Anton8612
PWR-LINE PL7400 firmware
Sat Apr 11, 2020 11:16 pm
Please tell me where can I get firmware version 1.4.0 or newer for PL7400?
Zacharias
Re: PWR-LINE PL7400 firmware
Sun Apr 12, 2020 2:23 am
I do not see any firmware available... How can you tell that there is an update ?
Anton8612
Sun Apr 12, 2020 4:25 am
I have several devices based on the QCA7420 chip with different firmware versions of the PWR-LINE module.
The problem arises when the modules work with different firmware versions on the same network, even under ideal conditions.
Zacharias
Sun Apr 12, 2020 7:09 pm
Since it is not available to download, i do not see anything, you could contact Mikrotik support and ask them...
zarnaya
Wed Apr 07, 2021 6:24 pm
I updated mine using firmware from this post
plc-hw-platform: QCA7420
plc-sw-platform: MAC
plc-fw-version: 1.5.0(26-20200114-CS)
Simply uploaded firmware to flash and run firmware-update.
josepc
Thu Feb 10, 2022 12:38 am
Thanks!
I followed these instructions and everything worked fine.
Download the file with the extension .nvm
Upload it to Files section on Winbox
On terminal write: interface pwr-line upgrade-firmware file=<nameOfFile.vnm> 0
After a few seconds the PLC chipset is upgraded.
hecatae
Mon Feb 14, 2022 7:09 pm
correct command is:
interface pwr-line upgrade-firmware firmware-file=.nvm
eddieb
Thu Feb 17, 2022 2:56 pm
I also loaded this firware into my pair of pwr-line devices, worked fine, no problems ;-)
Users browsing this forum: lurker888 and 89 guests
