DorianGray
RBM33G with two WifiCards
Wed Mar 11, 2020 4:55 pm
Hi Guys,
iam asked my Mikrotik Dealer for RBM33G using it with 2 miniPCIe Wificards at the same Time.
I got as answer, the RBM33G doesn't support this Setup, two wifi Cards at the same Time.
Well so i check MT alternatives, but didn't find smth. useful for my Setup, but the RBM33G would be perfect.
I Would use it with two R11e-2HPnD, and i don't need the USB Port. I checked the Block Diagramm and the other Papers of MT but i didn't find any problems?
Who knows more?
Thanks, and kind Regards!
JohnTRIVOLTA
Re: RBM33G with two WifiCards
Wed Mar 11, 2020 4:59 pm
This is not true ! I'm with such a two wifi card !
intensex
Thu May 21, 2020 5:43 pm
It's true,I have test two WiFi card work at once on RBM33G at July 2019, and the
Cards can work on caps mode
mcfish
Wed Nov 04, 2020 1:18 pm
which cards are you using ?
I've tried a R11e-2HPnD and R11e-5HacT.
But together they won't work. After a couple of days the board freeze.
Ony with one of the cards it works well (RBM33G with 128GB M.2 and USB LTE Modem)
krafg
Forum Veteran
Forum Veteran
Fri Nov 06, 2020 5:24 am
You can try to remove the jumper next to USB 3.0 port.
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
dodo34
Sat Dec 05, 2020 11:27 pm
Can i install 2 x Wifi Cards + 1 x M.2 4G LTE Card ?
Users browsing this forum: No registered users and 28 guests
