barbyboy
PCC load balance rules check for not work
Sun Jun 28, 2020 8:45 pm
Hi all,
I'm currently using a config with dual WAN for failover and load balancing traffic with pcc load balance config
and this config not work
my config is:
/ ip address
add address=10.10.10.1/24 network=10.10.10.0 interface=ether3-Vlan3
add address=10.5.60.1/24 network=10.5.60.0 interface=ether6-Vlan6
add address=86.12.89.42/29 network=86.12.89.40 interface=ether1-internet
add address=192.168.30.2/30 network=192.168.30.0 interface=ether2-internet
add address=35.31.126.13/30 network=35.31.126.12 interface=ether2-internet
/ ip firewall mangle
add chain=prerouting dst-address=86.12.89.40/29  action=accept in-interface=ether3-Vlan3
add chain=prerouting dst-address=192.168.30.0/24  action=accept in-interface=ether3-Vlan3
add chain=prerouting in-interface=ether3-Vlan3 connection-mark=ether1_conn action=mark-connection \
    new-connection-mark=ether1_conn
add chain=prerouting in-interface=ether3-Vlan3 connection-mark=ether2_conn action=mark-connection \
    new-connection-mark=ether2_conn
add chain=prerouting  in-interface=ether3-Vlan3 connection-mark=no-mark dst-address-type=!local \
    per-connection-classifier=both-addresses and port:2/0 action=mark-connection new-connection-mark=ether1_conn
    per-connection-classifier=both-addresses and port:2/1 action=mark-connection new-connection-mark=ether2_conn
add chain=output connection-mark=ether1_conn action=mark-routing new-routing-mark=to_isp1
add chain=output connection-mark=ether2_conn action=mark-routing new-routing-mark=to_isp2
add chain=input connection-mark=ether1-internet action=mark-connection new-routing-mark=ether1_conn
add chain=input connection-mark=ether2-internet action=mark-connection new-routing-mark=ether2_conn
/ ip route
add dst-address=0.0.0.0/0 gateway=86.12.89.41 routing-mark=to_isp1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.30.1 routing-mark=to_isp2 check-gateway=ping pref.surce=35.31.126.13
add dst-address=0.0.0.0/0 gateway=86.12.89.41 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.30.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=ether1-internet action=masquerade
add chain=srcnat out-interface=ether2-internet action=masquerade
Users browsing this forum: Bing [Bot], catallguy, jjuzetpu, maxsaf, MikroPlan and 155 guests
