kvan64
Limitting bandwith after download limit is reach - How to?
Fri May 25, 2007 4:17 pm
Hi, I am not a programmer and have never attempted any script in my entire life. I don't know how to do it correctly. Combining the scripts from others, will the following work???
Scripts
______________________
add name=shapingRate source={
:local traf;
/queue simple
:for i from=1 to= 254 do = {
:if ([/queue simple find target-addresses=("192.168.1." . $i)] != "") do={
:set traf [get [find target-addresses=("192.168.1." . $i)] total-bytes]
:if ($traf > 104857600) do = {
set [find target-addresses=("192.168.1." . $i)] max-limit= 32000/64000
add name=resetCounter source={/que simple reset-counters}
Schedules
add name=run-1h interval=1h on-event=shapingRate
add name=run-24h interval=24h on-event=resetCounter
kvan64
Re: Limitting bandwith after download limit is reach - How to?
Sat May 26, 2007 12:59 am
Also I have tx/rx limits set using hotspot user profiles. If the script works, will it work in this case? If I tried it anyway and it has errors, will it compromise hotspot connections? Ta
meverest
Wed Jun 06, 2007 5:43 am
you need to use a radius server to do this, else subscribe to some admin application service like this one: http://www.viewbankrise.net.au/webministrator.htm
Cheers.
Users browsing this forum: Majestic-12 [Bot] and 61 guests
