ccmks
Display Expire Date on Hotspot Status Page
Sun May 31, 2020 8:13 pm
I have setup hotpsot + user manager. After customizing the hotspot page, I am very satisfied with it overall, except I need to have a way to display user the expire date on status page. Currently, I have been looking on Google and the Mikrotik forum, and looks like everyone just only talked about how much the up time left the user has. I didn't find anything related to display user expire date.
What would be the variable in HTML code for user expire date?
Since the user creation was done through User Manager, I would like the user can see the end time / till time set on user manager on hotspot status page
Please refer to the attachment for the end time / till time.
Thank you
icdbhh
Re: Display Expire Date on Hotspot Status Page
Fri Mar 19, 2021 5:58 pm
Hello Friend's For This problem I Create a Solution , Follow Below Step
1> add below Script Into "status.html" page
<script>
var seconds = '$(session-time-left-secs)';
var newDate = new Date(Date.now()+ seconds*1000);
var expire_date = newDate.toDateString();
document.getElementById("Expire_date").innerHTML = expire_date;
</script>
2> then add below paragraph tag into your expire date section , where you show the expire data ...
<p id="Expire_date"></p>
have fun .... now refresh you can see your plan expire date ..........
VanzJ13
Sat Jul 31, 2021 8:11 pm
<script>
</script>
Hello, Sir thank you so much for sharing, by the way, can expiry time also be displayed?
