emils
v6.45.9 [long-term] is released!
Thu May 07, 2020 5:09 pm
RouterOS version 6.45.9 has been released in public "long-term" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.45.9 (2020-Apr-30 10:25):
Changes since 6.45.8:
*) arm - improved watchdog and kernel panic reporting in log after reboots on RB3011 and IPQ4018/IPQ4019 devices ("/system routerboard upgrade" required);
*) capsman - fixed "certificate" parameter updating on CAP;
*) certificate - fixed certificate verification when flushing CRL's;
*) chr - added support for file system quiescing;
*) chr - enabled support for VMBus protocol version 4.1;
*) chr - improved system stability when running CHR on Hyper-V;
*) console - prevent incorrect type interfaces appearing in command hints;
*) crs3xx - fixed frame forwarding after disabling/enabling bridge hardware offloading for CRS354-48G-4S+2Q+ device;
*) crs3xx - fixed interface statistics for CRS354-48G-4S+2Q+ and CRS354-48P-4S+2Q+ devices;
*) crs3xx - fixed switch rule "dst-port" parameter for IPv6 traffic on CRS305-1G-4S+, CRS326-24G-2S+, CRS328-24P-4S+, CRS328-4C-20S-4S+, netPower 15FR devices;
*) crs3xx - improved SFP+ DAC cable initialization for CRS326-24S+2Q+ device;
*) defconf - added welcome note with common first steps for new users;
*) discovery - do not send CDP and LLDP packets on interfaces that does not have MAC address;
*) health - fixed maximum SFP temperature reading under '/system health' menu;
*) hotspot - fixed redirect to log in page (introduced in v6.45);
*) ike1 - rekey phase 1 rekeying as responder for Windows initiators;
*) ipsec - improved system stability when handling fragmented packets;
*) led - added "dark-mode" functionality for CRS105-5S-FB;
*) lte - added "phy-cellid" value support for LTE-US;
*) lte - fixed IP type selection from APN on RBSXTLTE3-7;
*) lte - improved system stability when performing firmware update on R11e-LTE6;
*) sniffer - fixed minor typo in "host" menu;
*) snmp - fixed "ifSpeed" reporting for tunnel interfaces;
*) snmp - fixed "routeros-version" value returning from registration table;
*) snmp - fixed UPS battery voltage value scaling;
*) ssh - added support for RSA keys with SHA256 hash (RFC8332);
*) system - correctly handle Generic Receive Offloading (GRO) for MPLS traffic;
*) system - improved system stability when forwarding traffic from switch chip to CPU (introduced in v6.43);
*) system - improved system stability when receiving/sending TCP traffic on multicore devices;
*) traceroute - improved stability when invalid packet is received;
*) webfig - added default configuration confirmation window to WebFig;
*) webfig - allow skin designing without "ftp" and "sensitive" policies;
*) webfig - do not show WebFig menu when opening 'Check For Updates' in Quick Set;
*) winbox - added "Options" parameter support for DHCPv6 client and server;
*) winbox - added 160Mhz extension channel support for CAPsMAN;
*) winbox - added support for "Tools->WoL" menu;
*) winbox - do not show "Revision" parameter under "System/RouterBOARD" menu on devices that have only one revision;
*) winbox - fixed "ARP" parameter inheritance from "CAPs Configuration" configuration;
*) winbox - fixed "Bands" parameter display for LTE interfaces;
*) winbox - fixed "DSCP" parameter value setting;
*) winbox - fixed "Frequency" and "Secondary Frequency" parameter inheritance from "CAPs Channel" configuration;
*) winbox - fixed "Passthr. MAC Address" parameter display "LTE APNs" menu;
*) winbox - fixed "Switch" menu on CRS354-48P-4S+2Q+;
*) winbox - fixed "dst-port" unsetting in "IP->Hotspot->Walled Garden" menu;
*) winbox - fixed "invalid" flag presence under "System/Certificates/CRL" menu;
*) winbox - fixed automatic "IPv6->Firewall->Address List" table update;
*) winbox - increased limit of multi-entry fields to 100;
*) winbox - made "none" the default value for "Security Profile" parameter when creating a new "Wirelees->Connect list" entry;
*) winbox - renamed "Memory used" to "HDD used" for HDD type under "Tools->Graphing->Resource Graphs";
*) winbox - renamed "Routerboard" to "RouterBOARD" under "System/RouterBOARD" menu;
*) winbox - show "System/RouterBOARD/Mode Button" on devices that have such feature;
*) wireless - added "skip-dfs-channels" parameter;
*) wireless - allow using FCC "U-NII-2" frequency range for hAP ac2 and RBwAPGR series devices;
*) wireless - fixed default "antenna-gain" setting on SXT 2 devices;
*) wireless - improved 5GHz interface stability on RB4011iGS+5HacQ2HnD and Audience;
*) wireless - improved compatibility for "ETSI" wireless country profile;
*) wireless - improved system stability on hAP ac^2;
*) wireless - updated "bangladesh" regulatory domain information;
*) wireless - updated "indonesia4" regulatory domain information;
*) wireless - updated "south africa" regulatory domain information;
For a full changelog please visit https://mikrotik.com/download/changelogs
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this specific RouterOS release.
MorgenS
Re: v6.45.9 [long-term] is released!
Thu May 07, 2020 5:51 pm
Skins in web-interface stopped working after upgrading to 6.45.9. Checked on 2 different architecture routers.
If the skin is assigned to a specific group (read only for example), a user of this group after login to web interface will see all elements, even the ones that were deselected in skin. If the skin is selected manually in Design Skin menu, everything looks ok for this user.
Is it just for us or not?
andriys
Thu May 07, 2020 6:51 pm
*) chr - fixed graceful shutdown execution on Hyper-V (introduced in v6.46);
How comes 6.45.9 contains a fix for something introduced in 6.46? In case the bug was "backported" from 6.46 it would be good to know what 6.45.x versions are affected.
nmt1900
Fri May 08, 2020 10:21 am
There's obvious probability of it being present at least in 6.45.8 as it was released after 6.46. Then again as 6.44.6 was released before 6.46, so it is quite probable, that 6.45.8 is the only one affected in long-term tree - presuming "introduced" is pointing to right version...
emils
Fri May 08, 2020 10:29 am
Sorry for the confusion. The fix was backported to 6.45.9 by mistake, but the fix does not cause any harm. There is no issue with shutdown execution on Hyper-V before 6.46. I will remove the entry from changelog.
bda
Fri May 08, 2020 12:40 pm
Sorry, but are where any news about OSPF stability in this release?
Especially with OSPF MD5 auth...
God bless UNIX!
deanMKD1
Fri May 08, 2020 10:18 pm
Someone tested this on ARM platform yet? hAP AC2 ? How is compared with 6.45.6 Stable for ex?
whatever
Fri May 08, 2020 11:45 pm
Updated one of my hap ac² which is used as a switch and AP. No issues so far, I'm getting ~300 Mbps TCP download speed on a 5GHz 2x2 device while it used to be in the 200-250 Mbps range before (6.45.8 long-term). Still not as fast as the competition, but it looks like an improvement.
DenisPDA
Sat May 09, 2020 1:38 am
hAP ac² + Dell Vostro 7590 (Intel® Wireless-AC 9560)
whatever
Sat May 09, 2020 10:52 am
Is that with or without capsman? What's your result with a single TCP stream?
deanMKD1
Sat May 09, 2020 11:50 am
What meen this? I dont understand.. Improvment or downgrade from what version? Explain.
DenisPDA
Sat May 09, 2020 12:05 pm
Clear improvement regarding LT 6.44.6
deanMKD1
Sat May 09, 2020 11:09 pm
Upgraded my hAP ac2. All seems fine. Not experienced issues. Seems stable.
MTeeker
Mon May 11, 2020 11:44 pm
Long-term v6.45.9 broke both 2.4 and 5GHz wifi on wAP ac (RBwAPG-5HacT2HnD). It simply refuses to boot up after Netinstall.
Repeated Netinstall process produces same result.
Back down to Stable V6.46.6, and it's working again.
(My wAp ac running as CAP under RB493G as CAPSMAN. Have not been able to upgrade firmware on wAP ac except via Netinstall).
andriys
Tue May 12, 2020 12:03 am
MTeeker That must be something specific to your particular unit. We have 8 wAP ac units here also running as CAPs, successfully upgraded all of them to 6.45.9 from 6.45.8 two days ago (both RouterOS and RouterBOOT), no problems so far.
You wrote "Back down to Stable V6.46.6", so I guess you tried switching to 6.45.9 from 6.46.6. Do you have RouterBOOT also upgraded to 6.46.6?
MTeeker
Tue May 12, 2020 1:08 am
MTeeker That must be something specific to your particular unit. .....
.... Do you have RouterBOOT also upgraded to 6.46.6?
It's good to know that it only happened on my box, given your successes on eight other wAP ac's.
As a matter of fact, I upgraded routerBOOT to 6.46.6 earlier when I flashed v6.46.6. RouterBOOT remained 6.46.6 when I tried 6.45.9. Not sure if this was the cause of my failure.
Lastly, are you able to upgrade firmware on your wAP ac normally. For some reason, I have not been able to. Henece Netinstall. And I have not been able to find out why.
Regards,
MTeeker
andriys
Tue May 12, 2020 1:19 am
Absolutely. Upgraded RouterOS on all 8 units from CAPsMAN, and once they all came back online rebooted once again to upgrade RouterBOOT (they all have /system routerboard settings set auto-upgrade=yes). All went smoothly.
djdrastic
Tue May 12, 2020 3:07 pm
Gonna throw this up in the lab but any updates on the weird OSPF issues that were introduced 6.44.6 and upwards ? We had to go back to 6.44.5 as we'd get adjacencies seemingly stuck . Only thing that brought it back was either disabling/re-enabling the instance or rebooting the router.
bda
Tue May 12, 2020 6:09 pm
Do you test it for OSPF problems or no? I don`t understand.
God bless UNIX!
djdrastic
Tue May 12, 2020 6:20 pm
Busy testing at the moment to see if I can reproduce the issue that happened in 6.44.6 on 6.45.9
We had routers with adjacency for weeks running that would all of a sudden start acting up.
easyspot
Wed May 13, 2020 6:54 am
Long time ago, Long Term / Bugfix channel really good for mission critical system, because its already stable n tested. But now LT channel is just a name. In fact, the only latest real stable LT is 6.43.16. So why MT create LT n Stable channel if both unstable just like Testing channel?
kos
Wed May 13, 2020 11:20 am
+1
That's why Mikrotik must stop prevent users downgrading ROS version!
Chupaka
Wed May 13, 2020 4:01 pm
Do they prevent? (O_o)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
easyspot
Wed May 13, 2020 4:11 pm
Mikrotik have to choose between being enterprise os which is offering stability, or soho os which is offering alot of features but unstable.
Mikrotik always, I mean always, sell new hardware before make the software for it. Everytime we buy new hardware, we must wait for about 6 months before that hardware can be stable. After that hardware become stable, next version can be unstable again. Man, do u guys sell hardware for business/enterprise or soho/toys?
easyspot
Wed May 13, 2020 4:21 pm
Yes they prevent. I was working alot with RB951UI-2HnD with the most stable ROS 6.32.4. After some times, MT put factory version. Since that time, RB951UI-2HnD that I bought with factory version post 6.32.4 can't downgrade to 6.32.4. Netinstall prevent it. I was curious, I disassembly older n younger hw, n they both have exactly the same hardware. They prevent downgrade for what purpose?
Chupaka
Wed May 13, 2020 6:19 pm
Did you contact support with this question?
vortex
Wed May 13, 2020 11:05 pm
The features can be in packages. Enterprise is not forced to install them.
MTeeker
Thu May 14, 2020 1:44 am
In a fast changing IT landscape, rigidity in approaching marketplace is not considered a smart strategy for any business. That's given. Enterprise-class products are are more stable because of their better specs, longer development and testing time. And more expensive, as a result.
On the other hand, MikroTik would not be where it is today without having been accepted in many many developing markets as best value products at selling price points.
That somehow reminds me of a car analogy. Lexus cars are better quality and more reliable than Toyota ones. They are both manufactured by the same company.
My point: there is a trade-off in there when using MikroTik products. Some time the trade off may be a bit too much. Sure. But that should not invalidate its strategy.
P.S. I put on my former business analyst hat to offer no more than a bird's eye viewpoint. Wishing you a good day.
easyspot
Thu May 14, 2020 5:56 am
When they create CCR n CRS, that time they aim for enterprise router. But guess what? There are alot of CCR n CRS problem caused by software. After sometime, they can make a good software for CCR n CRS, but the next update will be unstable again.
I was working with CCR n CRS for a big factory. I ordered the latest CCR n CRS model but because it's really unstable, the boss dont wanna know any reason, i had to change to PC with x86 MT n HP switch. I lost my money for buying that CCR + CRS. I wait for long time before they can be stable n I can sell it to another factory. But when new bugfix update come n unstable, the boss dont wanna know if its software problem. I offer to revert to previous software version but he said its a bad product. He cancel my last payment because of that. Since then, I dont wanna use new MT hardware. They just give a big headache.
MTeeker
Thu May 14, 2020 9:08 am
Sorry to hear you lost money over the purchase of some MT gears which had issues at implementation time.
I stopped wondering why tradesmen (such as plumbers and electrical device installers) prefer to work on products on which they had plenty of experience, rather than others. It was after I experienced a moment or two of 'not sure why' as answers to my clients.
Since then, I always try to implement products that I am reasonably sure of their functionalities and reliability for my clients. After all, they rely on my knowledge, however limited it was. Once or twice, I bought new products, set them up and had them running in my lab prior to installing it at client site.
It's fail-safe approach for me.
My two cents. Cheers.
kos
Thu May 14, 2020 3:42 pm
Mikrotik devices can't be downgraded below factory-software version, which is the current ROS version at the time of manufacture.
kriztov
Fri May 15, 2020 7:03 am
rb4011igs. after update, bridge mac address changes non stop
my log filled with
"bridge" mac address changed to xx:xx:xx:xx:xx:xx
version 6.44.6 don't have this problem
osc86
Fri May 15, 2020 10:34 am
my log filled with
Always set an admin mac address for bridges, or it will cause trouble sooner or later. Just my experience..
nmt1900
Fri May 15, 2020 12:27 pm
Here we go again with another long-term headache...
Hopes for thew solution to 6.45.x + RB1100x4 problem have been destroyed again. First testing produces loss of internal DNS resolution and therefore DNS server settings propagation through DHCP also stopped working - and that with /ip dns set allow-remote-requests set to NO!
This means, that even 7 day interval for scheduled reboots is too long - as failure occured on 6th day...
djdrastic
Fri May 15, 2020 1:05 pm
The only thing I can maybe add .If you guys do a security update like 6.44.6 only put in the security update and leave further upstream patches to a following update , so we don't have to choose between security and stability.
kriztov
Fri May 15, 2020 2:36 pm
my log filled with
ah, it works!
thank u
nmt1900
Fri May 15, 2020 10:03 pm
6.43.16 was released exactly one year ago and it was about last long-term release, which had none of the problems 6.44.x and 6.45.x release tree had introduced.
With 6.44.x we got huge increase in DFS radar detections making some of 5 GHz frequencies essentially unusable and some of RB3011 devices started having spontaneous reboots.
6.45.x gave big headaches to al21400 devices and state of DFS radar detections remained about same as before. Only thing to hope is that 6.46.x long-term will turn out better than last 10 months of long-term releases have been giving us...
prawira
Trainer
Trainer
Sun May 17, 2020 1:15 pm
need to fix this small cosmetic problem. it seems introduce on 6.45.8
Paul
prawira
Trainer
Trainer
Sun May 17, 2020 1:45 pm
and this bug has not fixed yet..
i found this on my RB4011iGS+5HacQ2HnD-IN and audience; the problem only for radio 5GHz card
Paul
nmt1900
Mon May 18, 2020 1:00 am
Well... I am not sure how can this get more embarrassing, than it already is...
Two diffenrent locations, both have RB1100x4, one has 6.45.8 and other has 6.45.9.
When CPU usage goes crazy and internal DNS resolution stops working, I try to make supout.rif and guess what? It is not possible, because process stops somewhere about 56% and I get disconnected. Another try gives same result. No desire to try this repeatedly as there's no guarentee about device being accessible after this. Reboot gets rid of the problem, but there's no use of making supout file after that.
What the hell is going on?
P. S. There's no easy way to access device physically on the location if somebody would try to suggest use serial connection.
Tester007
Mon May 18, 2020 2:14 am
Looks like "Restore default config" functionality is broken on my hap lite on this version. Getting no config at all after the reset.
groundbeatmsk
Mon May 18, 2020 12:37 pm
Hello.
How fix memory leak on my hAPac2 6.45.9?
just 7 days uptime, free memory down from 80Mb to 65Mb
andriys
Mon May 18, 2020 1:21 pm
That is not an indication of memory leak on its own. Does the memory usage keep growing? How does it look over time? Do you have a graph to show?
groundbeatmsk
Mon May 18, 2020 1:45 pm
- about 80Mb free memoy after reboot and still decreases every day by ~2-3 MB. It's happens once per day, not each minute.
- i'm think that graph doesn't work properly cause it's empty
whatever
Mon May 18, 2020 1:54 pm
You have to enable resource graphing by adding a new rule under "Resource Rules" tab.
nmt1900
Mon May 18, 2020 2:08 pm
Well... I can tell you what is going on - I did a reboot after making supout proved to be impossible and some hours after that it left THIS in LibreNMS log
and surprise, surprise - it really shows just that
Is this one also one of these "cosmetic" issues or is 6.45.x crippling 1100x4 and 4011 devices? Fancy a RMA? If device has been in use for years (factory software 6.40.4)?
What next?
osc86
Mon May 18, 2020 6:00 pm
@nmt1900 seems this device is still running 6.45.8
nmt1900
Mon May 18, 2020 9:17 pm
Yes it was. As I stated previously, we have 3 1100x4 devices with 6.45.8 and 6.45.9 and they all suffer from same problems to somewhat different extent. Others with 6.44.x versions are functioning without problems.
As update to previous - another reboot "brought" license back and this device now also is updated to 6.45.9. It is interesting to see, which would license level be after next reboot - almost like rolling a dice. This is getting really confusing...
deanMKD1
Tue May 19, 2020 9:56 pm
Hello.
No memory leak for me at all.. Memory usage seems the same like every previous build i have used before, no matter that is stable or long term one.. Currently on latest long-term, all seems fine, 10 days till now.
nmt1900
Thu May 21, 2020 11:55 am
Now we know, how this starts.
This pops up in log and after that CPU usage goes up and stays there. More than one thing ceases to work after that - commands in terminal produce similar output with suggestion to send supout file.
The license level problem is also related to that because issuing /system license print also puts out similar error message in terminal and "adding insult to injury" - finally new terminal window refuses to open in winbox.
We'll see if supout can be made with scheduler or not, but after that attempt it is time to downgrade.
deanMKD1
Thu May 21, 2020 6:04 pm
After 11 day uptime after flashed this long-term build.
- No memory leak. Still memory is the same !
- No licence Level issues reporeted before for my hAP AC2.
For people who is reported issues. Make sure that you update RoS and Firmware too to latest available compatible to RoS version.
bda
Fri May 22, 2020 11:53 am
Does anybody check ospf problem?
God bless UNIX!
bda
Fri May 22, 2020 7:04 pm
Hi, do you test OSPF issues yet? Any positive news?
God bless UNIX!
djdrastic
Tue May 26, 2020 2:07 pm
Passed lab test with a couple of Ubnt and Cisco equipment . Going to go put it in a non critical area of the network with and see how it goes .
Not very optimistic as I've seen nothing in the changelogs indicating any sort of fix.
bda
Tue May 26, 2020 6:54 pm
I will test now on several non critical devices too.
For now - we have no large scale up/down events on core routers with many circuits, so no statistical data on ospf behavior.
I will inform on issue detection.
But it is true - no news on ospf fix in changelog.
God bless UNIX!
thedix
Fri May 29, 2020 4:00 pm
Seems random reboots disappeared on HAP AC^2 with 6.45.9.
Uptime is 8 days.
CZFan
Tue Jun 09, 2020 3:01 am
+1
Not just you. Busy deploying The Dude and wanted to create web skin for web access to The Dude this eve and noticed exact same as described
MTCNA, MTCTCE, MTCRE & MTCINE
allancesar
Thu Jun 11, 2020 5:44 am
Someone needs to tell Mikrotik that there is a bug in OSPFv3 (tested in 6.44.5, 6.44.6 and 6.45.8) when the router is experiencing high IPv6 traffic (1.5gbps here started to give problems). It is that bug that some complained about in the forum, the adjacency drops, and only goes back until the router deactivates and reactivates the instance of OSPFv3, while OSPFv2 does not present any problems. I believe it is possible to reproduce this bug by closing adjacency between some routers and leaving them with about 5gbps of IPv6 traffic (or more) for at least 2 days.
Yes, I already opened a ticket on the support, I talked a lot with them, and the conclusion I reached was this. Nothing to complain about support, there is only one problem and needs to be fixed. I still need to test version 6.45.9, but by the changelog, it should be the same.
Jotne
Thu Jun 11, 2020 8:03 am
You can do that: support@mikrotik.com
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
allancesar
Fri Jun 12, 2020 2:06 am
The bug is already reported to Mikrotik support. Do not want to lose sleep over this issue, I'm leaving for another manufacturer to rule my network core. I helped with sniffer, with data, prints, tests, in short, everything that was within my reach.
I hope that Mikrotik will be able to reproduce and fix the bug.
AlexKV
Fri Jun 12, 2020 11:41 am
RouterBOARD 1100x4
factory FW 3.43.2
Upgrade from 6.44.6 to 6.45.9 - random reboots every 5-7 days (
On 6.44.6 some months before - newer reboots.
RouterBOARD 1100x4
factory FW 6.43.16
Upgrade to 6.45.9 - no reboots....
mkx
Fri Jun 12, 2020 8:11 pm
@alexkv: why don't you upgrade RouterBoot on both units? It is adviseable to do so every time one upgrades RouterOS.
/system routerboard upgrade .. and reboot after that.
BR,
Metod
nmt1900
Wed Jun 17, 2020 3:15 pm
This is really interesting. I provided Mikrotik with needed information and my support ticket got this answer: "your device has a hardware malfunction. Please submit the device for warranty repair - if warranty is still valid".
I did a full rollback to 6.44.6 and now there is about 4 weeks of uptime without any problems whatsoever.
What kind of a "hardware malfunction" might it be if it disappears after firmware downgrade???
jebz
Wed Jun 17, 2020 3:36 pm
ROS v6.44.6 was my preferred firmware on RB1100AHx4 but reboots after 20-30 days continued. Mikrotik analyzed the supout and responded the same, hardware issue please return.
Users browsing this forum: Google Feedfetcher, marcin21, sindy, vecernik87 and 15 guests
