AtifKhan
RouterOs and Radius Manager on Single Machine
Sun May 27, 2007 2:44 am
Is it possible to have RouterOs + Radius Manager + Squid Proxy on Single Machine.
RouterOs
(PPPoE Server + Firewall + Bandwidth Manager
Radius Manager
(Mysql+FreeRadius+FrontEnd+Squid proxy)
All on same machine. if someone tried it.
Atif Khan
mneumark
Re: RouterOs and Radius Manager on Single Machine
Sun May 27, 2007 9:42 am
Yes its possible. All the machines i have are way overbuilt. I don't have any issues.
Matt
nazadnan2003
Sun May 27, 2007 12:24 pm
Matt
can you please explain in details how can you achieve this.
Many thanks
AtifKhan
Sun May 27, 2007 2:12 pm
I would like to know how you did it. how its possible. what hardware did you used what os did you used. kindly provide more information to understand it better.
Atif Khan
mneumark
Mon May 28, 2007 4:52 am
You can do this by using VMware. Just to be careful, pay really close attention on the amount of processor power and ram you have.
Matt
nazadnan2003
Mon May 28, 2007 9:14 am
Matt
Can you please be more specific:
- What is the mane OS ? Is it Windows ?
- What is the VMware you use ? Is it Microsoft VM
- What is your recommendation for CPU and RAM ?
- Did you use this machine in real environment ?
- What is the amount of your traffic ?
- What is the number of your concurrent users ?
Many thanks
mneumark
Mon May 28, 2007 9:32 am
Fedora and MT
VMware
I would recommend a dual core processor in the manor (2GHz+). The dual core process will help with VMware and fedora, but secondary core will not be utilized in MT.
2GB+ RAM
Yes (also tested with gaming users)
5MB-10MB/2MB-7MB of Traffic per second
~400
AtifKhan
Mon May 28, 2007 4:15 pm
Never Tired VMware but i would love to try it. I need some starting point to start using VMware any good tutorial site for startup of VMware.
And define little info about steps for
Installation RouterOs + fedora Core 5
mneumark
Mon May 28, 2007 8:58 pm
You will need to run two virtual machines. One with RouterOS and One with Fedora Core. This can all be done a single machine.
If you search online search for preloaded Fedora core appliances. The are free and save you the time configuring it and setting it up. You can download a preloaded VMware appliance with Squid preloaded from http://www.vmware.com/vmtn/appliances/directory/57
Then after you got that running create another additional virtual machine and load it use pxe if possible and then use netinstall to install it onto the virtual machine.
Hopefully this helps some.
Matt
firebat
Sat Jun 09, 2007 5:46 am
If you have 8 ether ports in the machine, you can assign each to which ever partition/VM that you wish? Can you assign CPU affinity, etc also?
mneumark
Sat Jun 09, 2007 7:47 am
Well you can assign nics to the VM machine you want. When it comes to the CPU affinity you are going to set that in windows on the VM software.
Users browsing this forum: Google [Bot], jewelaziz and 180 guests
