mutluit
Forum Veteran
Forum Veteran
Connecting two LANs via two WLANs
Fri Jun 19, 2020 3:45 am
I'll soon perform this WLAN experiment: connecting two LANs via two WLANs using basic IP routing (ie. w/o any tunneling):
             WLAN1(.132.254/24)      WLAN2(.142.254/24)
    WAN1 --------- R1                     R2 ------------ WAN2
             LAN1(.131.254/24)       LAN2(.141.254/24)
Routers R1 and R2 are not cable-connected with each other. Both are hAP ac^2, using just their respective "wlan1" interfaces.
They are in the same room in about 15 meters distance.
Q: How to set a route from LAN1 to LAN2 via WLAN1 and WLAN2 (and vice-versa)?
A:
R1: /ip route add dst-address=192.168.142.0/24 gateway=192.168.132.254
R1: /ip route add dst-address=192.168.141.0/24 gateway=192.168.132.254
R2: /ip route add dst-address=192.168.132.0/24 gateway=192.168.142.254
R2: /ip route add dst-address=192.168.131.0/24 gateway=192.168.142.254
Ie. can the WLANs transport also traffic that is not destined to the WLANs? IMHO should.
Will this work? Can this work?
Users browsing this forum: No registered users and 27 guests
