rgpmikrotik
Connection-mark
Tue May 29, 2007 3:19 pm
Hello I wan´t to know when is necessary to use connection marks, I´m using just packet marks without connection marks and I can´t see why I should use connection marks (What is the difference in using them?). Thanks
mrz
Re: Connection-mark
Tue May 29, 2007 3:21 pm
IF you use connection marks before packet marks, it reduces CPU load.
skillful
Trainer
Trainer
Re: Connection-mark
Tue May 29, 2007 5:49 pm
Connection mark help you keep track of the return traffic which are then marked with the same connection mark.
JJCinAZ
Re: Connection-mark
Fri Jun 01, 2007 5:50 pm
Skillful is correct. Additionally, when using Masq-NAT, you need the connection marks to be able to mark all the packets properly.
Users browsing this forum: Baidu [Spider], samreiss, SuperMiao and 131 guests
