kashifmax
Need to set daily limit 100mb for 30 days (month)
Fri Mar 27, 2020 10:26 am
I'm using RB951 series with userman. Can anyone tell how to set daily internet limit let's say 100mb per day and want to set it for 30 days (a month).
Thank you.
Zacharias
Re: Need to set daily limit 100mb for 30 days (month)
Sat Mar 28, 2020 4:54 pm
You can set a limit for each profile you create... i do not remember right now if it can be daily or not... you can check it out...
kashifmax
Sun Mar 29, 2020 12:05 pm
Hi Zacharias,
Thanks for the reply,
Right now I have set validity. I don't know if that will work, will check later.
Zacharias
Sun Mar 29, 2020 2:31 pm
Validity will just expire the users profile...!
Untils the user gets assigned a new profile, no access to the internet will be available...
Users browsing this forum: No registered users and 7 guests
