emils
Forum Veteran
Forum Veteran
v7.0beta8 [development] is released!
Thu Jun 04, 2020 1:40 pm
RouterOS version 7.0beta8 has been released in public "development" channel!
What's new in 7.0beta8 (2020-Jun-4 15:04):
*) fixed CLI dependencies for routing menu;
What's new in 7.0beta7 (2020-Jun-3 16:31):
!) added Layer3 hardware offloading support for CRS317-1G-16S+RM more info here: https://wiki.mikrotik.com/wiki/Manual:C ... Offloading
!) enabled BGP support with multicore peer processing (CLI only);
!) enabled RPKI support (CLI only);
!) ported features and fixes introduced in v6.47;
!) routing updates, complete status report: https://help.mikrotik.com/docs/display/ ... col+Status
!) system kernel has been updated to version 5.6.3;
*) other minor fixes and improvements;
All released RouterOS v7 changelogs are available here:
https://mikrotik.com/download/changelog ... lease-tree
How to report RouterOS v7 bugs:
viewtopic.php?f=1&t=152006
santyx32
Re: RouterOS v7 release discussion topic
Thu Jun 04, 2020 1:46 pm
I expected CAKE or fq-codel queue type since this new kernel already includes it.
Edit: Wireguard is also supported in kernel 5.6.x
strods
Re: v7.0beta7 [development] is released!
Thu Jun 04, 2020 1:55 pm
Please keep this topic related to the problems found in this RouterOS release. This topic is not made for feature requests. For that please create a new topic or contact support@mikrotik.com.
tjcomserv
Thu Jun 04, 2020 1:56 pm
I just wanted to say thank you very much for all your hard work.
anav
Thu Jun 04, 2020 2:07 pm
I am simply impressed that you can side stream in improvements from 6.47 into v7.0.
santyx32
Thu Jun 04, 2020 2:11 pm
DoH is no longer working in 7.0 beta 7, it worked in 6.47
Jotne
Thu Jun 04, 2020 2:19 pm
DoH works fine for me.
Just added
https://1.1.1.1/dns-query
Did not select "Verify DoH Certificate" since this is just a test.
santyx32
Thu Jun 04, 2020 2:21 pm
Just added
The verify certicate option used to work in 6.47, I have the root certicate imported into the router
Jotne
Thu Jun 04, 2020 2:23 pm
Does it work without certificates? Just to test the DoH to see what is wrong?
emils
Forum Veteran
Forum Veteran
Thu Jun 04, 2020 2:34 pm
Seems that the router is unable to resolve the DoH hostname. Post your DNS configuration and make sure you have at least one dynamic or static DNS server configured.
santyx32
Thu Jun 04, 2020 2:53 pm
I disabled the verify certificate option for testing but it still has resolving errors
set allow-remote-requests=yes servers=1.1.1.1 use-doh-server=\
    https://cloudflare-dns.com/dns-query
EDIT: I resetted the router and the problem with DoH persists, maybe this build requires a netinstall?
Device is hAP AC2
emils
Forum Veteran
Forum Veteran
Re: v7.0beta8 [development] is released!
Thu Jun 04, 2020 3:45 pm
Unfortunately, v7.0beta7 release did not have all the necessary routing changes for public release, here is a hotfix version of v7.0beta8.
santyx32
Thu Jun 04, 2020 4:02 pm
DoH is still not working for me in beta8
Jotne
Thu Jun 04, 2020 4:24 pm
Test this instead:
set allow-remote-requests=yes use-doh-server=https://1.1.1.1/dns-query
Looks like your router does not resolve the name for cloudflare-dns.com
pe1chl
Thu Jun 04, 2020 4:26 pm
/export includes this line:
#error exporting /routing/policy/selection
/routing/policy/selection/print shows:
error - contact MikroTik support and send a supout file (3)
Is this already known?
In Winbox, there is no icon for "Routing" (this was true in previous versions as well)
Is there a manual for /routing/bgp ? It appears to be completely different from v6 so I need some directions to be able to test it.
santyx32
Thu Jun 04, 2020 4:28 pm
Test this instead:
It did in 6.47, I can even ping cloudflare-dns.com from the CLI but it's not working in DoH
You updated directly from 6.47 or used Netinstall?
EDIT: Also tried Adguard and Quad9 without luck
EDIT 2: tried https://1.1.1.1/dns-query and it works, but if I want to use another server I can't do that, because they don't have a SSL certificate embedded into their IP address like Cloudflare has
hugues
A basic ibgp configuration :
/routing bgp template
add as=65534 name=lab
/routing bgp connection
add local.role=ibgp remote.address=10.X.X.X template=lab
kcarhc
Thu Jun 04, 2020 4:44 pm
router was rebooted without proper shutdown on RouterOS v7.0 beta 7
When it on RouterOS Beta 5, it's work well.
I have config some EoIP Tunnels and some IP Tunnels and Bonding Tunnels with EoIP Tunnels.
kcarhc
Thu Jun 04, 2020 4:51 pm
IPsec Policies say no phase2 on PH2 no phase2
When Upgrade from RouterOS v7.0beta3 and v7.0beta5 to RouterOS v7.0beta7 or v7.0beta8
IPsec Policies say no phase2 on PH2 State
You need goto Identities and remove all and add the Identities for peers again
That's will make IPsec works again.
When Downgradepgrade from RouterOS v7.0beta7 or v7.0beta8 to RouterOS v7.0beta3 and v7.0beta5
IPsec Policies say no phase2 on PH2 State, too.
patrick7
Thu Jun 04, 2020 5:00 pm
Good work, I just hope that you will do the same effort you're doing for IPv4 for IPv6 too.
mrz
Thu Jun 04, 2020 5:05 pm
IPv6 works a lot better in v7, ipv6 policy routing and ECMP coming soon
pe1chl
Thu Jun 04, 2020 5:08 pm
Great! I am looking forward to policy routing and hopefully the other mechanisms to do balancing/failover on IPv6 too.
(like NPT and connection-marking with per-connection-classifier)
kcarhc
Thu Jun 04, 2020 5:09 pm
router was rebooted without proper shutdown on RouterOS v7.0 Beta 7 and Beta 8
Every 10 minutes, router auto reboot.
I think maybe some scheduler Interval 10 minutes on RouterOS v7.0 Beta 7 and Beta 8 crash the kernel
patrick7
Thu Jun 04, 2020 5:14 pm
Hardware offloading?
pe1chl
Thu Jun 04, 2020 5:24 pm
I tried setting it up this way, and it connects. That is, at first it connected and failed and then on the second attempt it connects and receives the routes.
Logged messages:
14:18:12 system,info  by admin
14:18:48 system,info  by admin
14:18:48 route,bgp,info Write to bgp failed (32) { #buf=1 max=64 sk=Socket{ 5[\00OUT] } }
Those "system.info by admin" messages are logged whenever config is changed, I think it is missing some info about what was done (like "bgp added template").
rhaa01
Thu Jun 04, 2020 5:27 pm
I can't set the MTU on an ethernet interface to be larger than 1500. L2MTU is 1580 and I can't even set MTU to 1510.
Router: CCR1036-12G-4S
> int eth set 0 mtu=1510
failure: could not set mtu
> int set 0 mtu=1510
mrz
Thu Jun 04, 2020 5:28 pm
@pe1chl this message typically will appear when there is no local address set or not piicked automatically.
msatter
Thu Jun 04, 2020 5:31 pm
> int set 0 mtu=1510
Is a know problem since the start of ROS 7. That is why did not start using this Beta yet.
pe1chl
Thu Jun 04, 2020 5:43 pm
The router has only a single interface (ether1) and it has an address (172.22.16.252/21).
The first attempt DID come in to the other side but was disconnected immediately, then connected again and it worked.
Log on the other router:
Jun  4 16:18:48 MikroTik N0212 Connection opened by remote host
Jun  4 16:18:48 MikroTik N0212     RemoteAddress=172.22.16.252
Jun  4 16:18:48 MikroTik N0212 Connection closed
Jun  4 16:18:58 MikroTik N0212 Connection opened by remote host
Jun  4 16:18:58 MikroTik N0212     RemoteAddress=172.22.16.252
pcdog
Thu Jun 04, 2020 8:18 pm
I am using a Chateau LTE12
v4 NAT seems a bit broken now.
- MTRs do not fully go through on some hosts with ipv4 only
on other hosts, if I run an mtr on my PC behind it, it will show the whole route, and then jump and cut out the whole icmp unreachables in between so I can see the mtr, until it's complete, then it only shows 2 hosts -that's with ipv6. weird.
- SSH works on ipv6 only, to the same hosts. reducing the MTU on my machine to mtu 1300 on the PC didn't fix it, so it's not an mtu issue. it's just frozen after SSH login
- disabling fasttrack didn't help
any ideas where I can troubleshoot more? it did work fine before, and a ssh connection using MOSH (UDP tunnel) works as well as SSH outbound over ipv6 now. it also works when I connect over an L2TPoverIPSEC tunnel
this only affects FORWARDED connections. it works fine originating from the chateau outbound!
happy to give remote access if MTIK staff wants to look at it more. It's an elisa 4g connection....
G2Dolphin
Thu Jun 04, 2020 8:51 pm
Can't believe my eyes. L3 HW offloading and Linux kernel v5.6.3, what a jump from v4.14. What's next, WireGuard and HW NAT? :)
You're amazing, guys! Gonna play around with spare RB3011 to test everything.
floaty
Thu Jun 04, 2020 8:58 pm
and VRF ! that's rich !
[admin@chr] > ip vrf add list=vrf-if-list-red name=vrf-red
03:52:05 echo: radvd,debug skip Router Advertisement sending on bridge2: no prefixes to send
[admin@chr] >
03:52:11 echo: system,info vrf-red added by admin
03:52:11 echo: route,debug,calc 3 Main publish
[admin@chr] >
[admin@chr] >
Florian
Thu Jun 04, 2020 8:59 pm
IPv6 fasttrack/path (or any form of faster ipv6) would be nice :D
But it's already a big step to see V7.0 here... Congrats !
Paternot
Forum Veteran
Forum Veteran
Thu Jun 04, 2020 9:02 pm
Kernel 5.6.3, so little time after 4.x... Does it mean that RoS is using the official drivers, instead of Mikrotik's?
r00t
Long time Member
Long time Member
Thu Jun 04, 2020 9:23 pm
Anyone seeing same increased amount of flash writes as seen for v6.47? Or does that not affect ROS 7?
My test results are kind of inconclusive... not sure if it's higher than before or not.
ErfanDL
Thu Jun 04, 2020 9:26 pm
new kernel mean better wifi performance?
Sent from my SM-A705FN using Tapatalk
macgaiver
it looks like it happens to a point, if i have to guess filesystem manages something and then it goes away, at least on my boards, maybe MT can comment, I have seen the same behaviur both in v6 and v7 now.
santyx32
Thu Jun 04, 2020 9:36 pm
it feels a bit faster but maybe placebo
cfcnightmare
Thu Jun 04, 2020 9:58 pm
x86 version broken or its netinstall?
trying to install on usb flash and its error
santyx32
Thu Jun 04, 2020 10:00 pm
AFAIK Mikrotik uses its own drivers to allow faster kernel upgrades
mafiosa
Thu Jun 04, 2020 10:16 pm
How do I get access to rosv7 documentation? Would be using on vultr vps for bgp. ROSv7 beta8 solves a lot of the issues that makes mikrotik usable.
doush
Long time Member
Long time Member
Thu Jun 04, 2020 10:50 pm
Great work.
It is very nice to see HW acceleration of routes and also surprised to see Flowspec.
Now we need HW Acceleration of "Traffic-Flow" to complement Flowspec.
Under D/DOS, if traffic flow is enabled, halts the router by consuming all the CPUs.
Beone
Trainer
Trainer
Thu Jun 04, 2020 11:15 pm
having the same issue, support did not reply
Paternot
Forum Veteran
Forum Veteran
Thu Jun 04, 2020 11:17 pm
Mikrotik does uses (used to?) its own drivers - one of the reasons for the slow upgrade turnaround - it is truly hell to debug this kind of thing.
bpwl
Thu Jun 04, 2020 11:31 pm
What an update!!
There is more than in the release notes and so there is always hope: "*) other minor fixes and improvements;"
Is there anything changed in the New User Manager ? (that allows for WPA2/EAP and WPA/EAP authentication but did not work for Windows 10 client devices. (No problems with other clients))
viewtopic.php?f=1&t=185562#p775022
hel
Thu Jun 04, 2020 11:33 pm
After a clean ros7b8 netinstall on my hAP lite classic I couldn't access it via winbox or putty.
Winbox, after logging in and after "something (forgot what) descriptors" phase says "ERROR: cannot open source file".
In putty I can login, but after ROS logo there's nothing I can do, I could write anything and I do not receive any reply.
Reverted to a 6.47 using netinstall.
tpedko
Fri Jun 05, 2020 12:55 am
5G WiFi does not work on RB4011iGS+5HacQ2HnD
osc86
Fri Jun 05, 2020 1:38 am
Did someone already check if enabling igmp-snooping still breaks IPv6 connectivity like in V6?
mducharme
Trainer
Trainer
Fri Jun 05, 2020 2:15 am
I upgraded my hAP mini from 7 beta 5 to 7 beta 8 and the same thing happened. I tried a factory reset on it and it did reset (I could see the name went back to MikroTik in the neighbor discovery packets) but no change to the behavior.
floaty
Fri Jun 05, 2020 2:47 am
Winbox 3.24 crashes after setting up VRF and opening '/IP/routes' dialog ( ...and crashes immediately after trying to reopen)
[admin@chr-7-1] > ip route print
Flags: D - DYNAMIC; A - ACTIVE; C - CONNECT, S - STATIC, m - MODEM
Columns: DST-ADDRESS, GATEWAY, DISTANCE
  #       DST-ADDRESS             GATEWAY                D
  0   AS  0.0.0.0/0               192.168.222.25         1
     DAC  10.1.1.0/24             ether2                 0
     DAC  192.168.222.0/24        bridge1                0
     DAC  172.16.30.0/24@vrf-red  71-e2-vlan100@vrf-red  0
[admin@chr-7-1] >
[admin@chr-7-1] >
[admin@chr-7-1] >
[admin@chr-7-1] > routing/table/print
Flags: D - dynamic; X - disabled, I - invalid; U - used
 0 D   name="main" fib
 1 D   name="vrf-red" fib
[admin@chr-7-1] >
[admin@chr-7-1] >
[admin@chr-7-1] >
[admin@chr-7-1] > ping 172.16.30.2 arp-ping=yes interface=71-e2-vlan100
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 00:0C:29:CB:EC:F0                                 0ms
    1 00:0C:29:CB:EC:F0                                 0ms
    2 00:0C:29:CB:EC:F0                                 0ms
    3 00:0C:29:CB:EC:F0                                 0ms
    4 00:0C:29:CB:EC:F0                                 0ms
    sent=5 received=5 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@chr-7-1] >
[admin@chr-7-2] > ip route print
  0   AS  0.0.0.0                 192.168.222.254        1
     DAC  192.168.222.0/24        ether1                 0
     DAC  172.16.30.0/24@vrf-red  72-e2-vlan100@vrf-red  0
[admin@chr-7-2] >
[admin@chr-7-2] >
[admin@chr-7-2] >
[admin@chr-7-2] > routing/table/print
 0 D   name="main" fib
[admin@chr-7-2] >
[admin@chr-7-2] >
[admin@chr-7-2] >
[admin@chr-7-2] > ping 172.16.30.1 arp-ping=yes interface=72-e2-vlan100
    0 00:0C:29:BD:76:B9                                 0ms
    1 00:0C:29:BD:76:B9                                 0ms
    2 00:0C:29:BD:76:B9                                 0ms
    3 00:0C:29:BD:76:B9                                 0ms
[admin@chr-7-2] >
[admin@chr-7-2] >
sundalez
Fri Jun 05, 2020 4:03 am
Im not sure what Mikrotik has done, but look at these numbers with latest ROS7 beta8 on the newly released ccr2004
Over 200 gig duplex against localhost ?
zandhaas
Fri Jun 05, 2020 10:29 am
Do you know what this was before you upgraded to ROS7b8?
kamillo
Fri Jun 05, 2020 10:41 am
They increased MTU size on the loopback interface in 6.47
*) interface - increased loopback interface MTU to 65536;
I would guess they did the same in v7
D13410N3
Fri Jun 05, 2020 12:30 pm
Same issue for me
krisjanisj
Fri Jun 05, 2020 12:58 pm
cfcnightmare & D13410N3 - Does the same error pops-up if You try to install v6 x86 package with 7.0beta8 netinstall?
netzwerghh
Fri Jun 05, 2020 1:42 pm
Great to see BGP finally! Is there andy documentation of the new bgp config style yet? Seems the whole CLI logic changed for BGP. I was able to configure a basic setup but am wondering what all those options actually mean.
mrz
Fri Jun 05, 2020 1:43 pm
Those parameters are subject to change, so no manual for now.
cfcnightmare
Fri Jun 05, 2020 2:17 pm
The package in download section is not even marked as x86
cfcnightmare
Fri Jun 05, 2020 5:08 pm
Do you test it before upload to the downlod section?
Using test version we are beta testers (or alpha) so you need to exclude such primitive things like that
floaty
Fri Jun 05, 2020 5:22 pm
user-manager / radiusd:
chap-authentication works
eap works ! ( : [] )
no logging messages echoed to terminal-session for:
[admin@chr-7-1] > /system/logging/print
Flags: X - DISABLED, I - INVALID; * - DEFAULT
Columns: TOPICS, ACTION
   #      TOPICS    ACTION
### snip ###
   4      radius    echo
mafiosa
Fri Jun 05, 2020 6:05 pm
GRE tunnels don't seem to work!
mafiosa
Fri Jun 05, 2020 6:09 pm
Sorry GRE works only the keepalive doesn't! After upgarding from v6.47 to v7beta 8 the tunnels stopped working. After reset same issue persists. WHen I turned off the keep alive it works fine. However the other end v6.47 works absolutely fine with keepalives on or off.
pe1chl
Fri Jun 05, 2020 6:46 pm
Keepalives do not work in stock Linux either. Probably they had made a patch for it and it has not (yet) been applied to the kernel used with v7.
However, usually you do not need keepalives. I suggest that by default they are kept OFF and only enabled when the admin explicitly selects it.
arm920t
Fri Jun 05, 2020 7:30 pm
Netinstall is broken too.Use PXE to boot from lan.Device did not appear on the window.I got this error message:
Kernel panic - not syncing: VFS:Unable to mount root fs on unkown -block(0,0)
Kernel Offset: disabled
Rebooting in 5 seconds..
Also tried to upgrade from Beta 4 to Beta 8.The log said "Not enough memory".Same error as upgrade from Beta 4 to Beta 5.But the flash disk is totally empty.
sundalez
Fri Jun 05, 2020 7:36 pm
That makes sense, missed that :)
HzMeister
Fri Jun 05, 2020 7:55 pm
Where is CAKE?!?!?!?
Literally everyone expects it, yet there's nothing about it from mikrotik..
Kind of pathetic on their part tbh.
bpwl
Fri Jun 05, 2020 7:57 pm
Simple test on "Omnitik 5 ac". Setting up WLAN2 failed !!!
- WLAN1 is "station bridge" (the way this Omnitik is part of my test setup)
- added virtual WLAN2 as "Ap bridge" (to test TXpower on "all rates fixed" with regulatory domain (as antenna gain is gone) . To see the power I need to capture it in "Wifi analyzer".)
... No luck, no signal (even after the longest DFS delay) so I cannot measure and cannot connect
- added virtual WLAN3 (just trying to get forward with different settings) as "bridge" . No problem it is immediatly visible. Smartphone connects.
- changed WLAN2 to "bridge" , no success
- changed WLAN3 to "AP bridge" , OK no problem
- removed WLAN2 as it had 02:00:00:AA:00:00 as MAC address !?
- entered new WLAN2 as "bridge" mode, it got a normal MAC address
- normal MAC address, but disconnected one minute later WLAN1 and after reconnection there was again that local MAC address on WLAN2. WLAN2 cannot be used.
Epilog: TX power follows "all rates fixed"settings , but that TX power cannot be seen on the Mikrotik (it always indicates "max power of the region - antenna gain") in the status/Channel but it transmits differently.
EDIT: tested some more .... WLAN2=bad, WLAN3=OK, WLAN4=bad, WLAN5=OK
EDIT2: the disconnects were reboots without proper shutdown, crashes ?
mada3k
Long time Member
Long time Member
Fri Jun 05, 2020 8:33 pm
WOW. Thats som heavy features and updates :shock:
bpwl
Fri Jun 05, 2020 9:05 pm
Strange screen refresh in WinBOX/terminal.
In 7.0beta8 if you scroll up/down the characters are incomplete. Not so for older ROS version.
Just pressing "shift" in that window already corrects the screen.
EDIT : only happens when WinBOX is not full screen on the PC.
mrz
Fri Jun 05, 2020 9:11 pm
You can find cakes here:
https://majaskukas.lv/
Even trendy gluten free ones, which probably you like the most.
floaty
Fri Jun 05, 2020 9:25 pm
yepp: buttercream !
... my doc told me !
sstybel
Fri Jun 05, 2020 10:26 pm
I upgrade my wAP ac from ROS 6.47 to 7beta 8 by the Netinstall and now couldn't connect with them by the WinBox or SSH.
When I try ping default IP (192.168.88.1), some ICMP packet was lost.
Best regards,
Sebastian
Jotne
Fri Jun 05, 2020 10:44 pm
/ip accouning
is missing in latest beta.
This breaks my Splunk script.
:local AccuntData true
# Get traffic data (accounting data)
if ($AccuntData) do={
# Test if fasttrack is enabled and give warning
	:if ([/ip firewall filter find where (action=fasttrack-connection && !disabled)] != "") do={
		:log info message=("script=traffic,fasttrack=1")
	} else={
		:log info message=("script=traffic,fasttrack=0")
# Test if accounting is enabled and if yes, get data
	if ([/ip accounting get enabled]=yes) do={
		/ip accounting snapshot take
# Get uncounted data
		do {
			/ip accounting uncounted {
				:log info message=("script=uncounted,bytes=".[get bytes].",packets=".[get packets])
		} on-error={}
# Send data to loggin server
		foreach logline in=[/ip accounting snapshot find] do={
			:local output "$[/ip accounting snapshot print as-value from=$logline]"
			:set ( "$output"->"script" ) "traffic"
			:log info message="$output"
Even if I try the
do={
:my script
} on-error={}
it fails.
I though that I read some about better logging of script error in v7, but no trace of broken script in the log. And its a pain to see what parts fails. I need to cut an past part by part to the terminal and see what is giving eror.
mrz
Fri Jun 05, 2020 10:59 pm
IP Acccounting is deprecated and removed from ROS v7.
Jotne
Fri Jun 05, 2020 11:48 pm
What do I use then to get traffic data from each client that I do use in Splunk for MikroTik?
SNMP is not an option.
Script will then fail 100% if some do an upgrade to 7.x, since on-error seem to not handle this situation.
andriys
Sat Jun 06, 2020 12:22 am
NetFlow is an obvious choice for that kind of data.
Jotne
Sat Jun 06, 2020 12:32 am
Did forget about Netflow. Will have a look at it.
I do see that this needs an extra input to work on my server. Accounting do work with Syslog that I already uses.
floaty
Sat Jun 06, 2020 12:58 am
sad ... evolution ... in fact ... there's in all times a child behind
I'm a sad mammal to say so ... :shock:
I'm great splunk fan !! ... but I'm doing graylog ... until I'm not !
killersoft
Sat Jun 06, 2020 4:23 am
LtAP mini VS v7.0beta 8
Well the wifi via a station & station bridge mode does not work. It connects briefly(10 seconds), then drops( no its not a signal, issue, 6.47 works a treat on the same unit)).
I have a Quectel EC25 LTE board in it. That works no problem !
Doing a WiFi SCAN produces random MAC & SSID's as per image below :
santyx32
Sat Jun 06, 2020 4:32 am
We're talking about this 🍰 https://www.bufferbloat.net/projects/codel/wiki/Cake/ right?
killersoft
Sat Jun 06, 2020 4:53 am
There is another thread for feature requests..
Also queuing has to be one of the lowest priority's right now.
idnawsi
Sat Jun 06, 2020 10:41 am
routes nexthops unreachable, and sometimes it got disconnected without any reason.
pe1chl
Sat Jun 06, 2020 1:07 pm
I used /ip accounting in the past but switched to netflow which has a lot more capability and can also do IPv6.
I wrote a simple Perl program (using Net::Flow library) to collect the netflow traffic and write it to a tab-separated file where I can run some other scripts to collect some statistic info.
Of course there are nice graphical netflow analyzers available but this was not required in my case (it is mainly for logging in case of complaints).
doush
Long time Member
Long time Member
Sat Jun 06, 2020 1:12 pm
As I mentioned earlier, Netflow/Traffic Flow also needs a rewrite or hardware acceleration on RouterOS.
Traffic flow consumes all the CPU resources in case of an ddos attack.
nevolex
Sat Jun 06, 2020 2:25 pm
Amazing what a fresh kernel, hi wireguard!
Thanks guys
Linux1976
Sat Jun 06, 2020 2:42 pm
Upgrade from 6.47rc2 to 7beta8 on RB3011 changed Software ID and results in lost license. So no further testing for me.
mrz
Sat Jun 06, 2020 6:32 pm
On-error catches only runtime errors. With syntax errors (which is what unknown keyword, remowed command is) script does not even start.
brimfulnick
Sat Jun 06, 2020 7:44 pm
Not everyone is 'expecting' it. Whilst fq_codel / cake would be nice, I don't feel it should be implmented at the detriment of implementing other features
stucchimax
Sat Jun 06, 2020 9:30 pm
On a new RB4011 I am having issues running BGP for IPv6. I have a session for IPv4 that works perfectly, but IPv6 does not seem to announce and originate anything.
Here is the situation:
add local.role=ebgp remote.address=x.x.x.x .as=xxxx template=net4
add local.address=2xxx:xxx:xxx::10 .role=ebgp remote.address=2xxx:xxx:xxx::1 .as=xxxxx template=\
    net6
add local.role=ebgp remote.address=2xxx:xxxx:1::36 .as=65000 template=net6
Here's the template
add address-families=ip as=xxxxx name=net4 output.filter=""
add address-families=ipv6 apply-changes=auto as=xxxxx instance=default name=net6 output.filter=""
And the static routes
add dst-address=xxx.xxx.xxx.x/22 gateway="" type=unreachable
/ipv6 route
add dst-address=2xxx:xxxx::/29 gateway="" type=unreachable
The session gets set up, but no routes are exchanged over IPv6. Again, the same config with IPv4 works perfectly.
Am I missing something, or is this a bug ?
hel
Sun Jun 07, 2020 5:25 am
I agree. First priority is to get ROS7 at least as stable as ROS6. And then implement new features.
Personally I wait for SQM like fq_codel, CAKE too. We are trying to provide more comfortable service for our customers. This feature is one that we think improve it (but not 100% sure about it).
Devs, please check if smips version still have problems with ipsec.
On every 7beta I have problems with it. It (I think) maxing CPU to 100% when tunnel is working or looping through some phases of connecting. When this happens I lose connectivity to my router. Only way to restore my access in this situation is to unplug the cable from internet so ipsec will stop connecting. I had similar problem on ROS7b8 (just having problems with connecting winbox to confirm it), my router stopped responding until I have disconnected cable from internet. This is an only problem stopping me to test ros7, because I need an ipsec tunnel everyday.
ipsec config:
/ip ipsec policy group add name=Peak
/ip ipsec profile add dh-group=modp1024 enc-algorithm=aes-128 hash-algorithm=sha256 name=profile_1 nat-traversal=no
/ip ipsec peer add address=123.123.123.123/32 local-address=11.11.11.11 name=peak profile=profile_1
/ip ipsec proposal add auth-algorithms=sha256 enc-algorithms=aes-128-cbc name=peak
/ip ipsec identity add auth-method=digital-signature certificate=local-cert peer=peak policy-template-group=Peak remote-certificate=remote-cert
/ip ipsec policy add dst-address=123.123.123.123/32 peer=peak proposal=peak sa-dst-address=123.123.123.123 sa-src-address=11.11.11.11 src-address=11.11.11.11/32 tunnel=yes
Disabling ipsec peer and policy let me connect router to internet without problems.
On 6.47 I didn't see that ipsec could eat so much CPU, I could push ~20mbit/s of encrypted traffic between ipsec peers with only 80% of CPU load and it didn't break any other connectivity.
pawelbien
Sun Jun 07, 2020 5:30 am
Thank you for your hard work guys, really appreciate it. I'm happy with every v7 milestone, and this edition is certainly it.
MT should focus on releasing v7 asap after providing functionality similar to v6. Without looking at all the requests for the new features. There will be time for that later.
whatever
Sun Jun 07, 2020 1:45 pm
That is a really pleasant surprise. Never expected to see a 5.x kernel in ROS after TILE architecture has been removed from upstream Linux.
normis
Sun Jun 07, 2020 2:34 pm
TILE support in RouterOS never depended on the kernel
cfcnightmare
Sun Jun 07, 2020 3:01 pm
How about x86 version? Did you checked it?
Even write to usb flash is not working....
mducharme
Trainer
Trainer
Mon Jun 08, 2020 4:29 am
5GHz interface on RB4011 wifi model is not working in 7.0beta8. It is in ap bridge mode. Scan shows nothing, devices do not see the SSID. I have 6.47 on another partition on the same device and rebooting to that makes it work again. The 2.4GHz interface works fine in either.
Strangely, my Audience wlan3, which uses the same chip (QCA9984), seems to work fine. I set it up as "ap bridge" and I can connect to it.
My RB4011 cannot even connect as "station bridge" to the Audience, but other devices can, like my iPhone.
When I try connecting the RB4011 wlan1 as either bridge or station bridge to the Audience wlan3 in "ap bridge" mode, it seems to see it at first and tries connecting, but I get "association timeout" in the log.
Whatever the the problem is, it seems specific to the RB4011 wifi model and not the QCA9984 chip. It does not work even if I reset to factory defaults, so it is not a config issue.
mducharme
Trainer
Trainer
Mon Jun 08, 2020 6:29 am
Thank you for this - I am having the same issue on my smips device (hAP mini). It is running 7.0beta8. I am not using it as a router so I had ether1 connected but it refused to connect via winbox or terminal (ssh/telnet). I plugged in ether2 instead and rebooted it, and now I can log into winbox and everything works, but terminal still does not (it freezes). The issue does not seem to involve the configuration of the port (on my device ether1 was not set up as an "internet" port in any way), but instead whether there is a cable plugged into ether1 or not.
bpwl
Mon Jun 08, 2020 11:05 am
My experience is that all even numbered WLAN do not work. Check the MAC address.
Add a virtual WLAN and use only the ODD interface numbers
viewtopic.php?f=1&t=161980#p798313
cfcnightmare
Mon Jun 08, 2020 2:39 pm
What about x86 version?
Can you solve the issue i wrote before?
pe1chl
Mon Jun 08, 2020 2:48 pm
Please do not repeat the same thing over and over again!
slackR
Mon Jun 08, 2020 8:44 pm
Tried to load beta8 on a rb1200 and get a kernel panic
RouterBOOT booter 6.47
RouterBoard 1200
CPU frequency: 1000 MHz
Memory size: 512 MiB
NAND size: 64 MiB
Press <delete> key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Starting...
Oops: Machine check, sig: 7 [#1]
BE PAGE_SIZE=4K RB1200
CPU: 0 PID: 41 Comm: sysinit Tainted: G M 5.6.3-440 #7
NIP: a10758ac LR: a1076f90 CTR: 00000000
REGS: 9ffeff08 TRAP: 0214 Tainted: G M (5.6.3-440)
MSR: 00029000 <CE,EE,ME> CR: 84000208 XER: 00000000
GPR00: a1076f3c 9e491cf8 9f734600 000000f8 00000000 00000000 000000fc 80499990
GPR08: 8047e1e4 a9015114 80480000 9e491cb8 24000208 10028298 a107d000 8038720d
GPR16: a107e094 00000039 803e52dc 00000124 8007297c 00000010 9f5f0a24 00000488
GPR24: a4f8b384 a107b448 9f5f0a24 a1080000 00015000 00000124 a107b284 a107b094
NIP [a10758ac] get_hcfg+0x118/0x124 [flash@0xa1075000]
LR [a1076f90] init_module+0x280/0x408 [flash@0xa1075000]
Call Trace:
[9e491cf8] [a1076f3c] init_module+0x22c/0x408 [flash@0xa1075000] (unreliable)
[9e491d28] [80002a54] do_one_initcall+0x7c/0x154
[9e491da8] [80074258] do_init_module+0x6c/0x1e0
[9e491dd8] [80075dc8] load_module+0x1974/0x1bb4
[9e491ea8] [80076174] sys_finit_module+0x8c/0x94
[9e491f38] [8000b168] ret_from_syscall+0x0/0x38
--- interrupt: c01 at 0x77edf204
LR = 0x77eb98c4
Instruction dump:
90010024 48003a79 80010024 80610008 38210020 7c0803a6 4e800020 3d20a108
8129b080 7d291a14 7c0004ac 80690000 <0c030000> 4c00012c 4e800020 3d20a108
---[ end trace 1e39f59b6d518d6a ]---
Kernel panic - not syncing: Fatal exception
Sob
Mon Jun 08, 2020 10:22 pm
Sorry for nagging, but can you please help me understand, why is there this combined dst-address parameter for other routing tables?
/ip route add ... dst-address=<destination>@<routing table>
I still can't wrap my head around it. Why not separate and intuitive:
/ip route add ... dst-address=<destination> table=<routing table>
like everywhere else? This is like if there was:
/interface bridge port add ... interface=<interface>@<bridge>
/ip firewall address-list add ... address=<address>@<list>
/ip firewall filter add ... action=<action>@<chain>
It would be weird. Or am I missing some deeper idea, why the combined parameter is better?
pe1chl
Mon Jun 08, 2020 10:54 pm
Maybe it is the direction that all parameters will be moving?
I see in BGP that there is things like "remote.address" too, apparently structuring several parameters under groups like "local" and "remote".
(such a parameter would have been called "remote-address" before)
dbouwer
Wed Jun 10, 2020 3:07 pm
Sierra Wireless AirPrime MC7304 interface statistics are showing Gbps...
.See attached.
joshfinlay
Thu Jun 11, 2020 1:38 am
Unsure if this has been reported yet.
ROSv7b8 CHR on Proxmox
Configuration does not preserve across reboots, but log file does.
Expectation: Configuration preserves
Steps to reproduce:
Create VM in Proxmox
qm importdisk <VMID> chr-7.0beta8.img <storage>
Boot VM
Login. Make config changes. See working.
Reboot.
Result: Configuration restored to default after reboot
Chupaka
Thu Jun 11, 2020 12:05 pm
When in WinBox 3.24 I go to IP -> Routes, click "Add" and type "8.8.8.8@" in Dst. Address, WinBox hungs and, a few seconds later, disappears. Is it only me with Wine on MacOS, or the problem is repeatable everywhere?
LetMeRepair
Fri Jun 12, 2020 8:51 am
Is the any hardware requirements for ROS 7 (Beta 8 )? I have tried to test it on RB411UAHR (with Sierra MC8792V modem installed).
First did regular upgrade but it ends in a boot loop.
RouterBOOT booter 7.0beta8
RouterBoard 411UAHR
CPU frequency: 680 MHz
  Memory size:  64 MiB
    NAND size:  64 MiB
Press any key within 2 seconds to enter setup..
trying bootp protocol............... failed
kernel loading failed
Starting...
Starting services...
MikroTik 7.0beta8 (development)
MikroTik Login:
RouterBoard 411UAHR
  Memory size:  64 MiB
    NAND size:  64 MiB
Did netinstall after this, it said it couldn't keep config so the box is back to defaults also. Still boot loop.
Downgrade to 6.47 (netinstall) works fine.
If I can provide any additional data to help debug let me know. If the box is just too old or something, oh well I would understand that. For me it's just a test router anyway, but have no big one free at the moment for testing.
floaty
Fri Jun 12, 2020 4:12 pm
it's general
dkenguru
Fri Jun 12, 2020 4:57 pm
2.4Ghz wireless don't work on hAP AC.
It's running, but any client's can't connect.
5Ghz works fine.
ferarrese
Fri Jun 12, 2020 8:01 pm
Hello, I see that you are a new colleague on the forum and you may not have learned to use the tool. Or don't learn to be pasciente yet.
Even though this is not the place to answer your question, here's your answer:
viewtopic.php?f=1&t=160929&p=799906#p799906
You can also use furum search which will also find a solution to your problem.
Be welcome
cfcnightmare
Fri Jun 12, 2020 8:18 pm
Be welcome
Do you understand that you cannot even write it to a usb flash?
Why you give me that link?
jvanhambelgium
Forum Veteran
Forum Veteran
Fri Jun 12, 2020 8:33 pm
So far I've not been able to find a free Netflow collector that actually works.
I've tried dozens...almost got it working with ElasticFlow (https://www.catapultsystems.com/blogs/i ... 04-part-1/)
Very sad IP-accounting will be gone in ROS7 , can't understand why. This "features" is not something cutting edge that needed works or was full of bugs to my understanding. It just basically works and is no rocket-science.
ferarrese
Fri Jun 12, 2020 9:11 pm
Be welcome
Friend, if you just read the whole topic, you will see that this same problem has already been solved in another way
then the mikrotik support indicates to download an ISO of the installer and install directly on the flash.
I'll draw for you to understand:
https://box.mikrotik.com/f/092549ada5484eeab7bb/
Download the file, write to the flash drive with the Rufus utility (https://rufus.ie/)
and boot.
If you have any other specific problem, I would like to open a post on the forum to avoid polluting this POST, dedicated to the BUG of the new version of RouterOS.
Concluding this matter.
Thank you and good luck!
cfcnightmare
Fri Jun 12, 2020 9:15 pm
Did you see iso there?
pe1chl
Fri Jun 12, 2020 11:40 pm
I wrote my own in Perl, it uses Net::Flow and it writes tab-separated files (1 flow per line).
It is based on an example provided with Net::Flow. I could post it in a forum topic.
arm920t
Sat Jun 13, 2020 1:28 pm
Be welcome
and boot.
Not work! My system has two sata disk.I burned the iso into one and boot from it.Loading the linux kernel and report no disk found. I had changed the disk from sata to ide model. I does not work too.
I searched the comminuity and found this is a very old problem and did not solved till now.
mkx
Sat Jun 13, 2020 4:37 pm
Boot process (which is not the same as kernel) complained about CD-ROM not found. So the install package has to be started from a device which presents itself as CD-ROM, not as hard disk. Which is easy under VM, not so easy under barebone hardware.
Paternot
Forum Veteran
Forum Veteran
Sat Jun 13, 2020 6:06 pm
But is it an ISO boot image? I never bothered with the x86 version.
If it is just an installation iso image, then one can just do a "cat file.iso > /dev/<flashdrive>; flush" and be done with the iso image. If the ISO is a normal one (Windows needs something more than a Distro ISO), it should boot as a CD.
WARNING: This will ERASE everything on the destination flashdrive - even the partition table. Be warned.
mkx
Sat Jun 13, 2020 6:53 pm
Traditionally ISO images could only be used in CD and DVD physical media. And if software reading it wasn't too smart, it would choke if ISO image was "burned" on some other type of medium (such as HD). Quite a few linux installers were made so that they were looking for installation medium on CD-ROM type of devices.
Initially wasn't so, nowdays many USB sticks can present themselves either as HDD or CD-ROM to the host OS and modern linux distributions come as "hybrid ISOs" that can be simply written to USB stick ... probably not to more traditional HDD or SSD. Additionally modern installers scan all storage devices for installation medium.
Mind that all of this is pretty modern stuff, we all know Mikrotik is curently lagging behind in many aspects so one should not be too surprised if something which is otherwise usual fails in ROS. Good knowledge of computing history (at least last 15 years) helps to understand the shortcomings.
Jotne
Sat Jun 13, 2020 10:59 pm
Did try netflow for Splunk, but does not get it to work.
It also add a new port to listen to, not only Syslog. Not sure if nteflow work over long internet connection.
Why not just leave the working accounting that are in all Router OS up until 7.beta 6 (not in beta 8 )
Or MT can do a poll and ask if its ok to remove a function. Maybe its not only me and all the Splunk user who uses it... :(
LetMeRepair
Sun Jun 14, 2020 12:05 am
OMG why didn't anyone mention yet: UDP support on OpenVPN???
Feels like that was longer on the wishlist than anything else!
Uxorious
Sun Jun 14, 2020 1:26 am
Still issues with NTP server names.
UI gives an error when entering a server name.
Doing this: "/system/ntp/client/set enabled=yes servers=us.pool.ntp.org" will work, but the Address field will be blank and the resolved-address will be correct.
After that, "/export" does not include the server.
pe1chl
Sun Jun 14, 2020 11:46 am
Nobody appreciates that anymore, the whiners have moved on to requesting Wireguard....
msatter
Sun Jun 14, 2020 11:56 am
And we got a Linux version that supports Wireguard. So endless whining is avoided.
RouterOS eight would not be there in my lifetime.
mbovenka
Sun Jun 14, 2020 12:06 pm
Anyone else having problems with the CCR1036-8G-2S+ USB port under 7.0b8?
I upgraded my CCR from 6.46.1 to get my Huawei 3372h-320 working (tested on a hAP ac). But on my CCR, the stick isn't recognized. In fact, nothing is; nothing shows up in USB resources, whatever I connect to it (USB memory stick, Android phone, 4G stick). And nothing I connect to the USB port recognizes that there is anything at the other end (The Android phone doesn't go into USB tethering for instance, which works fine in 6.46.1, and gives me a working 'LTE' interface).
It looks like it just delivers power (it does do that: the phone charges), but nothing else. I have opened a ticket with support, we'll see what drops out.
pe1chl
Sun Jun 14, 2020 12:43 pm
RouterOS v6 runs on a Linux version that supports OpenVPN with UDP, and we all know what happened there...
"the Linux version supporting it" is amongst the many different points deciding if something is added to RouterOS.
That is why I think it is a good idea to allow for user code to run in a sandbox. So people can add what they need
even when MikroTik does not consider it to be worth it.
(of course this does not really work for every feature one can think of, but for some of them it would)
normis
Mon Jun 15, 2020 8:24 am
BTW the IMG file is also available, just don't use the ISO for installation.
arm920t
Mon Jun 15, 2020 11:24 am
Finally i installed ros V7 Beta5 under barebone hardware with the help of Vmware workstation.The boot partition is 35MB now which is bigger than previous(upgraded from V6).Thanks for your help.
pe1chl
Tue Jun 16, 2020 12:46 pm
Can you please add the "rpfilter" matcher to the firewall matching rule options?
See viewtopic.php?f=2&t=120863 and viewtopic.php?f=14&t=56572
wenasong
Tue Jun 16, 2020 1:16 pm
Just to check. I have my interfaces detected and running well on 7beta5, but after upgrading to 7beta8, all interfaces gone from the list,
also... somehow I have to wait about 2 minutes before I can use the CLI after login.
Any information to solve this issue?
-Wenas
arm920t
Wed Jun 17, 2020 5:48 am
-Wenas
Same here,The onboard nic works well in beta5 but can not detected in beta 8. I add a connectx-4 lx card and found the system working slowly with 80% cpu usage.Reset configuration or reboot didi not solve the problem. I reinstall beta8 and boot from another motherboard and this time everyting is ok.But after that i added a switch and system became slow again with very hight CPU usage
wenasong
Wed Jun 17, 2020 10:59 am
-Wenas
Do you have any info on how to reinstall to Beta8, netinstall doesn't work for me. ISO only 7beta5 is available.
normis
Wed Jun 17, 2020 11:12 am
What is not working with Netinstall? Any error?
cfcnightmare
Wed Jun 17, 2020 12:47 pm
I posted screenshot above....
arm920t
Wed Jun 17, 2020 1:33 pm
-Wenas
Use Vmware Workstation to boot from 7beta5 iso. Mount the physical disk into vmware and install 7beta5 . Plug the disk to your x86 router and boot from it. Use the npk file to upgrade to 7beta8.
Vmware will solve the "can not find CD-ROM" error when you use the iso for installation
You can make your own 7beta8 ISO file , Just use the ULTRA ISO to edit the 7beta5 iso file and replace the routeros.npk in it with the routeros-x86-7.0beta8.npk (rename to routeros.npk)
telepro
Wed Jun 17, 2020 7:06 pm
On RB951G-2HnD running V7.0beta8, unable to successfully load a metarouter image.
Entered command response is as follows:
[admin@FasSat V3.05.03.U016] > /metarouter import-image file-name=openwrt-mr-mips-rootfs.v1.22.01.20200413.tar.gz
import failed: file in archive goes out of root directory: ./FasSat/
Should metarouter capability be available in V7, or is this error something unique to our metarouter image?
Is it Mikrotik's intention to have this available when V7 is released for production usage?
We use this feature on 1600+ 951G2HnD devices with ROS 6.45.8 and do strongly prefer it to remain available.
rushlife
Wed Jun 24, 2020 12:37 am
hi, tried someone ros7.0b8 on CRS354 ?
possible fix for interfaces forwarding problem ?
viewtopic.php?t=160561
angriukas
Thu Jun 25, 2020 10:43 am
ROS 7.0beta8 contains problems with CAPsMAN (or with DHCP)!
Local WiFi interface (on same router) connected via CAPsMAN (in CAPsMAN forwarding mode) cannot deliver DHCP lease, error ocured:
03:01:08 dhcp,warning dhcp1-lan offering lease 192.168.101.253 for MAC-ADDRESS without success
There is no problems with same config on ROS 6.45.x
And because RBD53G-5HacD2HnD cannot be downgraded to 6.X - I am in really big trouble :(
Any suggestions are welcome: how to avoid "lease without success" issue in CAPsMAN forwarding mode?
Update:
In case of CAPsMAN forwarding mode, dynamic cap port in the bridge appears without "Forwarding". And probably this is the reason why DHCP are failing.
I try to set STP protocol to none, unfortunately same problem still exists - "Forwarding" not enabled, DHCP do not working.
trungpro3105
Thu Jun 25, 2020 12:34 pm
Since RouterOS v6.43 it is possible to create a Private VLAN setup on CRS3xx series switches, example can be found in the Switch chip port isolation manual page.
bluecrow76
Sun Jun 28, 2020 11:09 am
Did some testing with BGP this evening. BGP does not work when a TCP MD5 key is specified. Removing the TCP MD5 key requirement from the remote peer allows BGP to connect.
When the TCP MD5 key is specified, there are no error messages on either end regarding an invalid key as would be expected.
This test was done on a hEX S router running ROS 7.0beta8 connecting to a production RB1200 running ROS 6.47.
Example config:
set default as=4274700001
add connect=yes listen=yes local.role=ibgp remote.address=10.23.1.37 template=default tcp-md5-key=abc123
Lupin
Sun Jun 28, 2020 10:48 pm
Mikrotik, with the new kernel do you think to make MPTCP available?
pe1chl
Mon Jun 29, 2020 11:25 am
MPTCP runs on end-systems, not on routers. It would be like asking MikroTik to make QUIC available. It is already available.
eworm
Mon Jun 29, 2020 12:15 pm
Well, RouterOS can be client as well, so for example fetch command could benefit. It's not a big win there, though.
But DoH over QUIC or HTTPS/3 could be worth adding one day... No idea if there are endpoints supporting it already.
bpwl
Mon Jun 29, 2020 3:01 pm
It's probably not only the RouterOS traffic alone that would benefit from MPTCP. If one uses a WAN uplink as client (with NAT etc) then all internet traffic is handled as RouterOS-client on that WAN interface. I have no idea if LAN based TCP could be converted to "aggregated WAN MPTCP", it could just be wishful thinking. I only see improved connectivity with the web-proxy, which is using slightly different HTTP protocols than the clients. (Over satellite it makes quite a difference).
nithinkumar2000
Mon Jun 29, 2020 3:25 pm
Can anyone please confirm wheather IPv6 accounting is added to ROS v7?
Waiting for that from a long time.
ISP need Delegation Prefix for IPDR and since ROS is not having IPv6 Accounting we are unable to fetch the Delegated IPv6 Prefix details...
Hope Mikrotik Team will take this in priority.
pe1chl
Mon Jun 29, 2020 3:42 pm
IP(v4) Accounting has been removed in RouterOS v7. So certainly there has been no IPv6 Accounting added.
Accounting should now be done using Netflow (IP->Traffic Flow) which already supports IPv6 in RouterOS v6.
mrz
Mon Jun 29, 2020 4:24 pm
In case of NAT router is only changing SRC or DST address of the packet, it does not make a connection. So it is still end-to-end system feature.
nithinkumar2000
Mon Jun 29, 2020 4:54 pm
Thank You for the reply. But i was asking about radius accounting for IPv6.
Currently we are unable to get the information about DHCPv6 PD information in radius session log.
We are ISP and it is mandatory for us to log the following Parameters in our IPDR:
1. Session Start Date & Time -> Working
2. Session End Date & Time -> Working
3. IPv4 Address Assigned -> Working
4. IPv6 Prefix Assigned -> Working
5. IPv6 Delegation Assigned -> NOT WORKING
6. MAC Address -> Working
7. User ID -> Working
Because of this issue we are unable to implement IPv6 in our Network.
I Hope all major ISP in INDIA using Mikroitk Router is facing this issue and still we have received no Updates of improvements from the team.
It would be really great if anyone who is having some update/solutions regarding this problem may share here which will be very useful to everyone.
pe1chl
Mon Jun 29, 2020 6:09 pm
Of course it would be possible to use a socks proxy to make a bad TCP implementation work better over a difficult connection (e.g. one that delays or re-orders packets).
A web proxy is another case where that would work.
However, I'm not so sure if it is a good idea to cover up the problems this way, it will likely work better when the end-system TCP is improved.
(I know that some popular operating system has a terrible TCP implementation, but is it everyone-else's problem to fix that?)
Lupin
Mon Jun 29, 2020 10:47 pm
I see MPTCP implemented using OpenWRT on end Router, and a debian/ubuntu on datacenter vps
Creating some tunnel make real aggregation of multiple ISP with different bandwidth, latency instantly
See this example:
https://www.youtube.com/watch?v=YYDZ_8wc5HA
nithinkumar2000
Tue Jun 30, 2020 5:33 am
Anyone?????
mducharme
Trainer
Trainer
Tue Jun 30, 2020 6:56 am
Anyone?????
What we do is run a script every 5 minutes that converts all DHCPv6 dynamic bindings (leases) to static bindings. We backup the config of our PPPoE concentrator every hour, and keep the backups for a very long time period. So, every customer gets the same prefix lease the next time, and if we need to find which customer had a lease, we just need to check the backups of our concentrator. It is not as nice as having this info reported in the RADIUS accounting packets, but in the meantime, it works very well.
DarkNate
Thu Jul 02, 2020 5:15 pm
Hi, I'm a home user using MikroTik as my router. With BSNL FTTH as my ISP. I too have IPv6 problems on MikroTik. I found a hack, it's probably violating some IPv6 specifications, but it works.
Link: viewtopic.php?f=13&t=162930#p802934
However it's not just MikroTik, I've seen the exact same problems even with consumer brands like TP-Link, Netgear, D-Link and even some reports on pfSense.
nithinkumar2000
Fri Jul 03, 2020 9:42 pm
Anyone?????
Thank You so much for the reply @mducharme
It would be really helpful if you can share the script.
Thanks in Advance
mafiosa
Sat Jul 04, 2020 11:48 pm
OSPF doesn't work. All routes learnt by ospf on v7 router is marked as invalid while other v6 routers are learning ospf networks via v7 but traffic is being dropped by v7 router.
nithinkumar2000
Sun Jul 05, 2020 5:07 pm
I Really Appriciate MIKROTIK Team for their wonderful hardwork with ROS v7 :)
But Please add the IPv6 Radius accounting as all ISP are looking for the same from very long time.
ISP's are unable to deploy the IPv6 due to No Radius Accounting for IPv6 and it is really SAD :( that Mikrotik team is not taking any actions towards this issue.
Expecting the Feature at the earliest.
normis
Mon Jul 06, 2020 3:37 pm
nithin kumar
What's new in 6.45.1 (2019-Jun-27 10:23):
*) dhcpv6-server - added RADIUS accounting support with queue based statistics;
It's already in RouterOS.
nithinkumar2000
Mon Jul 06, 2020 5:00 pm
nithin kumar
It is Still Not Working Normis.
We are getting only Remote Prefix but Not the Delegated IPv6 Prefix
mducharme
Trainer
Trainer
Mon Jul 06, 2020 8:09 pm
Thanks in Advance
Schedule this to run every 5 minutes:
/ipv6 dhcp-server binding;
:foreach i in=[find server~"pppoe"] do={
  make-static $i;
  set $i comment=[get $i server];
  set $i server=all;
mducharme
Trainer
Trainer
Mon Jul 06, 2020 8:11 pm
This is because they only added support for DHCPv6 RADIUS accounting in that version where PPPoE is not used. If PPPoE is used, it is still not supported.
nithinkumar2000
Tue Jul 07, 2020 5:31 am
Thanks in Advance
  make-static $i;
  set $i server=all;
Hi mducharme
Thank You so much for your response. :D
mducharme
Trainer
Trainer
Tue Jul 07, 2020 5:58 am
Hi mducharme
No problem - you might potentially be able to extend that script to pull the MAC for the logged in user by pulling the "Caller ID" for that username, and do a /tool fetch to a php page running on the radius server that could capture the mac address plus the lease given at that time and write it to the RADIUS database directly. It shouldn't be too hard.
Obviously we shouldn't have to do it, I was hoping for an official solution from MikroTik sooner and it has not appeared yet. However, as of yet we have not yet gotten a single abuse report for an IPv6 address, but I think that is only a matter of time.
nithinkumar2000
Tue Jul 07, 2020 6:19 am
Hi mducharme
Yes I agree with you mudcharme.
IPv6 is at the Implementation stage only so abuse report is still very low compared to IPv4. But Still the Norms and Regulations here force the ISP to collect all the Delegated and Remote Prefix in IPDR for Complaince purpose.
Hope Mikrotik Team will understand the difficulties and will do the needful at the earliest.
As i tested with other brand routers like CISCO, JUNIPER, HUWAAI and all are ready and working only this issue is seen in Mikrotik Routers from very long time.
I also observerd that many request have been done by many ISPs and WISPs in the forum but still it not answered propoerly by anyone yet.
I am also contacting Mikrotik Support for the same, hope something positive may come from their side..... 8)
pe1chl
Tue Jul 07, 2020 11:52 am
I understood that for such a feature request to have any impact, you need to go to your MikroTik distributor (where you buy the equipment) and ask them to submit a business case to MikroTik sales where they explain how much business they lose because this (or some other) feature is not available in RouterOS.
That is what counts. Not individuals making requests to MikroTik sales or even less here on the forum.
When the sales people at MikroTik notice they lose some big sales because a minor feature is not available, they will ask the developers to implement it.
When you go to MikroTik as an individual, you get the "nobody is ever asking for this" reply. Of course from a sales standpoint that can be explained, because you already bought your router and you notice a problem, and them fixing it is not going to bring them any money, maybe only some goodwill.
I noticed that before when asking for some IPv6 features, the reply usually is that "the customers do not ask for IPv6" so clearly I am not regarded a customer (as I am asking for it!), the distributors are the customers. Which they confirmed.
mducharme
Trainer
Trainer
Tue Jul 07, 2020 11:19 pm
I work for a distributor and we have asked for this already last year.
mikeybreks
Tue Jul 07, 2020 11:53 pm
Hi there,
Just wondering if anyone is successfully using BFD as a gateway check on a static route? I am assuming this can be configured as a standalone option (as in, does not require BGP or other protocols as well) but packet captures show no BFD packets are sent (RB1100). Packet captures shows BFD packets are arriving from the other end (Juniper MX960).
Cheers.
pe1chl
Wed Jul 08, 2020 12:22 pm
In RouterOS, BFD only works in combination with a routing protocol. The setup of BFD only defines parameters like the rate and the number of missed packets before the link is declared down, but the actual activation of BFD takes place in a routing protocol (BGP Peer or OSPF Interface).
The BFD traffic starts when the routing protocol has activated a peer, and the routing protocol is informed when BFD detects a dead peer.
For gateway checks, you can use PING or ARP as config items, or you can use Netwatch or make a custom scheduled script that performs whatever action you want.
mrz
Wed Jul 08, 2020 1:52 pm
Hi there,
Cheers.
You can set it, but functionality is not yet implemented. At the moment reliably you can use only PING check.
mikeybreks
Thu Jul 09, 2020 3:07 am
Hi there,
Cheers.
Thank you MRZ, I'll keep an eye out for future releases.
Cheers.
amirali
Sat Jul 11, 2020 4:14 am
Hi.
is there any chance for wireguard in new kernel ??
nithinkumar2000
Mon Jul 13, 2020 7:54 am
Hi Mikrotik Team,
Please add Vendar attribute for "Parnet Queue" so that we can define the parent queues value from radius auth request itself.
This will help so much for QOS
behrooz
Mon Jul 13, 2020 9:34 am
Hi Mikrotik Team,
Please add the module ISG available at Cisco to the Mikrotik system
In our country, the regulations are such that traffic separation must be done. ISP Replace the Mikrotik router with Seiko. Please add module ISG Add
rushlife
Wed Jul 15, 2020 3:08 pm
+1
thx Mikrotik, very appreciated
rpingar
Long time Member
Long time Member
Sat Jul 18, 2020 6:59 pm
in routing filter the is a bug!
i created two chain: in-v4 and out-v4
Going in templates, the two chain are allowed to be chossen by input.filter but not by out put filter
[admin@test-100G] /routing/bgp/template> set 0 input.filter=
in-v4 out-v4
If I force the chain by writing the name it is not executed by the filter:
[admin@test-100G] /routing/bgp/template> set 1 output.filter="out-v4"
this doen't do anything.
regards
Ros
rpingar
Long time Member
Long time Member
Sun Jul 19, 2020 12:18 pm
in input.filter chain the rpki-verify is not working, infact in the following chain:
1 chain=in-v4 match-rpki=valid rpki-verify=validator action=accept
2 chain=in-v4 match-rpki=invalid rpki-verify=validator action=reject
3 chain=in-v4 action=accept
the first two rules are ignored. We don't see any traffic from mikrotik to routinator except when routinator is added as a validator.
regards
Ros
mrz
Mon Jul 20, 2020 10:23 am
in-v4 out-v4
Output requires selection rules:
/routing filter rule
add action=accept chain=xx
/routing filter select-rule
add chain=xx-select do-where=xx
set 0 output.filter=xx-select
For RPKI rules to match you need to specify against which group to verify, see example here:
https://help.mikrotik.com/docs/display/ ... ading-RPKI
But RPKI still has a bug, that prefixes do not have correct state. It will be fixed in next beta.
emils
Forum Veteran
Forum Veteran
Tue Jul 21, 2020 2:54 pm
New version 7.1beta1 has been released in development RouterOS channel:
viewtopic.php?f=1&t=163957
Chupaka
Tue Jul 21, 2020 6:59 pm
Did I miss 7.0 release? %)
mkx
Tue Jul 21, 2020 8:20 pm
I guess we all miss it very much.
nithinkumar2000
Wed Jul 22, 2020 9:36 am
I Think We will get ROS v7.5 Stable :lol: :lol: :lol:
Users browsing this forum: No registered users and 65 guests
