dadaniel
wAP R 4G registration-status: denied
Thu Jun 04, 2020 4:02 pm
I always have to reboot my wAP R 4G (RouterOS v6.47) twice to get a working connection.
One the first boot I get:
interface lte info lte1
pin-status: ok
functionality: full
manufacturer: MikroTik
model: R11e-4G
revision: R11e-4G_V007
imei: 359147090019841
imsi: 232106601032167
It works after a reboot:
pin-status: ok
registration-status: registered
functionality: full
model: R11e-4G
current-operator: 3 AT
lac: 10157
current-cellid: 31042827
enb-id: 121261
sector-id: 11
phy-cellid: 360
access-technology: Evolved 3G (LTE)
session-uptime: 1h53m35s
earfcn: 1525 (band 3, bandwidth 15Mhz)
rssi: -83dBm
rsrp: -104dBm
rsrq: -10dB
sinr: 11dB
cqi: 12
Is there a way to avoid the need to reboot?
SiB
Re: wAP R 4G registration-status: denied
Thu Jun 04, 2020 4:23 pm
check if any helps you:
usb power-reset
disable and enable it
