rssreader
Why command "fetch" doesn't wait for output?
Wed Apr 15, 2020 11:54 am
I use the "fetch" command to run PHP scripts on my web server using a URL call. PHP script generates large data (XML) - it takes a long time. The output is only "OK" when finished.
However, the fetch command does not wait for "OK". Is it possible to set a timeout for fetching output or how to solve it?
I need verify that "OK" has been returned.
andriys
Re: Why command "fetch" doesn't wait for output?
Wed Apr 15, 2020 12:22 pm
It does. You don't see it in console because the result goes to file by default. RTFM here, please: Tools/Fetch.
As to checking what was returned, read this section specifically: Return value to a variable.
rssreader
Wed Apr 15, 2020 11:08 pm
Of course I know that. That's not the problem. Here is my code:
:local cronFile "result.log";
:local cronUrl "https://www.xxxxxxx.xx/xxxxxxxxxxxxx.php";
:tool fetch url=$cronUrl dst-path=$cronFile;
:local cronResult [/file get $cronFile contents];
:if ( $cronResult != "OK") do={ /tool e-mail send to="email@email.xx" subject="cron incomplete" body=$cronResult file=$cronFile }
Calling "fetch" terminates execution rest of the script, no record in the system log ... nothing
just end
PHP script finishes the job and returns "OK", but "fetch" dies in the meantime
creatin
Fri Apr 17, 2020 10:25 am
Try to put a delay of 5 seconds before and 10 seconds after fetch command
rssreader
Wed Jul 01, 2020 8:32 am
like this ?:
:delay 5s;
:delay 10s;
The same result - nothing.
The fetch command is missing a "timeout" option.
sutrus
Wed Jul 01, 2020 8:26 pm
Return value to a variable:
:local result [/tool fetch url=$cronUrl as-value output=user];
:if ($result->"status" = "finished") do={
:if ($result->"data" != "OK") do={ /tool e-mail send to="email@email.xx" subject="cron incomplete" body=$cronResult file=$cronFile }
rssreader
Sun Mar 07, 2021 3:56 pm
it also doesn't work
only "start" appears in the log:
:local cronUrl "https://xxxxxxxxxxxxx.php";
:log info "start";
:local result [ :tool fetch url=$cronUrl as-value output=user ];
:log info "finish";
elico
Tue Mar 23, 2021 10:38 pm
You should try to see if there is some kind of error using a do and on-error like:
/log info "start";
:do {
	/tool fetch url=$cronUrl;
} on-error={
	/log info "finished with error";
/log info "finished";
The log and fetch should start with "/" in scripts.
Jotne
Wed Mar 24, 2021 8:23 am
You do not need the ; after each line.
Its only needed when there are more than one command at the same line.
Chupakabra303
Tue Dec 21, 2021 4:32 pm
Mikrotik team, please add timeout option for Fetch tool!
Default timeout 10 (?) second is too small for specific tasks
failure: connection timeout
infabo
Long time Member
Long time Member
Wed Dec 29, 2021 1:25 pm
@rssreader have you found a solution? I have the same issue, where nothing after tool/fetch is executed in a script.
byosni
Thu Jan 27, 2022 10:08 pm
Eu também tenho o mesmo problema, @mikrotik coloque um "limit timeout" no tool fetch
Users browsing this forum: No registered users and 24 guests
