gdelacruz
BLOCK TORRENT w/ ROUTER OS 6.45.9
Wed May 20, 2020 5:55 pm
Is there a way to totally block torrent using the mentioned router OS version.
If not, can we apply download limit for torrent traffic only.
Many thanks,
Gerry
jvanhambelgium
Re: BLOCK TORRENT w/ ROUTER OS 6.45.9
Wed May 20, 2020 6:11 pm
Many thanks,
Gerry
You could go quite aggressive :
-> Deny any inbound traffic not part of client-initiated sessions. (but with exceptions that are applicable for your environment, like dns,ntp,smtp,...) and if you host external public services etc.
-> Only allow 80 & 443 outbound (and offcourse DNS,NTP,SMTP etc)
It is not so easy to get this under control by only looking at port-numbers etc.
You should first make an good analysis of what normally your traffic-flows contain. Depending on the size of your environment this can vary from simple to very complex.
