Janevski
OpenVPN hardware
Thu Jun 25, 2020 5:28 pm
What would be the best MikroTik router hardware for OpenVPN performance?
edit: Many users use case, not single user performance.
ksteink
Re: OpenVPN hardware
Tue Jul 14, 2020 4:45 am
None at this moment. Mikrotik’s OVPN implementation sucks for RouterOS ver 6.x:
- Support only for TCP not UDP (Causing TCP meltdown)
- No compression
- No hardware acceleration for encryption/ decryption.
RouterOS v7.x that is in beta since last year promises to fix these issues. I do know it supports at least UDP now but not sure the others features.
If you want good performance now I recommend to use IKEV2 VPNs with some of the routers that supports IPSec HW acceleration such as hEX S, hAP AC2 or RB4011 just to mention few.
Good luck
Sent from my iPhone using Tapatalk
Users browsing this forum: No registered users and 19 guests
