SoWaR
Change switch port ether1 to ether5 for ISP
Tue Jun 23, 2020 9:59 am
I have mikrotik hap ac and RouterOS 6.42.6.
After lightning strike port ether1 died (as my ISP switch either). I tried to setup ether5 port as replacement for ether1. There are two configs
in attachments: old one (it's worked) and new (it does not).
L2TP status is connected. But I can't reach any non local resources. Local is ok.
I've connected ISP cable directly to desktop and made all setup routine. All worked fine. I trace rote to www.ru and compare the same command in case desktop besides router. May be it will help.
Can you advice me something, please?
direct desktop connection to ISP:
>tracert www.ru
www.ru [31.177.80.70]
1 <1 ms <1 ms <1 ms cisco-10008-0200-po1.kvidex.net [192.168.255.202]
2 <1 ms <1 ms <1 ms cat-6509-sup32-ro2-vl50.kvidex.net [192.168.96.1]
3 <1 ms <1 ms <1 ms cat-6506-border-vl323-te1-1.kvidex.net [93.182.32.21]
4 2 ms 1 ms 1 ms rt-47-msk-ix.rostelecom.ru [195.208.208.238]
5 1 ms 1 ms 1 ms 213.59.211.241
6 1 ms 1 ms 1 ms 5.143.251.250
7 1 ms 1 ms 1 ms ctv-r5.nic.ru [31.177.67.139]
8 2 ms 2 ms 2 ms dp-r5.nic.ru [31.177.67.76]
9 3 ms 4 ms 3 ms dp-gw1.nic.ru [31.177.67.73]
10 2 ms 2 ms 2 ms shop.parking.nic.ru [31.177.80.70]
from the same desktop but through router with new_config:
>tracert www.ru
1 <1 ms <1 ms <1 ms router [192.168.88.1]
2 <1 ms <1 ms <1 ms host-104-124-1.kvidex.net [10.104.124.1]
3 <1 ms <1 ms <1 ms cat-6509-sup32-ro2-vl6-po1.kvidex.net [10.104.0.10]
4 * * * timeout
Users browsing this forum: No registered users and 38 guests
