archerious
Duplicate Address Detected IPv6?
Wed May 20, 2020 3:51 am
Can someone explain this to me, I found it doesn't go away even if I switch from a /64 on say 1873 to 1875 etc. Randomly it goes away or this issue spreads.
I am about as stupid as it gets to IPv6 on MikroTik, so any help is appreciated.
My ISP gives me a /60 if that helps.
RB4011 Former: UDM-Pro, CCR2004, hEX, ER4
USW-24-Poe, USW Aggregation Switch, and Cisco Catalyst 1000-24P-4X-L Former: Ubiquiti XG-16 & ES-10X
Wireless Wire
troykelly
Re: Duplicate Address Detected IPv6?
Mon Jun 01, 2020 9:08 am
@archerious Did you get any answers on this - it's making our routers unusable.
The fix for (horrific IPv6 issues) on RouterOS was to disable and re-enable all IPv6 addresses at startup - but that doesn't seem to resolve this specific issue.
jprietove
Trainer
Trainer
Re: Duplicate Address Detected IPv6?  [SOLVED]
Mon Jun 01, 2020 2:46 pm
Have you tried to enable 'EUI-64' in address? Maybe another device is trying to use the same address (prefix obtained with all the other bits 0). If you construct your IP address using the prefix + EUI-64 you shouldn't have this problem
archerious
Mon Jun 15, 2020 4:57 pm
That fixed it! I don't see any other devices using the exact prefix, but enabling EUI64 resolved it!
Do you have a donation link? This saved me so much, god bless you!
Wireless Wire
WGH
Wed Nov 25, 2020 11:49 am
It happens very easily on Linux network stack. If Linux considers itself a router (which is the same as having "forwarding" enabled), it will claim the all-zeros address, EDIT: even though it will never explicitly appear in
ip address show
. If you have VMs, Docker containers, etc., you will automatically have forwarding turned on.
As things are now, trying to suppress this behaviour is an exercise in futility.
Users browsing this forum: No registered users and 64 guests
