kcarhc
routing-mark and table and mangle in RouterOS v7 BETA 7
Thu Jun 04, 2020 2:58 pm
here is the code in RouterOS v6, how to make it work in RouterOS v7.
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark new-connection-mark=CON-TEST passthrough=yes dst-address=4.2.2.1
add action=mark-routing chain=prerouting connection-mark=CON-TEST new-routing-mark=IRT-TEST passthrough=no
add check-gateway=ping distance=10 gateway=10.10.54.161 routing-mark=IRT-TEST
add check-gateway=ping distance=10 dst-address=1.1.1.1/32 gateway=10.10.54.145
/ip route rule
add routing-mark=IRT-TEST table=IRT-TEST
add dst-address=8.8.8.8/32 table=IRT-TEST
mrz
Re: routing-mark and table and mangle in RouterOS v7 BETA 7
Thu Jun 04, 2020 3:47 pm
First add table in /routing table menu
THen you can add routing rules in /routing rule menu
and routes in specific table
/ip route add dst-address=x.x.x.x@table gateway=y.y.y.y@main
kcarhc
Thu Jun 04, 2020 4:40 pm
@mrz, please help me translate my code to RouterOS 7.
====================code====================
/ip firewall mangle
/ip route rule
mrz
Thu Jun 04, 2020 4:49 pm
/routing table add name=IRT-TEST fib
add dst-address=0.0.0.0/0@IRT-TEST gateway=10.10.54.161@main check-gateway=ping distance=10
/routing rule
add dst-address=8.8.8.8 action=lookup table=IRT-TEST
firewall the same as v6
kcarhc
Thu Jun 04, 2020 5:25 pm
OK, Thanks, Works well on RouterOS 7
kcarhc
Thu Aug 13, 2020 7:40 pm
add check-gateway=ping distance=10 dst-address=0.0.0.0/0@IRT-TEST gateway=10.10.66.70@main
it works on 7.0 Beta 8
it don't work on v7.1 BETA 1 show this
invalid or unexpected vrf or routing table value
mrz
Fri Aug 14, 2020 8:56 am
kcarhc
Mon Aug 17, 2020 2:57 am
@mrz, please help me translate my code to work on RouterOS 7.1Beta 1. not 7.0 Beta 9
/ip firewall mangle
/ip route rule
mrz
Mon Aug 17, 2020 10:58 am
kcarhc
Tue Aug 18, 2020 4:25 am
here is my code
and this line is work, I known
this line is not work on ROS 7.1 Beat, it works on ROS 7.0 Beta. I need this line.
mrz
Tue Aug 18, 2020 9:39 am
Now again, look at this line from the manual (character by character)
/ip route add dst-address=8.8.8.8 gateway=172.16.1.1@main routing-table=myTable
And compare to what you are trying to set
Hint (again from the manual):
(as per user requests v7.0beta9 adds back 'routing-table' parameter)
kcarhc
Sat Aug 22, 2020 1:02 am
ok thanks. it's work.
add check-gateway=ping distance=10 dst-address=0.0.0.0/0 gateway=10.10.66.70@main routing-table=IRT-TEST
Users browsing this forum: BartoszP and 4 guests
