nevolex
Port forwarding to External OpneVPN Server
Thu May 28, 2020 7:06 am
Hi all.
I have an Open Vpn server (on a raspberry pi in my lan)
It has an ip of 10.0.0.6 and port 33445
Can somebody please advise how to do port forwarding to that port 33445 (UDP only)
External port is also 33445 (I have a static public IP)
These are my current rules:
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
Thanks a lot
nevolex
Re: Port forwarding to External OpneVPN Server
Thu May 28, 2020 8:31 am
Would that rule work?
add action=dst-nat chain=dstnat dst-port=33445 in-interface-list=WAN protocol=udp to-addresses=10.0.0.6 to-ports=33445
sindy
Thu May 28, 2020 11:02 am
Add it just before or just after any already existing rules in chain=dstnat - it is for a particular port, so it is unlikely to get shadowed by another one in the same chain, and it is unable to shadow another one itself.
Just a remark, you only need to use to-addresses and/or to-ports if the address or port needs to be changed. So here, translation to the value found in to-ports will eat several CPU cycles in vain.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
nevolex
Thu May 28, 2020 11:34 am
Ah I see, what would be the most efficient rule for nat in this case, my ports will never change ?
Thank you
jvanhambelgium
Re: Port forwarding to External OpneVPN Server  [SOLVED]
Thu May 28, 2020 11:41 am
Thank you
Then simply omit/remove the last "port" part I guess.
[/quote]
Users browsing this forum: sindy and 145 guests
