. everything is normal .... window positioning works.....
then back again to 3.22 .... opening first time the winobox ... position OK ... opening first session ..... position OK
closing session&winbox .... opening winbox /session again ... position not OK ... and stays not OK .... strange :(
Richard
PS: Resolution 3840 x 2160
strods
Wed Mar 11, 2020 2:57 pm
Can you please send this session file to support@mikrotik.com?
roe1974
Wed Mar 11, 2020 3:11 pm
mail sent :-)
br, Richard
td32
Wed Mar 11, 2020 3:23 pm
I confirm session windows inside main winbox windows are saved but their size seams to be restored to a kind of default preset size at each start
first start windows set up
on new session, also the same on winbox restart
roe1974
Wed Mar 11, 2020 3:28 pm
session window full-screen works and is saved......
but all between "wrong-small-size" window and full-screen is not saved.....
Richard
roe1974
Wed Mar 11, 2020 3:29 pm
FYI:
MikroTik support #[SUP-10870]
Richard
nishadul
Wed Mar 11, 2020 3:43 pm
Thank you for new Log Window.
** In Log Window, # column align need Left OR Center because # and Time is show very near/close.
** Zoom In and Zoom Out need shortcut key as like: Ctrl +, Ctrl -
w0lt
Long time Member
Long time Member
Wed Mar 11, 2020 4:53 pm
Also, when upgrading the firmware, within the "Routerboard dialog box", the message to reboot your computer to activate firmware is off centered.
Paternot
Wed Mar 11, 2020 5:16 pm
Linux + Wine here.
Windows opens with the last used size and position.
roe1974
Wed Mar 11, 2020 9:18 pm
tested another machine (Also Lenovo Laptop) with same Win10 Version .... same issue :(
I have on both laptops german localization .....
Richard
mszru
Wed Mar 11, 2020 10:37 pm
The issue with Winbox window position and shuffled windows inside the Winbox itself is caused by the scaling factor in the display settings.
If you set it to 100%, you won't see any issues. In my case it is set to 125%...
MichalPospichal
Wed Mar 11, 2020 10:51 pm
I also confirm that saved opened windows inside Winbox are always reverted to some default sizes after each login. I have scaling set at 100%, 2K display.
roe1974
Wed Mar 11, 2020 11:10 pm
Richard
OK ... Windows 10 Display scale factor set to 100% and there is no problem.
when i set the scale to 125% or 150% (as i use the notebook) the issue is back :(
Richard
macsrwe
Thu Mar 12, 2020 2:10 am
Yes, outermost window size is saved with session file, but zoom level is not. Yes, I no longer have to drag the window larger before zooming it, but I still have to zoom it ^3 every time. Please fix this!!
Ironic that recent "lawyer" change that forced user to "acknowledge" contents of system note before allowing him to do anything, is now nullified by making system note entirely unreadable without microscope. User is not even allowed to zoom the system note, he must first close it! :-/
On another note, I do appreciate the expandable log window columns finally. Thank you.
nichky
Thu Mar 12, 2020 4:43 am
*) added Legacy Mode = means to get access to device which have older version ROS version,is that correct?
anav
Thu Mar 12, 2020 5:48 am
I can confirm that when I rescale my display from extra large for my old eyes 200% down to teeny weeny 100% size, the log files do not overlap.
How do I get the log files to appear normal and maintain larger fonts sizes etc........ ????
I dont have this problem with other things like notepad++ for example!
Kindis
Thu Mar 12, 2020 10:49 am
All the issues I had with scaling is now gone as far as I know BUT i noticed something before. I run a 2 monitor setup with one 4K (laptop) and the other 1440 (external screen).
If I had the problem where I could not read the logs on either screens dragging the winbox window from one screen to the other and then back again would solve this issue for me.
When you do that Windows re-scales the window according to that screen and it made everything "readable" again on both screens.
conrad
Thu Mar 12, 2020 11:08 am
I confirm it too
DenisPDA
Thu Mar 12, 2020 11:43 am
Enable Autosave Session and check the Autosave on Close checkbox is checked.
normis
Thu Mar 12, 2020 11:44 am
We have repeated the issue. It happens if Windows window scaling is used together with Winbox zoom. Autosave no longer works. We will try to fix it ASAP.
roe1974
Thu Mar 12, 2020 11:49 am
thx a lot !
sid5632
Long time Member
Long time Member
Thu Mar 12, 2020 12:17 pm
I'm still getting this flip-flopping of window sizes when starting winbox64.exe (on Wine under Linux Mint 19):
creating Window Class routeros_null
creating Window Class routeros_connect
DPI=100
EMS=13
ERROR: bad bmp format id=2329
biPlanes=1, biBitCount=1, biCompression=0
ERROR: bad bmp format id=3329
creating Window Class routeros_dbl_canvas
 discovery started
then
DPI CHANGED to 120
rescale font 100 to 120
EMS=16
 discovery started
then
 discovery started
etc.
I also get the window pinned to 0,0 regardless.
Connecting to an actual router gives a window sized roughly 460x260 or 440x240 (depending on the above flip-flip).
This is worse than 3.21, which was itself bad. The last version that worked even vaguely properly was 3.20 (on Wine on Mint).
On Windows (7 - 64) it all seems to work properly for me, but I don't have any funky scaling settings.
mszru
Thu Mar 12, 2020 12:32 pm
Dear MT!
Would you consider changing the first column in the Log window to the running number?
Currently those numbers are from 0 to 999 and when the log is full (all 1000 lines populated) the specific log message will get a new number from the previous log entry with every new entry added. From my perspective the log entry number should start from 0 after a device reboots and should never be changed for a specific log message.
Does it make sense to you or anyone else here?
Thank you!
Sob
Thu Mar 12, 2020 2:59 pm
One cosmetic problem, optional fields have wrong vertical centering. With small zoom the text is too much to top, while with big zoom it's too much to bottom. It happens everywhere for this field type. Other fields (simple edits, dropdowns) have it correct.
tippenring
Thu Mar 12, 2020 3:27 pm
Dear MT!
Thank you!
I agree that the # column isn't necessary. The numbers are meaningless if they change which message they are associated with for every event. However, I do really like that I can select, open properties, and copy content from the log window now. Definitely need to keep that.
brotherdust
Thu Mar 12, 2020 8:35 pm
Normis, does this mean that Winbox will honor the scaling setting so that I don't have to zoom every time I open a new session?
Thanks!
Zwodka
Thu Mar 12, 2020 10:31 pm
So am I :-)
rushlife
Fri Mar 13, 2020 7:17 am
for what exactly ?
btw. still no native version for mac and linux, still no shortcuts implemented :-( ,
otherwise - thanks for new version, is great, appreciated...
tpedko
Fri Mar 13, 2020 1:40 pm
add ctrl+c ctrl+v in the console
Sob
Fri Mar 13, 2020 2:31 pm
Ctrl+C already works for aborting commands. But it could probably have double use, where copying would work when there's some selected text. Or there are also safe non-conflicting Ctrl+Ins and Shift+Ins (my favourite, but those currently don't work in Terminal either).
Chupaka
Fri Mar 13, 2020 3:01 pm
Shift+Ins in Terminal works at least in Wine for MacOS.
Sob
Fri Mar 13, 2020 3:26 pm
Great, that's half of the work done. It would be real shame to not add Ctrl+Ins now. ;)
pe1chl
Fri Mar 13, 2020 3:49 pm
I would still very much like to see the following changes:
- easier widget for selection of columns (a modal panel with checkmarks for all possible columns in a "square" layout where multiple checkmarks can be toggled before clicking OK)
- some way to raise windows that are covered by another window that has opened on top of it, e.g. a set of "window buttons" in the dashboard bar or some mouse action to "lower" the current window so other existing windows may appear on top of it.
pcunite
Fri Mar 13, 2020 11:37 pm
Agreed, takes way to much effort to deselect all the FP* columns, across multiple forms.
bda
Sat Mar 14, 2020 3:25 pm
Good day.
Some new bugs:
1. interface window resises to default size, even afer manual resize.
2. same for partition window.
pe1chl
Sat Mar 14, 2020 4:43 pm
Good day.
Some new bugs:
Not here...
MTeeker
Sat Mar 14, 2020 10:58 pm
Good day.
Some new bugs:
Same here. I experienced this resizing for the first time since switching to Winbox 3.22 (64 bit).
pe1chl
Sun Mar 15, 2020 1:38 pm
Moving items and changing column widths has become unstable!
When moving an item or changing a column width and keeping mouse button pressed for a while to find new suitable position, it suddenly jumps to completely wrong position.
I think this happens when the screen is updated in the meantime, e.g. to show updated counters in firewall view.
bda
Mon Mar 16, 2020 5:16 pm
Weird.... Plus auto windows resize...
I am waiting for a fix...
mpadmin
Mon Mar 16, 2020 6:45 pm
Good day.
Some new bugs:
Same here on Windows 10. Also the last (and most important one) line of the log is very hard to read - it almost always stay "between" lines, auto scroll doesn't always work. I hope that bugfix version will be released.
brotherdust
Mon Mar 16, 2020 8:56 pm
Can I just make a suggestion here? Why not re-write Winbox with something like Qt framework? It has all this Hi-DPI nonsense already solved.. it's built in. Bonus: Winbox would become cross-platform! I guess it couldn't be called Winbox anymore, huh?
sid5632
Long time Member
Long time Member
Tue Mar 17, 2020 12:53 pm
Yes, I'm seeing that too. Most irritating.
Abdock
Tue Mar 17, 2020 7:46 pm
how do i get winbox old version?
SiB
Tue Mar 17, 2020 9:21 pm
emils
I still must run WinBox 6.4 for manage old ROS v5.26 who cannot be upgraded to v6.x family.
It's still not that mouse scroll :(
Then what mean this point ??
Old bug with firewall chain's popup still exiting monitor
It;s to big, but font it's now monospace like CLI, thanks!.
other
Logs with Filtering and Searching feature are awesome!.
CTRL+G not select the current entry log and you not know what rule is currently selected !
andriys
Tue Mar 17, 2020 10:40 pm
emils
What is WinBox 6.4?
Anyways, RouterOS 5 requires WinBox DLLs to be downloaded from the router. That was removed in WinBox 3.13 (and for a reason!) and has nothing to do with this "legacy connection mode".
By the way, what stops you from upgrading from RouterOS 5.x?
Property windows are not drop-down menus. Property window is what opens when you double-click on an item in the interface list, or a rule in the firewall rules window, etc.
And scroll bar is not a mouse wheel either!
owsugde
Wed Mar 18, 2020 1:08 pm
Looking good so far! 3.22 seems to be the version 3.21 was supposed to be. DPI problems all but vanished, as far as I've seen yet.
Add: Well except the fact that if you reconnect, the window is always reset as tiny size and everything is smashed together. That's not so great a thing.
Caci99
Wed Mar 18, 2020 6:22 pm
One learns a new thing everyday. Thanks Chupaka for the tip :)
hngjared
Wed Mar 18, 2020 7:58 pm
Thank you for fixing log window!
owsugde
Thu Mar 19, 2020 10:48 am
It absolute does this, just not for all connections / remote devices. I wasn't able to isolate what actually causes this yet. Never happened before 3.22.
Please test around a little with this. It's a very annoying bug that wastes a lot of time and nerves.
Trezona
Sat Mar 21, 2020 4:35 pm
Where can i find the 3.21 version of winbox?
w0lt
Long time Member
Long time Member
Sat Mar 21, 2020 6:59 pm
Trezona
Sat Mar 21, 2020 8:28 pm
bda
Sun Mar 22, 2020 4:01 pm
DPI problems are mostly here. If using 2k resolution with scale of 125-150 percents - all winbox windows and text looks weid.
Plus strange inner winbox windows resize bug.... Weird...
vv22
Sun Mar 22, 2020 10:06 pm
Textbox with red text lost binding to the left side.
Winbox 3.22.
rushlife
Mon Mar 23, 2020 8:10 am
Hi to all of you, especialy MIkrotik team :-).
I would be awesome use these quarantene days for making dedicated versions of winbox ( for linux / os x ).
Social distancing and lots of home office workers leads to make their working hours productive at least a little....
Chupaka
Tue Mar 24, 2020 2:41 pm
What's non-productive in Wine?
rushlife
Tue Mar 24, 2020 5:38 pm
distorted fonts and slowness
don't even mention obligate to install bunch of software (over 1GB) because one small binary (about 2MB)
Chupaka
Tue Mar 24, 2020 10:18 pm
YMMV, but it works fast and smooth for me :)
ghostt
Wed Mar 25, 2020 9:38 am
Yes, winbox is being launched with administrator privileges. What happens is this, all windows are opened, reopen on the next winbox session. But they are resized automatically if they are smaller then their some kind of default size.
For example. Even within one winbox session, If ip-addresses window is opened, resized to a small window, and closed, on re-opening it is bigger then it was set to. It's not a biggie, but could be quite annoying if you have a lot of windows opened and arranged on a screen, especially working from a laptop on a customer site.
Version 3.20 didn't have that issue. So far it's a decider for what I need, so rolling back to 3.20
Kind regards.
bda
Wed Mar 25, 2020 10:31 pm
Kind regards.
It is true. Same here. And weird artifacts on high DPI monitors with windows interface scaling. It is very bad!!!
Please, Mikrotik - do something!
robmaltsystems
Forum Veteran
Forum Veteran
Thu Mar 26, 2020 10:33 am
>added LegacyMode (disabled by default) to allow using older, less secure connections to RouterOS older than v6.43;
For the record, how has the security been improved in the later versions? Or maybe, why is the legacy mode insecure?
andriys
Thu Mar 26, 2020 10:49 am
In legacy mode server identity validation is not implemented, thus making MITM attacks possible even if "Secure Mode" is enabled. The current implementation of the WinBox protocol was reported to use a flavor of SRP, so identity validation is now always mutual. Plus this "Secure Mode" can no longer be turned off.
freemannnn
Forum Veteran
Forum Veteran
Thu Mar 26, 2020 2:17 pm
when you hover over the "show columns" please make it not to have to click x times to reach what you want. just to scroll automatically.
pe1chl
Thu Mar 26, 2020 2:28 pm
This is why that long list should be replaced by a square input form with multiple columns of column names and associated checkmark...
Added advantage is that you can select all the columns you need in one go, so you don't have to open it 4 times to get rid of those 4 useless FP columns, for example (as you already did).
freemannnn
Forum Veteran
Forum Veteran
Thu Mar 26, 2020 2:45 pm
i second this.
SiB
Thu Mar 26, 2020 3:12 pm
If not checkbox, then the CTRL + Click should on/off options.
Additional should be possible to use Mouse Scrool !.
I do that setup ones what is save in WinBox Session !. I have few sessions dedicate on differ platform/models.
pe1chl
Thu Mar 26, 2020 4:20 pm
i second this.
To answer your original remark: you can go to the end of the list by pressing the End key (and to the top by pressing the Home key).
But in remains a difficult UI.
SiB
Thu Mar 26, 2020 6:15 pm
pe1chl
True.
In my Win10 the Home/End not work.
Only pressing letter few times do a skip by all that entry with that letter at start. Maybe in new WinBox...
pe1chl
Thu Mar 26, 2020 8:02 pm
Home/End has always worked for me, but I am only using winbox under wine (in Linux). Maybe the Home/End is a feature of wine rather than winbox?
raffav
Thu Mar 26, 2020 8:58 pm
I think the legacy mode msg it would be great if it tell you where to find it I.E Enable it on Tools, Legacy mode
DragosStanescu
Sun Mar 29, 2020 8:28 pm
Hey guys!
I have a problem connecting to a mAP Lite, it says: ERROR: router does not support secure connection, please enable Legacy Mode, if you want to connect anyway.
Does anybody know how to activate Legacy Mode, or bypass that error? I am using Winbox V3.22.
Thank you!
Sob
Sun Mar 29, 2020 8:46 pm
Tools->Legacy Mode
DragosStanescu
Sun Mar 29, 2020 11:00 pm
Thank you.
fengyuclub
Mon Mar 30, 2020 10:19 am
Why the font of my winbox is different from yours, how can I use arial font, only the menu bar is arial font.
psannz
Mon Mar 30, 2020 10:47 am
Yes! This. It would make life quiet a bit easier.
leonardovescovo
Mon Mar 30, 2020 4:03 pm
for what exactly ?
Native version for iPad too.
sev
Tue Mar 31, 2020 1:43 am
Gee, I thought I'm the only one loosing my mind with these windows resizing all over the place. But with same behavior on 3 win10 laptops I started googling - so hello erbody :)
Guess imma wait patiently for a fix tho. Peace
bda
Wed Apr 01, 2020 12:15 am
True, bro... Weird resizing too damn crazy!!! Peace too
Dear Mikrotik developers. Please, fix crazy resizing circus!!! Please!!!
bda
Thu Apr 02, 2020 5:57 pm
Sorry, but any news on fixing bugs with inner windows resizing?
pe1chl
Thu Apr 02, 2020 6:27 pm
I went back to 3.21
At first things looked bright but the problems with column resizing and row movement on busy windows like firewall filter are just too severe.
w0lt
Long time Member
Long time Member
Thu Apr 02, 2020 7:47 pm
I went back to 3.21
Ditto !! :( :(
conrad
Fri Apr 03, 2020 12:31 am
RogerWilco
Mon Apr 06, 2020 7:06 am
Coming up a month after 3.22 was released... any ETA on when the window resizing will be fixed. It is very annoying when you have a dozen windows open.
xsoft
Mon Apr 06, 2020 4:59 pm
Thanks you.
After several test-cases I can confirm, that there is a but in 3.22 version when storing windows location/position/size to session file.
With 3.21 it works as designed (no bug).
Simple test case is to open 4 windows, resize them to smaller size, and layout all 4 fex px from each other.
Save and load session. 3.22 will NOT respect windows size/position, 3.21 will.
(winbox on fullscreen, windows 10)
bda
Tue Apr 07, 2020 12:11 am
Thanks you.
Thanks! I think, that another bug is wrong size (and font font size) of main winbox window on hi res display with main OS interface resize to more than 100%, even 125% and winbox go crazy...
Kraken2k
Tue Apr 07, 2020 12:38 pm
yeah... every time you open the firewall rule edit window, it increases it's height until it fills the whole window. It drives my crazy after quite short time of work.
sterod
Tue Apr 07, 2020 6:29 pm
^- THIS!
dmitris
Tue Apr 07, 2020 11:52 pm
Hi all, i'm alone who have problem with winbox64 v3.22 and v3.21 on MacOS Catalina 10.15.4? To be precise i can't connect to any Mikrotik with latest ROS. Winbox window is splashing for a second and nothing happens. In Mikrotik log i see that user loged in and logout by winbox. Any ideas how to solve ?
btw.
Winbox64 3.20 works fine.
ghostt
Wed Apr 08, 2020 10:08 am
ghostt
Wed Apr 08, 2020 10:13 am
Thanks you.
Windows version, full / windowed screen don't matter. I've tested that on multiple Windows machines (7, 7 Pro, 10, 10 Pro). The same thing is happening. Smaller the screen, more annoying the problem :)
RFS
Thu Apr 09, 2020 4:38 am
Здравствуйте! На моем нетбуке разрешение экрана 1024х600, и в Winbox внизу не видна кнопка "Connect" к WiFi, она просто не помещается. И прокрутки нет, и масштаб не изменить.
(Windows7x32)
Hello! My netbook has a screen resolution of 1024x600, and in the Winbox below the "Connect" button to WiFi is not visible, it just does not fit. And there is no scrolling, and the scale cannot be changed. (Google translate)
ghostt
Thu Apr 09, 2020 7:51 am
(Windows7x32)
Привет! Попробуй предыдущие версии Winbox, 3.21 или 3.20
gemesif
Thu Apr 09, 2020 4:43 pm
(Windows7x32)
I'm afraid, Winbox will not working good, in such low resolution...
May be solution the Webfig:
https://wiki.mikrotik.com/wiki/Manual:Webfig
by default:
http://192.168.88.1/
bda
Fri Apr 10, 2020 12:52 am
Not only firewall, interfaces, but partitions, pools. And crazy inner window resizing!
kd2pm2
Fri Apr 10, 2020 3:09 am
I have to believe that cloud backup will be part of winbox in the next release. Just a tad annoying to do it in the terminal
corp9592
Wed Apr 15, 2020 2:54 pm
Oof... I believed that I was going crazy with the zooming issue.
I had to goo back to 3.20 to avoid any of the scaling issues. Thank God MT at least has older versions online, though it would not make any harm to make them available in the website under the Download Archive section.
As a software developer, I am starting to think that WinBox is becoming release after release a little bit more outdated. Sure it is not intended to have cutting edge UI/UX techniques, but the minimum UI tricks and perks, such as ctrl+scroll to zoom in/out, able to resize columns, resize subwindows using the secondary mouse button, sticky subwindows to allow "mosaics", ctrl-c, ctrl-v everywhere...
bda
Wed Apr 15, 2020 4:59 pm
Still waiting for new version.... But one good news - more and more CLI experience...
macsrwe
Wed Apr 15, 2020 8:55 pm
+1.
I have never found a MikroTik user who found the current ^v "lock" feature useful. Conversely, I have assisted a number who were screaming "Jane! Stop this crazy thing!" after having activated it accidentally.
Maybe it's time to bite the bullet, discontinue it (or move it to control-altmode-cokebottle), and surrender ^c and ^v to the meaning they maintain in the entire rest of the universe.
jetelina
Thu Apr 16, 2020 12:35 am
After upgrading to 3.22 windows organization got little messy.
Top left corner of most of windows is on correct position, but width and height is not saved.
When window is on the bottom of screen, the default with and height is used and thus also top left corner is moved up.
ghostt
Thu Apr 16, 2020 2:36 am
+1.
I agree 100%. Personally, constantly installing, configuring and maintaining Mikrotiks for many clients I have also never found current ^v feature useful, it's rather annoying I'd say. I do understand that Winbox developers may have 1000 reasons for their way of using ^v combination. But. At the end of the day, we are buying Mikrotiks and configuring them for our customers.
So, correct me if I'm wrong, it should be convenient to use Winbox for people "in the field". I'm trying to say that developers should listen a little bit more to our feedback than to "people in the laboratories where everything is working".
tommyd
Fri Apr 17, 2020 11:50 am
Sorry to say but this is a dumpster fire. Windbox does no remember correctly the zoom level, it seems it zooms out with every reopen of the session session, messes up windows size and position even when saving session to file.
Please also add Ctrl-mouse wheel support for zoom
emils
Forum Veteran
Forum Veteran
Fri Apr 17, 2020 3:24 pm
Winbox v3.23 has been released:
viewtopic.php?f=21&t=160050
