Sat Oct 24, 2020 11:15 am
Hello mikrotik experts & users!
I have a strange problem after configuring NordVPN IKEv2 IPsec tunnel.
I followed their instructios step by step, and it works. When I run speedtest, I see the server location correspondent to choosen NordVPN server location and I'm satisfyed with up/down speed.
It works ok with my laptop (Macbook Air), and Mac mini. It also work on my other windows laptop.
Here comes the problem;
Problem comes with Android devices Fire stick 4K and other Android TVbox (Tanix mx3 mini). For example, Fire stick says it cannot connect to Amazon server, or for example sometimes when it connects or for example on other Android TV box, Youtube app doesn't start a video (but I see live icons like it has internet connection.
When I run Analiti app, download speed shows ok, but upload can't even start test.
If i just disable Fire stick local adresses assignet to VPN tunnel in Firewall / Adresses list, everything works fine, so obviously it is kind of VPN tunnel problem.
But even stranger, I have IPTV app (TiVi Mate), on Fire stick and Android TV box, and this app runs perfectly through VPN, and Youtube app doesnt ???
I'm quite shure that I've configured VPN on mikrotik ok (it's explained in tutorial very well), and other than this tunnel, my mikrotik is practicly on default settings.
Have any of you similar problems with Fire stick and Nord VPN?
If I run NordVPN app on Fire stick, it rons without problems. So could it be in codecs or protocols issue?
PS
I'm a newbie, not network expert, I configured it step by step following tutorial. Mikrotik router is Mikrotik hEX S (RB760iGS)
If it will be needed, I can put config. here. Thank you for all kind friends who are willing to help!
