aitaka
Mini PC With Intel nic I211AT
Mon Mar 16, 2020 3:17 pm
Im From Indonesia
Sorry if my english bad,
i bought Firewall Router Intel Celeron J1900 J1800 N2806 Mini PC Intel i211AT Gigabit Ethernet NIC 4x RJ45 HDMI VGA WiFi SIM Slot
Brand Name: XCY
Model Number: X30
Type: Mini Desktop
Hard Drive Capacity: ≤ 40GB
Processor Model: Celeron N2808 J1800 J1900
Memory Capacity: ≤ 128MB
Graphics Card Type: Integrated Card
Type: Mini PC
Processor Main Frequency: 2.0GHz
Processor Brand: Intel
Use: Multimedia
Memory Types: DDR3L, 1333/1600MHz, 1.35V
Hard Drive Types: mSATA, SATA
USB Ports: 1x USB3.0, 1x USB2.0
Video Ports: 1x HDMI, 1x VGA
Ethernet: 4x Intel i211AT 10/100/1000M Gigabit Ethernet
WiFi: Mini PCI-E WiFi
Processor Graphics: Intel HD Graphics
Audio Chip: Realtek ALC662 HD Audio
SIM Slot: Built-in 1x Micro SIM card slot
Supported OS: Windows, Linux Ubuntu, PFsense, Lede, VyOS, OpenWRT, MikroTik, CentOS,
Working Voltage: DC 12V 5A
Dimension: 136x126x40mm
after attcah ssd sata with original ros lvl 4,only wlan detect in interface print,
anybody can help,make the lan interfce detect in mikrotik?
thanx
aitaka
Re: Mini PC With Intel nic I211AT
Tue Mar 17, 2020 12:21 am
up #1
r00t
Long time Member
Long time Member
Tue Mar 17, 2020 3:32 pm
If the driver is not in ROS, your only option it to contact support and try to persuade them enough so it's added... good luck with that.
There is also small possibility beta version of ROS 7 may have the driver, you can try installing it to USB key (so you don't mess up your existing SSD) and test it. It's still in beta, but if it works, it will be better than nothing...
mbovenka
Tue Mar 17, 2020 4:15 pm
Well, his SSD isn't working for him as it is, so he might just as well try 7.0 beta on that... If that doesn't work either, he could try CHR under a hypervisor that does know how to talk to those interfaces, assuming that box has enough RAM for it.
aitaka
Tue Mar 17, 2020 5:15 pm
ok i will try install ros 7.
i will report again
thanx
update
notif crashkernel and restart before login.
aitaka
Tue Mar 17, 2020 5:17 pm
yes work with proxmox,lisesni p1 ,but high cpu on ethernet,
maybe because limit cpu j1900 :-(
aitaka
Tue Mar 17, 2020 6:00 pm
I hope Mikrotik adds a mini PC driver with multi nic like Qotom etc.
because it's very efficient for x86 fans and small-mid bandwith management
cheap
DC power
small size
many choices ranging from atoms, celeron - i7
aitaka
Wed Mar 18, 2020 12:06 pm
up#18-3
mbovenka
Wed Mar 18, 2020 12:22 pm
Probably. The J1900 isn't exactly a speed demon.
Hominidae
Sun Jun 14, 2020 11:43 am
I am having the same problem as the OP.
I am using a linux/KVM based system with vt-d/IOMMU to pass through the hardware NICs to a Router-VM, running CHR
This is a system, that works already for years an a self-build system with I3-8100 and i310AT Quad-NIC.
Now I purchased a mini PC with i5-6200U and 6x i211AT NICs...and no joy. :(
However,.using pfsense/opnsense works fine in the VM with NICs in passthrough (as underlying FreeeBSD is using the same driver for both models of these intel based chipsets).
I will try v7beta...otherwie opensense it is.
Edit: yes, ROS image for CHR based on v7beta does have the drivers.
monotsc
Tue Jul 07, 2020 2:44 am
i got one like that...managed to install x86 but no ethernet detected at all...so i gave up
use CHR with virtio-net (kvm) or vmxnet (vmware) driver so you wont get high cpu load or low throughput
spaxton
Fri Apr 08, 2022 10:29 pm
Hello Friends,
I was just about to buy a few boxes like this. Has anyone managed to get this up and running?
Best Regards.
