mbaldini
CSS326-24G-2S+ to RB960PGS with S+DA0001
Sat Jun 13, 2020 1:52 pm
Hello
I'm deploying a new rack with two switches CSS326-24G-2S+ and a RB960PGS, the routerboard will act as CAPsMAN
Between the two CSS326 switches I use a S+DA0001 SFP+ and it works very well.
I would like to connect the RB960 via SFP, but if I connect another S+DA0001 to the RB960 I cannot get cable link.
I attached some screenshots from configuration of both devices.
Can I solve this problem?
krafg
Re: CSS326-24G-2S+ to RB960PGS with S+DA0001
Thu Jun 18, 2020 1:51 am
Both cables (S+DA0001) are OK, right?
Regards.
mbaldini
Thu Jun 18, 2020 4:07 pm
Hello.
Both cables S+DA0001 are new, so I think they should be OK.
I'll try plugging them in two RB960 (I have both here available and both have SFP port)
I just finished putting cables in a rack with two CRS326 connected with a S+DA0001 and it's working, I connected a CRS112 with a RB760 with another S+DA0001 and it's working.
The problem arise only when I connect CSS326 (with SwitchOS not RouterOS) with RB960.
Could it be a compatibility problem in CSS326 SwitchOS software?
girts
Thu Jun 18, 2020 8:03 pm
Turn off auto-negotiation and force 1G on the interfaces in both ends of the cable.
mbaldini
Sat Jun 20, 2020 8:48 am
I haven't seen the option to turn off auto negotiation in SwitchOs, today I'll go to customer and check if there is the option. Thanks
Users browsing this forum: kennethrc and 93 guests
