sch0enbach
10GBASE-T max distance
Tue Jun 23, 2020 2:27 pm
Hey Folks,
I was planing to boost my home network to 10GBASE-T by buying and using the CRS312-4C+8XG-RM Switch. The network is already using CAT7 cables.
In order to use some of the SFP+ ports i opened up the MikroTik SFP module compatibility table and was shocked when i came to the seperated paragraph 3.2 about the CRS312-4C+8XG-RM Switch, which says, that 10GBASE-T is only supported up to 30 meters even when using CAT7 cables, even though CAT7 can offically support up to 100 meters.
No matter if its the SFP+ port or a RJ45 port.
Has anybody any experience if longer ranges are possible or any workaround to get 10Gbit network to every room in my house?
Thanks for advice,
Chris
Users browsing this forum: hwt and 22 guests
